10-03-2013, 11:53 PM | #726 |
Member#: 272090
Vehicle:2006 Subaru Forester SGM |
glad to see your healing. if you donate to me ill donate to you lol.
10-04-2013, 12:02 AM | #727 | |
Member#: 259194
Vehicle:2005 WRB STI |
What parts did you need? |
10-04-2013, 01:07 AM | #728 |
Member#: 193189
Vehicle:2006 Impreza Black |
i had a grade three mcl and acl tears and a meniscus tear... so yea i blew my knee out pretty bad... but just a bunch of stuff... driveshaft, axles, engine harness, ecu, rims , tires, seats... i know some i dont need but its on my list... and a big brake kit
10-05-2013, 02:39 AM | #729 |
Member#: 193189
10-05-2013, 02:40 AM | #730 |
Member#: 193189
10-05-2013, 10:25 AM | #731 |
Member#: 217648
BAIC
That looks so nice... Were the original end cap plastic or metal and just crimped on?
10-05-2013, 01:35 PM | #732 |
Member#: 239620
Vehicle:2003 WRX Wagon Aspen White |
it's a mishimoto rad, full aluminum. looks like he just cut off the original end tank and fitted this properly build looks great man! good luck with the recovery and your build progress!
10-05-2013, 01:43 PM | #733 | |
Member#: 193189
it was aluminum to begin with, but i had already moved the original inlet and welded on -20 AN fittings. The An 90 degree hose ends were really too big to fit so going to make hoses out of 304 stainless and use silicone connectors. So after cutting the AN fittings off, just wanted it to look cleaner and nicer. |
10-05-2013, 01:56 PM | #734 |
Member#: 217648
BAIC
That's going to look really good
10-06-2013, 12:50 AM | #735 |
Member#: 348242
Vehicle:2013 Impreza WRX Plasma Blue Pearl |
Be careful welding that new top tank on that you dont get the header plate too hot. The tube/header joints are not welded but controlled area furnace brazed. Get them too hot and the joints will open up and you'll have some serious leaks you wont be able to fix. Also some manufacturers use epoxy on the bottom side, can't remember if mishimoto does...
10-06-2013, 10:38 PM | #736 | |
Member#: 193189
10-06-2013, 10:51 PM | #737 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
Whats wrong with the Tig. What model? My 250 Syncrowave was acting up years ago. turns out it was a bad ground wire. few min with a wrench and its as good as new.
10-07-2013, 12:27 AM | #738 |
Member#: 193189
I have a diversion 180, at the time I didn't have a budget for the dynasty. But when I first got mine, it welded like ****, and tracked it down to the ground wire being loose, Nut on the main board was loose. but now its clicking and thumping, when you power it on, when you weld it sounds like its about to exploded, moaning and groaning, It was never like that, then it just started it. Its under warranty but everything checked out okay, but I told the service guy to try and weld on AC, and it would act up. He finally got it to act up and Miller sent the main board ( not sure what its called) but the noise is still there. I got it back, tried it on DC (stainless and the arc is going crazy ) like it did on AC before. So they said the noise i would have to deal with it... I told them they are crazy ( people at miller). I asked them how would I be able to sell it sounding like it does. But the service guy said he would swap the other board out, ( telling miller it checked bad) so we can just try that and see if that corrects the problem. I really want the new HTP that runs for $2500... I saw collin at toxicfab using it, looks to be in my price range and looks like a really nice welder. With all the different fab work I've ventured into with this car and other things the past year, I have a few tools I really want to purchase for my shop, and try and get my name out there and start doing work for others, something to actually put a little money in my pocket. I'd probably honestly sell my car to get the tools I desire.
10-07-2013, 09:27 AM | #739 |
Member#: 217648
BAIC
That would be pretty cool id like to see some build by you for other people
10-07-2013, 01:48 PM | #740 |
Member#: 185910
Vehicle:2007 FSXT |
Thats pretty ****y customer service from miller if they told you that you would "just have to deal with it". I would have told them thats fine, you can deal with court. See how fast they would have jumped to fix the situation then.
10-07-2013, 08:50 PM | #741 |
Member#: 193189
Got my tig welder back today... finally it works correctly and its QUIET! Im happy now, just glad to get to weld again...
10-08-2013, 01:33 PM | #742 |
Member#: 292161
Vehicle:2015 STI DGM |
Gotta love when things work properly!
10-12-2013, 08:26 PM | #743 |
Member#: 275131
NESIC
Vehicle:2005 WRX (AW) 2007 CBR1000rr Boosted!! |
This is absolutely amazing. Glad to hear your hand is doing well, and I want to see this finished!!!
10-12-2013, 10:34 PM | #744 |
Member#: 185910
Vehicle:2007 FSXT |
glad to hear everything came back fine on the welder and that your hand is doing better. Can't wait to see more project updates!
10-12-2013, 11:18 PM | #745 |
Member#: 193189
Thanks.. still not 100% in my hand... tig welding is still kinda off, like feeding wire isn't steady. Made a mess on some stainless on my downpipe... I hate to admit, but gonna fix it and move on. But yet on aluminum... its actually pretty decent on it now... Welded the entire radiator up with no issues. But I think just the machine acting right has my amperages that i was use to off, (i'm trying to weld too hot now) Im use to having the machine set high b/c it wasn't correct to begin with. Just gotta get use to it again. Also I've had some side work come in so haven't done much to the wrx.
10-13-2013, 02:52 AM | #746 | |
Member#: 185910
Vehicle:2007 FSXT |
10-13-2013, 09:39 AM | #747 |
Member#: 347474
Vehicle:0219 Bug,bug,coup,va mbp,sr,wrb |
keep at it cant wait to see this thing start up an slay some rubber
10-15-2013, 08:28 PM | #748 |
Member#: 193189
Well things aren't looking good for my day job.. The franchise that bought the bowling center that I work for pretty much told our manager that nothing would change, just we would be working for another company and everyone would be hired. Well we had to reapply today, went to the place where we was to fill out an application, and saw new faces filling out applications, so I asked how they knew about the jobs and they said craigslist. But pretty much was told they only have 1 full time mechanic at their other centers and that everyone would be only part time hrs. We have 3 Full time mechanics, me and my buddy have been there a yr and a half, and the other guy 8 yrs, but he was on salary so we did his job basically... maybe did 25hrs a week. Hes pretty much already guaranteed the job. We were all told about a month ago we were getting certified for the machines and that would be a 5 to 8k dollar pay increase over a yr. So I feel like we were all lied too and then finding the their add on craigslist , which states nothing about hiring at a bowling center. So tomorrow is technically my last day of being employed... So yea.... ?? What to do now?
10-15-2013, 09:26 PM | #749 |
Member#: 311562
Vehicle:2002 WRX PSM |
Well that... That's some **** right there...
10-15-2013, 09:28 PM | #750 |
Member#: 311562
Why would they make a Craigslist ad for a job when they already have multiple certified people that can take it without any bother...?
