05-06-2003, 07:15 PM | #1 |
Member#: 9624
Vehicle:2002 ImprezaWRXsedan Platinum Silver Metallic |
How did you mount your kick pods?
I've already got em made, but I am not sure what would be a good secure way to mount them to the car.
TIA and pics soon.
05-07-2003, 12:19 AM | #2 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
you can use those backstrap things, if they're already sitting on the floor velcro can probably hold them, but if it's sort of like a side mount either the backstraps or screw it in before you mount the speakers
05-08-2003, 04:39 PM | #3 |
Member#: 9624
Thanks tdxflex, I'm going to try a little silicone or velcro along the ege to keep it lined up and then screw it in to the plastic.
Here are some current pictures: http://gallery.mypearl.us/jakezor |
05-08-2003, 04:54 PM | #4 |
Member#: 13634
NESIC
depending on how heavy it is, you might want to think about using a bolt/nut with big washers. not sure how well the plastic will hold the screw in plate.
05-08-2003, 05:27 PM | #5 |
Member#: 14104
Vehicle:UBER ILikeItLongAndH ardDeepandSmoothEverSoCoo |
Jakezor - nice setup - especially how the rear subs are mounted. Can you tell what you use to make the boxes/enclosure for the subs? mix of fiberglass and wood? got pics of the install?
Thanks! can't wait for the completed pics! |
05-08-2003, 08:00 PM | #6 |
Member#: 9624
Thanks for the compliments guys.
tdxflex, I'll take that into consideration, I also don't want to screw into something important. G-force, I unfortunately did not make them myself. I cut the trunk liner/trim pieces so they could build farther out. They fiber glassed the back, used a 1x2 (or maybe 1x3) to make the middle straight (front to back @ the seam). They just put in a trim ring for the sub and fiber glassed it together. Wood for the ring and for a few support pieces the rest is fiberglass. |
How did you mount your Autometer dash pod? | djoye | Interior & Exterior Modification | 9 | 07-09-2005 06:45 PM |
How did you mount your Auxiliary Lighting? | Psydotek | Electrical & Lighting | 6 | 04-06-2004 12:04 PM |
LM-1 WB (or other any WB), how did you mount yours? | Division By Zero | Engine Management & Tuning | 8 | 03-25-2004 06:37 PM |
How did you mount your HID / Catz Zeta Ballast ? | DEVO-2nd GEN | Interior & Exterior Modification | 9 | 04-20-2001 12:52 AM |
