03-10-2010, 12:51 AM | #1 |
Member#: 167462
SCIC
Vehicle:2003 wrx sedona red |
camber bolts and already existing alignment
I searched but didn't find an answer.
I auto-x and need more front camber than -1.5* which is what the stock bolts are maxed out as of now. I know many people who run camber bolts up front in the lower mounting holes and I was wondering if I got a set for those holes and got more negative camber (~-2.5) would I need a new alignment to compensate for the camber? Thank you
03-10-2010, 07:13 AM | #2 |
Member#: 37359
Vehicle:2003 WRX |
Yes. Changing the camber will change toe. You'll want toe set back to zero.
03-10-2010, 02:08 PM | #3 |
Member#: 167462
SCIC
Is toe out the only change, because that can be done with ramps and a couple wrenches, not taking my car to an alignment shop? Thanks again
03-10-2010, 02:27 PM | #4 |
Member#: 200288
BAIC
Vehicle:2002 Impreza WRX World Rally Blue |
whenever you change the alignment up front, it affects the alignment in the rear. thats why you start with rear camber (if adjustable) rear toe, then front camber and front toe.
03-10-2010, 02:30 PM | #5 |
Member#: 146186
SCIC
Vehicle:2002 wrx psm |
Okay.
03-10-2010, 03:13 PM | #6 |
Member#: 200288
BAIC
03-10-2010, 03:26 PM | #7 |
Ethon
Member#: 221885
Vehicle:2050 Ivory Tower Ivory...duh |
Putting eccentric bolts in the lower knuckle creates a weak point (thus the other name for these bolts, crash bolts) while the can usually (if properly installed) handle DD duty, auto x will put them under stresses that many have found to be beyond they're design capability. To get to the 2-2.5 range you can either lower the car a bit which will add camber but creates other problems, or you can get some camber plates, they cost a pretty penny but you will feel safe knowing you wont have a catastrophic camber change mid corner when the eccentric bolt in the lower knuckle slips causing you to crash (again, crash bolts)
03-10-2010, 03:35 PM | #8 | |
Member#: 37359
Vehicle:2003 WRX |
I have also slotted the bottom hole of my struts. That's a ghetto way to get more camber. I can get -2.0 with just a little material removed. I'm not sure how much slotting is OK. |
03-10-2010, 03:52 PM | #9 |
Member#: 200288
BAIC
Whiteline com c's will also get you a little extra caster and camber, for a bit more than group n's
03-10-2010, 05:09 PM | #10 | |
Member#: 216135
Vehicle:2011 |
EDIT: I guess if the rear thrust angle was not 0 and a shop did not reset it and instead, messed with the front toe to compensate, then I can see how doing the front alignment first (or only) could not be ideal. Last edited by 09rexwagon; 03-10-2010 at 05:58 PM. |
Similar Threads | ||||
Rubbing, camber bolts, and alignment issue... | Donzo | Brakes, Steering & Suspension | 9 | 11-11-2009 10:16 PM |
Camber bolts, Dspecs on wagon, alignment | Hokie-wrx wagon | Brakes, Steering & Suspension | 9 | 08-27-2008 12:48 PM |
if you use camber bolts AND front camber plates...... | AliBenn | Motorsports | 20 | 08-10-2008 08:39 PM |
WTB: Sway bars, cambers bolts, and top hats | Rando | Private 'Wanted' Classifieds | 12 | 01-13-2004 12:05 AM |
Who's got the best price on the comfort ALK, rear camber bolts, and braided lines? | Schleppy | Brakes, Steering & Suspension | 6 | 07-05-2003 08:47 AM |
