Welcome to the North American Subaru Impreza Owners Club Tuesday April 24, 2018
Old 03-17-2007, 02:33 PM   #1
-Eric-
Member#: 143427
04 WRX 2.0
Default Anybody used Motul oils??
Been looking at the Motul 8100 5W-30 full syn. and was wondering if anyone else has used any of the Motul products before, and what they thought???
-Eric- is offline   Reply With Quote
Old 03-17-2007, 03:30 PM   #2
bluesubie
Member#: 767
04 FXT
That's what I'm running right now in my FXT. It's on the low end of a 30 weight and I switched to it in hopes that my engine would warm up more quickly in winter because of my short trips. I'll be replacing it before June because I prefer a thicker oil in summer.
A few people here have used the 300 V racing oils. Any one of the other 8100 30 weights are thicker than the 8100 5W30. Motul will soon have a very shear stable 8100 0W30 X-Lite that's on the high end of the 30 weight range.
Where do you live and what would you run it in? Click around on bitog (linked above) for some various Motul info.
-Dennis
Old 03-17-2007, 05:27 PM   #3
-Eric-
Member#: 143427
04 WRX 2.0
I'm in the Western NC area. Lots of good curvy roads to have fun on. I'm going to primarily be using my WRX sedan as a weekend leisure vehicle and short vacationing, etc. Is the 5W-30 okay for all season??? We keep mild weather here.....
Old 03-17-2007, 09:40 PM   #4
bluesubie
Member#: 767
04 FXT
It depends how often you change your oil. Change it every 3k and you're fine. I'm expecting mine to shear down to a 20 weight since I'll run it for about 6k miles. The 8100 X-Lite is said to have zero shear. If you drive hard, go with the X-Lite, 300V 5W30 or a 40 weight IMO.
-Dennis
Old 03-17-2007, 09:55 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Open your hood.
See the oil cap where you add oil?
It's yellow with black lettering right?
Read that lettering.
Old 03-18-2007, 12:36 PM   #6
bluesubie
Member#: 767
04 FXT
Originally Posted by Unabomber View Post
Open your hood.
And don't forget the part the states "See Manual".
-Dennis
Old 03-18-2007, 03:37 PM   #7
mikeythejew
Member#: 141672
Waste of money if it doesnt meet the ACEA A3 spec. The ACEA A3 oils hold up better and are rare in 5w30.
mikeythejew is offline   Reply With Quote
Old 03-18-2007, 03:38 PM   #8
mikeythejew
Member#: 141672
BTW, thicker oils cause higher oil temps then thinner oils.
Old 03-18-2007, 06:40 PM   #9
bluesubie
Member#: 767
04 FXT
The X-Lite I posted above meets it. I just added about 1/4 quart of the 5W30 after 2,000 miles. I was spoiled when running German Castrol 0W30 (meets ACEA A3) and didn't add a drop. Even during a 7,500 mile interval.
-Dennis
MOTUL Oil, MOTUL Gear Oil, MOTUL Coolant, MOTUL Brake Fluid, MOTUL Engine, MOTUL Agile Auto Car Care & Detailing 20 10-18-2011 11:55 PM
anyone use motul engine oil? kimguroo Baja Forum 3 02-18-2008 11:03 AM
Anybody use symthetic oil? rechrgd Tribeca Forum 10 12-27-2006 04:55 PM
anybody ever use 5w40 oil? godfather2112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-16-2004 03:40 AM
Anybody uses 15W-40W motor oil? Is it for trucks only? Dealer Xing Off-Topic 20 04-17-2004 08:47 PM
