10-19-2000, 11:12 AM | #1 |
Member#: 2005
Vehicle:98 Vw Jetta VR-Sex Cool White... |
Which is the Best turbo? HELP!
IHI turbo
T28/T3 T3/Super 60 T3/T4 hybrid i dont know of ne others also would they compare to ball bearing turbos..... i mean what would be the best turbo for my auto 2000 RS .. i want it to spool up as quickly as possible with no lag and start at the lowest RPM range and End the farthest thanx.... please HELP and explain all in Laymans terms thanx.... also price of each... thanx -DarkLite |
10-19-2000, 11:39 AM | #2 |
Member#: 2052
If you find something like that, let us all know.
Ball bearing turbos are supposed to be more durable, from what I've read. Search around, I know somebody posted about a company that makes a ball bearing turbo that can work on the RS. Of course, they're way more expensive. Check out: http://www.vishnuperformance.com/ http://www.carmodifcations.com/ I hear that Car Modifications is working on a new twin turbo set up. I'm going for the TEC-II first (from Vishnu), then a turbo (twin?) later. I believe that half of Minnam went to Vishnu and the other half went to Car Modifications. Lots of people feel pretty good about the Minnam Stage II. |
10-19-2000, 11:53 AM | #3 |
Member#: 216
If you want the one that spools quickest, then it's the IHI (though there's lots of IHI, I assume you are talking about the one JC sports was offering). However you'll be limited to around 230 HP in stock trim.
Ball bearing sections allow the turbo to spool a bit quicker. |
Similar Threads | ||||
Which is the best turbo timer? | eL_DiAbLoFeR | Newbies & FAQs | 3 | 09-07-2008 09:23 PM |
So...which is the best turbo kit... | adofly | Built Motor Discussion | 0 | 12-24-2007 07:14 AM |
Which is the Best BOLT ON TURBO?? | ac23 | Newbies & FAQs | 25 | 06-06-2007 01:52 AM |
Experts question which one is the best turbo | Roadrunner(NL) | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 06-27-2002 02:22 AM |
Which is the Best Turbo Exhaust System for WRX | ImprezaSTIVI | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 07-09-2001 07:51 AM |
