05-30-2006, 10:34 PM | #1 |
Member#: 1140
SCIC
Vehicle:2000 S201 #78, '95 L '13 F150 Ecoboost |
question about clutch line RS-STi
Okay, so I have a ver. 8 transmission and slave cylinder, and the banjo bolt flexible fluids line with a female fitting. I know it supposed to bolt to the hard line that winds it's way to the master cylinder. My question is this, I think the line should be long enough and flexible enough to connect the flexible line directly to the master cylinder via a male-to-male fitting? Is the long, solid line needed?
05-31-2006, 03:43 AM | #2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
yes you must keep the solid line, there's no need to replace it, the less flexible line you have the better, flexible hose cuts back on the pressure
05-31-2006, 10:02 AM | #3 |
Member#: 1140
SCIC
I don't have the solid section of line, that's why I ask. I can find/make one, just don't know if it's needed for the clutch to operate propererly. Anyone know the reason you need the hard line?
05-31-2006, 12:19 PM | #4 |
Member#: 6551
use the one that came on the car originally...it's the same line
05-31-2006, 09:12 PM | #5 |
Member#: 1140
SCIC
I have an automatic 2.5RS i'm installing a ver. 8 drivetrain and converting to manual, that's why i'm asking.
06-01-2006, 02:46 AM | #6 | |
Member#: 6551
06-02-2006, 12:07 AM | #7 |
Member#: 1140
SCIC
I may have one lying around at the shop, thanks for the info.
06-03-2006, 05:24 PM | #8 |
Member#: 25952
NWIC
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
You don't need the metal line. It just gets in the way. What I did was just spent like 30.00 on a custom stainless line. Flexible as rubber, but doesn't expand under pressure like rubber does.
06-12-2006, 05:28 PM | #9 |
Member#: 1140
SCIC
I found a metal line lying around, thanks!
SoCal : STi Stainless Brake Lines, STi Stainless Clutch Line & STi Trailing Link Set! | outcast | Suspension/Brakes/Handling | 15 | 11-30-2006 12:56 AM |
WRX pedal box, clutch master cylinder, clutch lines, RS exhaust, axles, and more! | 2.5 Blue Roo | Private 'For Sale' Classifieds | 13 | 10-04-2005 10:48 PM |
Question about Gold-line lowering springs | Maniac | Brakes, Steering & Suspension | 7 | 12-26-2002 01:48 PM |
Question about boost line vacuum and a MBC. | Cjchaps | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 05-28-2002 09:26 PM |
question about brake lines and pads | brainofjjj | Brakes, Steering & Suspension | 7 | 07-18-2001 04:42 PM |
