Welcome to the North American Subaru Impreza Owners Club Tuesday October 23, 2018
Old 06-04-2006, 01:44 AM   #1
AveyWRX
Member#: 112482
Default Question on boost gauge
I installed my boost gauge today. Everything went in ok and it seems to be working right. But when I get the boost up over 5psi the gauge needle flutters a bit and you can hear a ticking sound from it. It happens if I go WOT. I've also heard it tick when decelerating but it isnít as bad. Almost sounds like a bad rattle.
The boost gauge is a Omori 45mm mechanical boost gauge.
Is that a normal? Or did I hook something up wrong? Or is it maybe a bad gauge?
I double checked that the side of the "T' with the restrictor pill is going to the gauge. I also have all the tube connections zip tied.
My gut is telling me its a bad gauge. Just wanted to get a second opinion before trying to exchange it.
Any input would be great.
AveyWRX is offline   Reply With Quote
Old 06-04-2006, 02:21 PM   #2
Bluwater
Member#: 105040
i just installed the same gauge friday night. I also notice a rattle...
any info about this would be great.
Bluwater is offline   Reply With Quote
Old 06-04-2006, 02:26 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Hm, I have the same one and it's fine. Since it replaced the OEM gauge I just disconnected the existing line from the old gauge and connected it to the Omori, so I'm using the restrictor from the Lamco gauge. Still there shouldn't be any difference.
Where on the engine did you connect the gauge? It should be tapped into the line to the bypass valve.
Old 06-04-2006, 05:08 PM   #4
AveyWRX
Member#: 112482
Prety sure I hooked it to the right place. I'll take some pictures and post them
Old 06-04-2006, 05:12 PM   #5
AveyWRX
Member#: 112482
Old 06-04-2006, 05:22 PM   #6
WR^2X
Member#: 37617
That is an unusual spot to put it... Most tee it off of the line at the BPV. That's the factory gauge's pressure source.
WR^2X is offline   Reply With Quote
Old 06-04-2006, 09:07 PM   #7
AveyWRX
Member#: 112482
I was going off these instructions: http://www.j-spectuning.com/installs/wrxmechboost.pdf
So should I move the connection by the BPV?
Old 06-04-2006, 10:34 PM   #8
AveyWRX
Member#: 112482
I moved it to the line off the BPV. It seems like the noise went away.
The gauge I got came with a second T. The other T was larger on the the sides going to the line. I switched over to that one since the other one I was using was to small for the line off the BPV The first T fit perfect for the line I had it hooked to originaly.
Old 07-12-2006, 01:40 PM   #9
wrXmon
Member#: 115454
My 2002 WRX Wagon
still gets compliments.
Default Boost gauge 'T'-in
I brought this thread up because I am getting ready to install an electrical Omori boost gauge, and I am a little confused as to where to tap into to get a good turbo/vacuum reading. According to J-Spec's site (whom I bought the gauge from) it is tapped at the BPV, and then I have noticed that other people will tap into the line at the FPR.
Please, would someone solve this issue?
Editted: I typed BOV instead of BPV.
wrXmon is offline   Reply With Quote
Old 07-12-2006, 02:35 PM   #10
WR^2X
Member#: 37617
At the BPV, do not use the FPR. People have messed this up, run lean under boost, and blown their engines.
Old 07-12-2006, 04:04 PM   #11
wrXmon
Member#: 115454
My 2002 WRX Wagon
Thank you.
Old 07-12-2006, 04:48 PM   #12
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
Originally Posted by AveyWRX
i've had mine mounted here too for over 4years and have never had that issue. i've had 2 different boost gauges and no flutter.
taerron is offline   Reply With Quote
Old 07-12-2006, 05:00 PM   #13
wrXmon
Member#: 115454
My 2002 WRX Wagon
Still not clear enough... I want to make sure that I get the most accurate reading for boost/vacuum pressure when I install my gauges (the other one is an electrical oil temp), and it seems there are two different places to install each sensor/line. I was told by a friend that the closest place to the throttle body on the intake manifold is best, and I'm thinking this is it:
Again, someone please clarify.
Old 07-12-2006, 05:18 PM   #14
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Use the BPV hose. If you follow it down you will see that it goes to the manifold directly under the TB. This is the location Subaru recommends for the optional OEM gauge and everyone else uses it too.
Old 07-12-2006, 05:56 PM   #15
wrXmon
Member#: 115454
My 2002 WRX Wagon
Thanks, Mulder. Clarified.
Old 10-12-2006, 01:32 AM   #16
brando3wagon
Member#: 103282
2003 wrx wagon stg1
blue
sorry to revive an old thread here, but im a little confused were to t off as well. whats the bpv? another name for bov?
brando3wagon is offline   Reply With Quote
Old 10-12-2006, 07:12 AM   #17
RP31
Member#: 123574
2005 STi
CGM
No, the two are very different, but you are probably thinking of them as being the same. It's the thing attached to the front driver's side of the intercooler. Tee into the small vacuum line coming off of it.
RP31 is offline   Reply With Quote
Old 10-12-2006, 09:51 PM   #18
brando3wagon
Member#: 103282
2003 wrx wagon stg1
blue
so this guy is where i need to T in? i thought this was the bov..haha im retarded.
Old 10-12-2006, 10:54 PM   #19
brando3wagon
Member#: 103282
2003 wrx wagon stg1
blue
anyone? is that the right place to t in?
Old 10-13-2006, 07:05 AM   #20
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes that is the correct place. The pic shows the factory bypass valve which is commonly (and incorrectly) referred to as a BOV.
Old 10-15-2006, 10:56 PM   #21
boostpower
Member#: 116550
2006 WRX
Crystal Gray Metallic
So my assumption is that you would T in right before that valve or to the right of it as you're looking at it in that picture?
boostpower is offline   Reply With Quote
Old 10-15-2006, 11:00 PM   #22
brando3wagon
Member#: 103282
2003 wrx wagon stg1
blue
yeah..i think im going to just get a small piece of the same size hose and plug it into the bpv, then put the t in that, then put the orignal bpv hose on the other side, in case i need to take out the gauge for any reason.
Old 10-15-2006, 11:03 PM   #23
boostpower
Member#: 116550
2006 WRX
That's a good idea as long as the length of the hose doesn't have to be kept a particular length. Cutting things always makes me nervous anyways lol. I can't wait to install my gauge now, but I need a piller or something to put it in lol
Old 10-15-2006, 11:09 PM   #24
brando3wagon
Member#: 103282
2003 wrx wagon stg1
blue
yeah im only going to add like a 1" piece..maybe ill just cut it..depends on how lazy i am when it comes what kind of gauge do you have? and what size? im gettin a pretty sweet lookin deal, omori 45mm (its in psi and maches my 03 interior ) and a pod to put on my steering wheel column for 140.
Old 10-15-2006, 11:12 PM   #25
boostpower
Member#: 116550
2006 WRX
I got the Prosport 52mm Mechanical, $35 shipped. I just have to figure out how I want to mount it. I only have the one gauge so I don't want the 3 pod where the clock is and I'm not so sure I really like the mounting on the stearing wheel like the OEM ones are.
quick question on boost gauge speaker wire BlackoutWRX Newbies & FAQs 1 02-11-2006 06:22 PM
VAC on boost gauge reads zero, boost 30PSI stock!!! xS2k Electrical & Lighting 12 10-23-2005 12:06 AM
problem! showing no boost on boost gauge Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-26-2004 11:22 PM
quick question about boost gauge vacuum? marvd00d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-28-2002 01:46 AM
Question on boost gauge? WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-20-2001 09:47 PM
