Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 06-04-2018, 04:10 PM   #1
1ucky11
Member#: 229403
2005 Sti
Default 05 sti shift weird
Hey guys,
I noticed when I picked up the car about a month ago, sometimes I can't lift the reverse lockout. But it'll go into reverse fine without it. Also, 5th and 6th isn't all the way to the right, it's slightly passed 3rd and 4th. I'm used to driving it like that now. But I don't know how to fix it. It came with a kartboy short shifter and bushings. And a Perrin reverse lockout. Not sure what to look for or how to fix it.
1ucky11 is offline   Reply With Quote
Old 06-05-2018, 12:47 PM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Get under the car and check the reverse lockout device - compare it to the FSM images. All the parts that break or become disconnected are external and easy to fix.
mrsaturn7085 is offline   Reply With Quote
Old 06-05-2018, 05:59 PM   #3
1ucky11
Member#: 229403
2005 Sti
Where can I find that image?
Old 06-05-2018, 08:44 PM   #4
mrsaturn7085
Member#: 375462
WR Blue
In the FSM...
Old 06-05-2018, 11:03 PM   #5
1ucky11
Member#: 229403
2005 Sti
In the FSM...
I'm so sorry. Hahaha. I dont know what FSM stands for.
Old 06-05-2018, 11:45 PM   #6
Cobrakai
Member#: 176408
2005 STy
Factory Service Manual
You'll find the reverse lockout in front of the front shifter bushing.
Cobrakai is offline   Reply With Quote
Old 06-05-2018, 11:46 PM   #7
Cobrakai
Member#: 176408
2005 STy
Double Post
Old 06-06-2018, 05:46 PM   #8
1ucky11
Member#: 229403
2005 Sti
Thank you so much!
Old 06-06-2018, 06:17 PM   #9
[email protected]
Member#: 67
1999 Outlasting
the competition.
I got a feeling that the reverse lockout cable on the shifter end isnt right. My guess is that the pin on the perrin lockout is too high. might want to try and reset that.
Old 06-06-2018, 06:54 PM   #10
1ucky11
Member#: 229403
2005 Sti
I'll try that. I'm trying to find a pic online to see what I need to go by. Since I bought the car with this issue
Old 06-11-2018, 10:18 PM   #11
[email protected]
Member#: 67
1999 Outlasting
the competition.
http://www.scoobymods.com/showthread...tall-3785.html
Old 06-12-2018, 12:17 AM   #12
BD 04STI
Member#: 487103
Hey guys,
Did you make sure the reverse lockout was specifically for your car? I bought one and it said it would fit Brz, Wrx and Sti. Little did i know it was really meant for a brz. Found out after i chopped off the top to try to make it fit. lol
BD 04STI is offline   Reply With Quote
Old 06-13-2018, 11:47 AM   #13
1ucky11
Member#: 229403
2005 Sti
I finally got a moment to take off the shift boot to see what Iím working with. What can you see wrong with these pictures? Iím going to throat punch the last owner!!![IMG][/IMG]
Old 06-13-2018, 01:41 PM   #14
[email protected]
Member#: 67
1999 Outlasting
the competition.
D'oh! also the second zip tie should go underneath the car to tie up the shifter cable. might be rubbing on the drive shaft.
Old 06-13-2018, 01:57 PM   #15
1ucky11
Member#: 229403
2005 Sti
You think once I fix the reverse lockout the shift gate will fix itself?
Old 06-14-2018, 11:19 AM   #16
1ucky11
Member#: 229403
2005 Sti
Looks like I'm missing a piece under the lockout. Isn't something supposed to be screwed into the shifter
Old 06-14-2018, 12:31 PM   #17
mrsaturn7085
Member#: 375462
WR Blue
I don't think it's 100% needed - there were a few variants. Going off memory here, but I remember distinctly having two 6MT shifters on my workbench once and this difference catching my eye. Aftermarket reverse lock-outs can certainly cause some part changes, too.
EDIT:
The screwed part is just the cone that locates the (p)leather shift boot. The Perrin lock-out and the GpN shifter assembly do away with this fixed part.
Old 06-15-2018, 05:36 PM   #18
Zmanwrx23
Member#: 438620
2006 WRX TR
CGM
you're not missing a piece its been replaced/upgraded. The Perrin reverse lockout is installed on your car. It's a single piece design that combines the factory boot retainer (which is what bolts into the 2 holes on that flange on the shift arm) and the lockout itself.
Zmanwrx23 is offline   Reply With Quote
Old 06-15-2018, 07:51 PM   #19
1ucky11
Member#: 229403
2005 Sti
I'm going to try to take a picture under the car and see if something can be fixed. *update- there are times when I can pull up on the lockout, but when I move it to reverse it won't go in. And when I let go of the lockout, i can't pull it up again with all my might. But then without it pulled it goes into reverse with no problem. Shifter can move past 5th to the right. But of course there won't be a gear there. So I have to go into 5th slightly left of all the way right
Old 06-15-2018, 07:53 PM   #20
1ucky11
Member#: 229403
2005 Sti
So thinking about it. Since the lockout is stuck opened that's the reason why I can go right of 5th. Once I fix that problem 5th gear should be fixed
