10-16-2011, 06:10 PM | #51 |
Member#: 104200
TXIC
Vehicle:000 WHP BUGEYE Street Proven Performance |
10-16-2011, 06:32 PM | #52 |
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
10-16-2011, 10:31 PM | #53 | |
Member#: 104200
TXIC
10-17-2011, 12:55 AM | #54 | |
Member#: 64908
10-17-2011, 01:01 AM | #55 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
tooned.
10-17-2011, 07:20 AM | #56 |
Member#: 5591
Vehicle:2002 WRX EJ257 Gt35r |
That's pretty awesome. I know we are getting close to some data, but how does the 6265 spool? Like when are you seeing target boost on the road. And how do you expect it to compare to the 6266?
10-18-2011, 12:32 PM | #57 | |
Member#: 64908
CarTOONED.. lol..
It can hold 33psi to redline and I am sure if I tried for 35 it would do the same. I expect to see a 200-300rpm reduction in spool and about 20-30whp at the same boost. I also expect to be able to run 38-40psi with it and make over 700whp Jr |
10-20-2011, 11:23 PM | #58 |
Member#: 64908
Transmission time guys.. Im so stoked! This thing will be going 9s easily next yr. All in a real deal full weight street car like Rob58s 06 from a few yrs back. Those are my favorites!
10-21-2011, 04:53 PM | #59 |
Member#: 67199
Vehicle:07 8.8@171mph STI 97 RS 8.3@165mph |
10-21-2011, 05:44 PM | #60 |
Member#: 171948
Vehicle:19 Sti Crystal white |
nice.that car is a beast.
10-21-2011, 05:55 PM | #61 |
Member#: 63192
Vehicle:02 wrx 161mph Trapspeeds |
Car I's moving but holy tail wind batman! Car sounds great! Tires?
10-21-2011, 06:36 PM | #62 | |
Member#: 64908
Anyway car is on Hoosier 17s |
10-21-2011, 06:51 PM | #63 |
Member#: 63192
Look at video and the flag I's moving pretty crazy! Still a great pass I'm just very observant
10-22-2011, 08:19 PM | #64 | |
Member#: 64908
Well if you wanna get observant, observe all of the track... look at the yellow safety tape and watch it blow sideways, and the yellow towel by the tree blowing sideways It is near the windy city after all |
10-23-2011, 10:50 PM | #65 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
the civic....lol..
nice work |
10-24-2011, 11:17 AM | #66 |
Member#: 64908
10-24-2011, 08:01 PM | #67 |
Member#: 132587
Vehicle:2006 JrTuned STi 8.69@164mph |
Damn driving is spot on. Don't get to see that very often.
10-24-2011, 08:15 PM | #68 |
Member#: 132587
Speaking of P&L...when are they planning to update their website?! I want to see some of these new toys of theirs and get some pricing.
10-25-2011, 01:17 AM | #69 |
Member#: 64908
Yes the Russian is a beast.
Small update on the car Gears and 66 upgrade are getting done. I doubt he will be out again this season, but watch out for a mid 9sec full weight street car in the spring. Call the shop, the website is under development. Lots of stuff going on and at a very rapid pace. I have been flying out literally every week to tune 10+cars at a time because we have been so busy and backed up. |
10-25-2011, 01:44 AM | #70 |
Member#: 63179
BAIC
Vehicle:2006 Stock Turbo STi [email protected] VF39 |
the driving is def spot on,
major props can you PM me where did you get that 17 Hoosiers with white wall lol |
10-25-2011, 08:41 PM | #71 |
Member#: 132587
Will do when I get closer to purchasing a big kit, maybe if someone from P&L sees this post they can chime in on ball park rotated kit pricing and if it is competitive with some of the other big name kits out there.
10-25-2011, 09:57 PM | #72 |
Member#: 71287
South East
Vehicle:S202 #387, Type RA #169 and an 04 STi |
Jesus that things nuts! Now Im happy I am going with a lot of P&L parts!!
10-28-2011, 11:59 PM | #73 | ||
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
Ciao! |
10-29-2011, 12:25 AM | #74 | |
Member#: 64908
For starters, I am one of the few idiots that had a full cosi long block.. The really expensive one. It lasted me about 300 miles before I had to open it up and inspect it. It sounded like **** from day one. 2 cylinders on the same side, larger PTW then the other... Funny from this great company that something like that could happen. .. Right? I was told to ship the motor in for "inspection" .. Onto the cylinder heads.. You ever heard of this little company called HeadGames? The fastest imports in the WORLD run his heads. He took my Cosi heads and showed me how much they sucked, showed me how crappy the valve job was, and then showed me how it is just essentially a stock head with the complete port opened up. Naturally it will flow better then stock. Do a search on how many small time guys build better flowing heads then the cosworths... Pretty much the only good thing in those heads are the Ferrea valve-train components. Even the CAMS SUCK, search on here how many have broken, go on EVOM and look at how many people have bent valves to Cosworths POS cams that broke. Cosworth USA is what we get, not the same Cosworth UK.. so maybe you should get your data straight before you spew out bogus statements. Just because it says Cosworth doesn't mean its the awesome stuff that they started with in the UK yrs ago. The stuff we get here sucks.. Plain and simple, you don't have to believe me.. You can go spend your own money and find out for yourself. IMO cosworth parts are not worth it, the pistons will crack when you really start leaning on them because of the material. The crack is a over priced Arrow crank, the rods are carrillo's that they charge 400 more for.. ACL-Cosworth bearings.. H11 tool steel studs- ARP L-19.. All over priced, why? Because some one like you will see COSWORTH think its the best because of the name and spend 100000s on it. Jr |
10-29-2011, 10:15 AM | #75 |
Member#: 161816
Vehicle:2006 sti 35r beast 10.12@139 |
i should really invest in a mudpit, I bet I can make mad $$$ on JR! |
Similar Threads | ||||
Cleared 05 sti headlights FOR stock 05 sti headlights | GallardoKing | NWIC Private Classifieds | 4 | 11-07-2011 12:13 PM |
FS : 05 sti Project Mu. Rear brake pads FO FREE!!!! | sundayWRX | Suspension/Brakes/Handling | 10 | 01-04-2011 03:13 PM |
05 sti project, soon on 18x9.5 rota grids | stilv | Member's Car Gallery | 88 | 09-25-2009 04:04 PM |
05 sti project car.. only 25k miles! | michsti | Private Vehicle 'For Sale' Classifieds | 1 | 07-13-2009 03:06 PM |
05 STi stage 2 dynotuned... at AMS? | EarlQHan | Proven Power Bragging | 76 | 08-17-2007 02:57 AM |
