05-19-2009, 09:21 PM | #1 |
Member#: 71092
MWSOC
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Does the NA Block Have the Same Oil Gallery Plugs as the Turbo Block?
As the title says, and if so, do they use the same thread and pitch as the turbo plugs?
How many of them are there that aren't in use already? Last edited by williaty; 05-20-2009 at 03:27 PM. Reason: Grammar pwnz me. |
05-20-2009, 12:13 PM | #2 |
Member#: 209316
NESIC
Vehicle:14 XV OBP |
freeze plugs u mean??
05-20-2009, 03:27 PM | #3 |
Member#: 71092
MWSOC
05-20-2009, 12:51 PM | #4 |
Member#: 168862
NESIC
Vehicle:2007 ej253n/a 5speed Red Sox Nation Lifer |
does they use? nice
05-20-2009, 05:00 PM | #5 |
Member#: 115154
MWSOC
Vehicle:2005 Outback XT White on grey |
on the turbo motor, there's one on the back passenger side next to the turbo, and another one underneath the alternator.
05-20-2009, 05:07 PM | #6 |
Member#: 71092
MWSOC
Right, and all the info I've been able to find is for the turbo motor. I'm wondering if the NA motor has the same plugs, in the same place, with the same diameter and thread pitch.
05-20-2009, 05:10 PM | #7 |
Member#: 115154
MWSOC
well, you could always look at yours The one underneath the alternator should be there too since that's where the factory oil pressure sensor is.
05-20-2009, 05:14 PM | #8 |
Member#: 71092
MWSOC
Yeah, I found the one under the alt when I re-sealed the oil pump over the weekend (which still leaks, dammit!).
05-20-2009, 05:57 PM | #9 |
Member#: 165749
this is something I would like to know, also. plug size and thread pitch/type specifically.
05-20-2009, 06:00 PM | #10 |
Member#: 71092
MWSOC
The turbo ones are M18x1.5 I guess I'll be the guinea pig to find out if the NA ones are the same.
05-20-2009, 06:07 PM | #11 |
Member#: 165749
cool. I'll bet they are. You asking so you can get a sending unit adapter or are you just replacing them?
05-20-2009, 06:09 PM | #12 |
Member#: 71092
MWSOC
Putting gauges in. I'd like to know how high the oil pressure is getting since I can't stop the pump from leaking.
05-21-2009, 01:49 AM | #13 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
I have never taken the plugs off, but I would be pretty darn sure they are the same. It doesnt make sense that Subaru would use 2 different sized plugs just because one block is semi-closed vs. open deck.
I will assume you have tried a new crank seal.... What kind of sealant are you using? ~Josh~ |
05-21-2009, 12:08 PM | #14 |
Member#: 71092
MWSOC
05-21-2009, 02:09 AM | #15 |
Member#: 126217
MWSOC
Vehicle:04 Jetta GLI Blue |
they are the same i just pulled one off of my n/a block to put on my turbo block.
Similar Threads | ||||
Aftermarket oil pressure gauges and oil gallery plug... Q | gopsu | Newbies & FAQs | 12 | 12-05-2009 06:08 PM |
Oil Pressure/Oil Temp/Oil Gallery plug | WRenXhaven | Electrical & Lighting | 28 | 05-28-2009 01:54 PM |
Where is the oil gallery plug under the intercooler? Pic inside | Donnie_Doritos | Newbies & FAQs | 7 | 07-13-2008 08:47 PM |
To the local's who've done a gauge install: Where is the front oil gallery plug? | Schleppy | New England Impreza Club Forum -- NESIC | 12 | 01-14-2006 08:33 PM |
Wanted: the plug you remove to put in an oil gallery plug | North Ursalia | New England Impreza Club Forum -- NESIC | 15 | 07-01-2005 02:41 PM |
