Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2020
Old 01-03-2020, 05:27 PM   #1
ebrosz
Member#: 510357
2002 Wrx Wagon
Sedona Red
Default Boost oscillation
I'm sure this has been covered but most of the solutions I've found weren't applicable to my situation. So I've owned my 2002 wrx wagon for six or so months now. In the last 4 months it has been getting boost oscillations in 3rd-5th gear at anything over 3500 rpms. And has gotten worse in the last month or so. Here's a list of mods
STI VF39 turbo
STI blue injectors
New intake manifold gaskets
STI intercooler
New hoses throughout (silicone)
Newer 04 wrx transmission
Grimspeed headers
Grimspeed y-pipe
STI up pipe
Hks downpipe
Apexi cat back
Gfb respons hybrid bov
Cobb 3 port EBCS
Aeromotive 340lph
Heat wrapped SPT intake
I've smoke tested and sealed a couple leaks and inspected vac lines. I have a hunch it might be a boost leak but can't find anything obvious. Any help would be greatly appreciated as I've tried a ton of things to no avail
ebrosz is offline   Reply With Quote
Old 01-04-2020, 01:33 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Does the Cobb EBCS require the removal of the restrictor pill from the vacuum line?
supermarkus is offline   Reply With Quote
Old 01-04-2020, 04:40 AM   #3
NutBucket
Member#: 90804
2005 WRX
Have the injectors been removed/replaced? That's where I had leaks on mine. It can hold about 10psi before it leaks and goes s**t. Might want to check it out.
NutBucket is online now   Reply With Quote
Old 01-04-2020, 10:59 AM   #4
Therumblebox
Member#: 477751
Proper tune for the 3 port? I had issues in higher gears with oscillation when I was running a grimmspeed 3 port on a cobb ots tune
Therumblebox is offline   Reply With Quote
Old 01-23-2020, 09:51 PM   #5
ebrosz
Member#: 510357
2002 Wrx Wagon
Sedona Red
I do have a proper tune and this is a fairly recent issue that has developed. It does not have a restrictor pill but it has been that way since I bought the car and hadn't been an issue until recently. And injectors don't appear to have an issue
Old 01-24-2020, 12:01 AM   #6
subaru_gc8
Member#: 29292
2004 WRX wagon
how does it oscillate? its it like a hesitation? I would say first disconnect the wategate and see if it still does it. if iou can do a datalog and capture it so we can see what the ecu is doing
