01-20-2005, 11:25 PM | #1 |
Member#: 53573
South East
Vehicle:2005 STi Silver Silver and fun |
How much exhaust wrap do I need to wrap a gp moto header?
Just like the i tsays. I just want ot know how much. A store tried to to tell me that I would need 2 1 inch roles and 1 2 inch role(each role being 50 ft), plus the clips and the protective spray. That total came to a little over $100. I might as well have it coated if I could find a place.
01-21-2005, 08:34 AM | #2 |
Big Ron
Super Moderator Member#: 18062
That's a big header so I would guess 100ft. After you add in the spray and the clips, wrapping isn't cheap either.
01-21-2005, 10:14 AM | #3 |
Member#: 71542
Vehicle:2013 WRB BRZ |
Una is right, it's not cheap, but it is still cheaper than coating and you don't have to send your parts to anybody (what a pain in the arse). I wrapped my GTSpecII header and I needed about 3/4 of a 50 ft roll so you might be able to get away with one roll for your header. I wrapped my uppipe, top part of my DP, and my entire header with about 1.75 rolls (50' rolls). I bought two spray cans, two rolls of wrap, & the wrap binders from Summit Racing and it cost about $110.
Just FYI, the headers are a PITA to wrap b/c the piping curves so much and usually header pipes are very close to each other (not allowing you to run the wrap through the piping very easily). You will see, it is a PITA - or at least a GTSpecII header was. Last edited by SilverSurfer04STi; 01-21-2005 at 10:22 AM. |
01-21-2005, 10:57 AM | #4 |
Member#: 70234
Vehicle:MY86 BMW E30 325 SCIC/NWIC tranplant (-_-) |
i'd recommend getting it coated. it'll last longer and isn't too much more expensive. try finding somewhere within driving distance to cut-down on shipping costs. i found a place that would do a header, uppipe, downpipe, and turbo heatshield for their minimum service charge of $200. turn-around time was 7-10 days.
01-21-2005, 01:13 PM | #5 |
Member#: 70337
SCIC
Vehicle:2005 STi What's that on your hood? |
Kenny can you post the info about that place. I live in the OC also and may be interested when I get my exhaust in a few months.
PS - Were you the guy at Aerosim the night of the South Coast Subaru event, Blue STi? I came later. If so it was nice to meet you, your car gave me some ideas. |
01-21-2005, 01:32 PM | #6 |
Member#: 524
Vehicle:04 STi White |
If you wrap the pipes in the "collector" area individualy, it will take about 100ft. You can get away with 50ft if you just make sort of a blanket over th large sections. you will need wire to tie the individual wraps to the one next to it so that it doesn't fall apart.
01-21-2005, 06:23 PM | #7 |
Member#: 53573
South East
Thanks for all the replies.
01-21-2005, 07:00 PM | #8 |
Member#: 53573
South East
Is it a must to wrap each pipe? Or can I just wrap the whole thing as one(blanket wrap). I do not see how this would hender performance. I like the blanket wrap idea.
01-21-2005, 08:20 PM | #9 |
Member#: 32576
Vehicle:04 STI |
I personally did both wrapping and coating. 50' of 2" wrap will do most of it, or 100' of 1". 1" is much easier to wrap, but takes longer.
Also keeping your undertray in helps shield the headers from cooling winds. |
01-21-2005, 08:22 PM | #10 |
Member#: 53775
Vehicle:03 WRX Silver |
Wrapping is such a waste. Should have gotten te QTP. It comes Jethot 2000 coated. Just put it on the car. Put if i was you i would send your header out to jet hot and get it coated in the 2000. So much better than wrapping it.
01-22-2005, 08:26 AM | #11 |
Member#: 44629
Vehicle:CNC 'd heads, cams DB18g/EWG - F/S $8K |
http://www.store.yahoo.com/racingsup...thermotec.html
I'd get a butt load of 2" wide (100').. and wrap a foot or two of your DP. My GP Moto was a pain to get in (I didn't wrap it, I regret it).. you may end up damaging the wrap.. the header was that tight to get in. Try to avoid too much overlap, 'cause like I said, it was a pretty tight fit. It's also easier to remove the turbo when installing the header. Those studs are a real PITA to line up with the turbo. |
01-22-2005, 11:29 AM | #12 |
Member#: 53573
South East
It did not take me that long to install. Only an hour. I have to remove it and then wrap it. The key to getting that header in is to turn 180* to where most of the header is sittng on the outside on the passenger side. Slide the uppipe up and rotate.
01-22-2005, 05:17 PM | #13 | |
Member#: 70234
yesterday, i actually dropped off the same parts i listed in the post above. sermatech offers three different ceramic colors: black, grey, and polished silver. i, of course, opted for the polished silver. iirc, these are the steps in their process: acid dip, sand blast, ceramic coating, bake. i think they said it was a two process layer ceramic coat; i'll post pics of the components when i get them back. i drive a cgm wrx, actually: |
02-08-2005, 08:51 PM | #14 |
Member#: 36234
SCIC
Vehicle:2005 WRX STi CGM |
Does the plasctic undertray still fit with the GPMoto headers? It looks like it would be tight. That tray plays an aerodynamic role...I would hate to be forced to take it out.
02-08-2005, 09:01 PM | #15 |
Member#: 58221
Vehicle:2004 STi Silver/18x8 BBS RE's |
No, the plastic undertray still fits underneath the headers, but there is not a whole lot of room b/w them.
02-08-2005, 10:18 PM | #16 |
Member#: 524
The STi undertray usualy need a small section cut out where the one pipe makes the u-turn back to the merges. I cut mine by simply mounting it back up and letting it melt exactly where its a hair too close, then cleaning up the edge.
how much brake fuild do i need to bleed an 04 sti | ppericfe | Brakes, Steering & Suspension | 4 | 02-06-2007 02:46 AM |
how much brake fluid do I need for a flush | DanZ | Service & Maintenance | 18 | 03-23-2004 04:28 PM |
Where to get a GP MOTO header installed in DFW | SHOOKWRX | Texas Impreza Club Forum -- TXIC | 7 | 02-04-2004 11:58 AM |
How much brake fluid do i need for complete change? | edkwon | Brakes, Steering & Suspension | 6 | 10-27-2002 04:28 PM |
How much brake fluid do I need | aov | Brakes, Steering & Suspension | 2 | 08-28-2002 10:11 PM |
