#26 |
Member Sales Rating: (110)
Member#: 144779
Vehicle:200X ZOMG a car 100% crabon fibre girlfrendorz |
![]() The grommet is the same one that is used on the OEM tank? Also, thanks for the prompt response.
#27 |
Vendor Sales Rating: (43)
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() Yes, same grommet. Pull it from the OEM tank, swap it over and you're good.
No problem on the reply!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#29 |
Member#: 198281
![]() No. Without knowing what radiator/bung size you have that would be a guess. A couple $ and your local auto parts or hardware store and you're good.
The reservoir is thread 1/8NPT for whatever barb adapter size you need to use.
__________________
#30 |
Member Sales Rating: (15)
Member#: 216768
NWIC
Vehicle:2016 STI HYPER BLUE |
![]() i bought a koyo radiator but it hasnt come in the mail yet. you wouldnt happen to know what i would need off the top of your head would you? i'm just trying to minimize the trips to the auto store when i finally put everything in ya know?
#31 |
Member#: 198281
![]() Sorry of the super delayed response on this.
You'll need an 1/8NPT fitting with a barb on it to match the barb on the radiator. Then a length of hose (that fits the above barbs) long enough to run from radiator to reservoir. I like to run the line under the intake manifild and across the back of the engine.
__________________
#32 |
Member#: 198281
![]() Putting a bunch of these on the shelf so we'll be eliminating the wait for them
__________________
#33 |
Member#: 198281
![]() Plenty in stock and if you look in the 'open box' sub-forum there are some deals for those function first guys
__________________
#34 |
Member#: 198281
![]() Couple pics installed.
__________________
#36 |
Member#: 198281
![]() I've got one with a VERY slight blemish for a slight discount. PM me!
__________________
#38 |
Member#: 198281
![]() PM replied
__________________
#39 |
Member#: 198281
![]() In Stock!!
__________________
#41 |
Member#: 198281
![]() 2002-2005 only at this point. GRs are next
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by KillerBMotorsport; 10-08-2013 at 07:30 PM. |
#42 |
Member#: 198281
![]() Website updated. Bump.
__________________
#43 |
Member#: 198281
![]() We have lots of these in stock
__________________
#44 |
Member#: 198281
![]() Still got some
__________________
#46 |
Member#: 198281
![]() Slip of the keys... Fixed
__________________
#47 |
Member#: 198281
![]() Happy Cyber Monday!
__________________
#48 |
Member#: 198281
![]() In stock!
__________________
#50 |
Member#: 198281
![]() Check this thread out. These should be available soon...
http://forums.nasioc.com/forums/show....php?t=2567495
__________________
FS : WeaponR Coolant Overflow/Washer Tank | 02wrxbugg | Engine/Power/Exhaust | 4 | 04-12-2011 11:39 PM |
F/S:VA; STi coolant and washer tank with pump | moorebl | Engine/Power/Exhaust | 5 | 01-02-2010 02:39 PM |
Coolant Not Recirculating Correctly Between Lower & Upper Reservoir Tanks | chuglobal | Service & Maintenance | 13 | 10-13-2009 09:21 PM |
WTB:Windshield washer reservoir/tank | caesar | Private 'Wanted' Classifieds | 2 | 07-07-2008 01:33 PM |
Weapon R Coolant/windshield washer tank | Legacy777 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 05-20-2006 09:57 PM |
