Welcome to the North American Subaru Impreza Owners Club Friday November 16, 2018
Old 06-14-2018, 11:39 AM   #176
Sti831
Member#: 403592
Bump... anyone try making a DIY pressure sensor also? Lol
Sti831 is offline   Reply With Quote
Old 06-24-2018, 04:32 PM   #177
brecks
Member#: 435142
2004 STi
Java Black Pearl
I finally got around to giving this a go. I kept my rear O2 in place, so I made a pigtail for it, using the left TGV for the signal, and the same ethanol sensor posted by the OP. My voltages are as follows:
Battery voltage with the key on: 11.9v (low, I know its been a while lol)
Board power/gnd (where the 8v reg is): 11.7v
The 8v regulator (and/vin): 7.9v
Board 5v: 5.0v (score!)
Signal from E sensor at board: 4.2v
Power at E sensor: 11.7v
TGV signal wire: 0v
I think I may have used the wrong pin from the TGV, and that is why my values are incorrect. My TGV voltage on my AP was reading 0.00 with the car running (no surprise considering the measured voltages at the pins). If someone could confirm for me the signal pin for the TGVs in the 04-07 STi I'd appreciate it!
P.S. I'm using Barge's code, but I don't think this is a coding issue
EDIT: For anyone else having this issue, the signal wire is the yellow/red wire on the 04-07 STi, my TGV voltage is now reading 0.9v, which seems about right for pump 93 (~10% corn)
brecks is offline   Reply With Quote
Old 07-09-2018, 12:57 PM   #178
NickInMN
Member#: 488121
I came up with my own version of this, using this thread as well as a few others for inspiration. I did things slightly differently. I used an Arduino Beetle, a .96 inch LCD and a 5 volt regulator instead to power the Beetle since it doesn't have any voltage protection. I also used interrupts vs pulseIn for the measurements. In the display I have the top line showing ethanol percent and the bottom line showing temp in a bit smaller font.
Code:
Code:
#define EI_ARDUINO_INTERRUPTED_PIN
#include <EnableInterrupt.h>
#include <GOFi2cOLED.h>
GOFi2cOLED LCD;
#define SENSOR_PIN 10
#define OUTPUT_PIN 9
volatile unsigned long previousTime = 0;
volatile unsigned long highTime = 0;
volatile unsigned long lowTime = 0;
void stateChanged()
	unsigned long currentTime = micros();
	// high -> low
	if (arduinoPinState == 0) {
		highTime = currentTime - previousTime;
	else { // low -> high
		lowTime = currentTime - previousTime;
	previousTime = currentTime;
void setup()
	LCD.init(0x3C);
	LCD.setTextWrap(false);
	LCD.clearDisplay();
	LCD.setTextSize(2);
	LCD.println("Ethanol");
	LCD.println("Analyzer");
	LCD.display();
	delay(2000);
	pinMode(SENSOR_PIN, INPUT);
	enableInterrupt(SENSOR_PIN, stateChanged, CHANGE);
	// Setup for analog out, pin 9 to fast mode.
	pinMode(OUTPUT_PIN, OUTPUT);
	TCCR1B = TCCR1B & 0b11111000 | 0x01;
void loop()
	unsigned long pulsetime = highTime + lowTime;
	// 20000 uS = 50 HZ - ~6667 uS = 150 HZ
	if (pulsetime > 200000 || pulsetime < 6667) {
		// If the value falls outside the range just skip it for this iteration.
		return;
	LCD.clearDisplay();
	LCD.setCursor(0, 0);
	// 50 HZ = 0% ethanol, 150 HZ = 100% ethanol
	long eContent = int((1000000 / pulsetime) - 50);
	// These should never hit due to the check above.
	if (eContent < 0) {
		eContent = 0;
	else if (eContent > 100) {
		eContent = 100;
	// 1 millisecond = -40C, 5 milliseconds = 125C
	float frequency = float(1000000 / pulsetime);
	float dutyCycle = 100 * (highTime / float(lowTime + highTime));
	float totalTime = float(1.0 / frequency);
	float period = float(100 - dutyCycle) * totalTime;
	int temperature = 40.25 * 10 * period - 81.25;
	int temperatureF = temperature * 1.8 + 32;
	// Analog out, 0 volts = 0%, 5 volts = 100%
	float desiredVoltage = mapf(eContent, 0, 100, 0, 5);
	int analogOut = 255 * (desiredVoltage / 5);
	analogWrite(OUTPUT_PIN, int(analogOut));
	LCD.setTextSize(4);
	LCD.print("E:");
	LCD.print(eContent);
	LCD.println("%");
	LCD.setTextSize(1);
	LCD.println("");
	LCD.setTextSize(2);
	LCD.print("Temp:");
	LCD.print(temperatureF);
	LCD.print((char)247);
	LCD.println("F");
	LCD.display();
	delay(1000);
double mapf(double x, double in_min, double in_max, double out_min, double out_max)
	return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
NickInMN is offline   Reply With Quote
Old 07-11-2018, 09:06 PM   #179
salvi
Member#: 188132
Best location for the E85 sensor...on the return line.
salvi is offline   Reply With Quote
Old 07-20-2018, 09:49 AM   #180
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
I am experiencing an issue with my sensor voltage dropping to 0 during startup. I am in the process of switching over to Accessport from OS and it is causing the eth content to be locked at 10% during the voltage drop @ start. Any ideas on what can be done?
Datalog of condition - https://datazap.me/u/pearson222/log-...data=4-8-16-17
pearson222 is offline   Reply With Quote
Old 07-20-2018, 04:36 PM   #181
brecks
Member#: 435142
2004 STi
Java Black Pearl
How is it all wired up? Could just be a simple power issue. Have you tested voltages at the board with the car running? Made sure pinouts of plugs are correct? That's where I'd start.
Since all of this is custom, and varies person to person, its a hard issue to diagnose.
