01-17-2009, 06:56 PM | #1 |
Member#: 107170
Vehicle:2002 ver 7 EJ207 WRX WRB |
Just changed timing belt, water pump, thermostat...overheating now
Just did my timing belt on the 02 WRX, with 110K miles. I changed out the water pump and the thermostat as well. All OEM. I filled up the radiator and had the radiator cap open while the car warms up. Set the heater to full blast. The car started to burp and overflow a bit, coolant level went back down, added some more coolant and repeat. Fan kicks in. Then the coolant began to boil over....I thought it was just the air bubbles working its way up. Eventually, it boiled over about 4-5 times, very messy!!! I saw the temp gauge start to shoot up and shut the car off. I felt the lower radiator hose and it was cold, so coolant was definitely getting circulated.
Is this a stuck thermostat, or a faulty water pump? Mind you the water pump and the thermostat are brand new. Any ideas?
01-17-2009, 09:01 PM | #2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
are you sure you installed the thermostat in the correct orientation? cooling systems are supposed to run under pressure, you can't just have it open like that....
01-17-2009, 11:18 PM | #3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
WTB: Timing belt water pump and oil pump | JasonOJordan | Private 'Wanted' Classifieds | 4 | 09-16-2009 06:37 PM |
What shop around NYC for changing timing belt, water pump and tune-up? | nycsubaruwrx | Tri-State Area Forum | 12 | 10-11-2007 09:02 PM |
Timing belt, Water Pump, Oil Pump, what else? | TheBlackRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 06-11-2006 02:02 AM |
timing belt,water pump question. help | WRC STYL | Service & Maintenance | 0 | 01-09-2003 06:43 PM |
Anybody does timing belt, Water pump job for EJ22 locally? | Dealer Xing | Tri-State Area Forum | 11 | 12-24-2002 11:41 PM |
