04-28-2016, 03:01 PM | #1 |
Member#: 364950
NWIC
Vehicle:2020 WRX Magnetite Metallic |
Aftermarket BPV for FA20DIT
Hey All,
Boomba racing posted an interesting video today showing how the stock BPV wan't able to hold boost well at all. https://www.youtube.com/watch?v=QFyw-ktSQEQ If this is true then the turbo has to try and keep up with the escaping air. Just wanted to open this up for discussion on aftermarket BPVs for this platform and what (if) there is a benefit to having them. In talking with my tuner he said that they run a boost leak test on every car they tune and have never seen the OEM leak, my question is tho - during a boost leak test, if the BPV is recirculating, would you even see it is it were not able to hold pressure? What do you think?
04-28-2016, 03:03 PM | #2 |
Member#: 295911
NESIC
Vehicle:2015 WRX LR |
I ordered one about an hour ago. $154.08 shipped from subispeed(with "returncust" coupon code.
04-28-2016, 03:58 PM | #3 |
Member#: 210777
SCIC
Vehicle:.. Don't worry bout' it Brah |
Interesting.
04-28-2016, 04:26 PM | #4 |
Member#: 440399
Vehicle:2016 WRX Limited Lapis Blue Pearl |
Added to my wishlist. Always been a fan of boomba products.
04-28-2016, 05:01 PM | #5 |
Member#: 442262
Vehicle:2016 WRX Prem LBP |
I actually opted for a Turbosmart one since I've trusted their products much more. Aside from the point I actually came here to comment on...
Well well well. If the stock recirc was really that leaky, then I guess it would help explain the small loss of boost in the upper portions of the powerband I've been seeing on people's log posts. |
04-28-2016, 05:27 PM | #6 |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
Well s***. I didn't realize the stock piece was that bad. Now I'm looking for more info to back this up.
04-28-2016, 05:28 PM | #7 |
Member#: 364950
NWIC
It would be interesting to have someone else do an "independent" test. I ordered one and I'm going to use it on my tune next week so I'll test the stock one if I can.
04-28-2016, 05:29 PM | #8 |
Member#: 442262
04-28-2016, 05:39 PM | #9 |
Member#: 364950
NWIC
We'll see! Like I said Cobb Surgeline said that they had not seen any boost leaks from testing cars that they tune (they test every car for boost leaks). So I'm not sure why this one appears to be leaking so much.
04-28-2016, 05:48 PM | #10 | |
Member#: 165955
Vehicle:2015 WRX Base WRB |
And I think you are incorrect in thinking that a leak makes your turbo work harder. |
04-28-2016, 05:55 PM | #11 | |
Member#: 364950
NWIC
Maybe I'm missing something? |
04-28-2016, 06:03 PM | #12 |
Member#: 377450
SCIC
Vehicle:2015 WRX - Premium Crystal White Pearl |
Very curious to see what others have found, I've been looking at this BPV for a bit now. The only thing that deterred me initially was you have to trim an OEM hose, nothing a spare on hand wouldn't cure though although I can't seem to find a part number for that hose only just the entire unit from the recall.
http://parts.subaru.com/p/Subaru_201...4462AA571.html |
04-28-2016, 06:15 PM | #13 |
Member#: 166470
Vehicle:2015 WRX |
Sounds like we found a solution.
Now, lets find a problem to justify that solution. |
04-28-2016, 06:20 PM | #14 |
Member#: 398361
Vehicle:2015 wrx ice silver,wr blue |
I went with the nameless bpv about a year ago. When I took my stock valve off,you could blow some air through it from either direction without a vacuum source connected. I tend to believe it may have been made this way. Mine had 6k miles on it at that point. The nameless has been working great. I'm at 13.5k now
04-28-2016, 06:25 PM | #15 |
Member#: 117767
RMIC
^ Yeah, I think I'm with this guy. I need more evidence to back this up. I have to believe that if it was a true issue, shops/tuners would have realized this over a year ago and recommended ditching the OEM BPV right away.
04-28-2016, 09:09 PM | #16 |
Member#: 416044
Vehicle:2015 Subaru WRX 6MT K1X |
I'm running a GFB T9107 recirc valve. Direct replacement perfect fit. Awesome quality. The stock one is crap plastic one that can leak boost. There is no comparison.....
04-28-2016, 09:29 PM | #17 |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
Are these causing turbo flutter to those of you with them installed?
04-28-2016, 09:31 PM | #18 |
Member#: 378214
T0107 or T9107 Mach2?
All three look good, Boomba makes good products and the price for theirs and the GFB seems more reasonable vs Nameless. Looks like GFB can be had for $138 or so. |
04-28-2016, 09:37 PM | #19 |
Member#: 438431
Vehicle:2015 WRX Limited |
If anyone does an independent test can you please post a video? I'd be very interested in seeing. Thinking about getting something like this. Would you need a tune after install?
04-28-2016, 10:01 PM | #20 |
Member#: 76503
Vehicle:2016 Mustang GT |
I'm running the Turbosmart TS-0205-101 as 100% recirc. There is no doubting the quality on the piece, it's extremely nice. Pretty expensive though. I got mine for a damn good price so I couldn't pass it up. Recirc is also quite a bit louder than stock BPV.
04-28-2016, 11:05 PM | #21 |
Member#: 416044
04-28-2016, 11:05 PM | #22 |
Member#: 416044
04-28-2016, 11:09 PM | #23 |
Member#: 416044
04-28-2016, 11:50 PM | #24 |
Member#: 337626
TXIC
Vehicle:2015 WRX Crystal White Pearl |
04-29-2016, 06:13 AM | #25 |
Member#: 391748
NESIC
Hmm maybe I'll grab one to go with my protune and ebcs
