Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2020
Old 11-27-2004, 02:48 PM   #1
knertified
Member#: 33244
Have a Nice Day? stage 4 vf22 engine cutting out... possible boost leak? UTEC log inside.
This happens generally in 3rd or 4th gear at full throttle. It is not at a certian RPM. Some times its at 18-19psi, sometimes at 15-16psi.. I have a hyperflow V2 TMIC... I think it may be the stock turbo inlet hose which is crap or the intake manifold tube connected to the intercooler. Although I am not positive its a boost leak, possibly fuel? Take a look...
EDIT: Added Columns..
Code:
RPM	MAP(PSI) MAP(V)  TPS%	MLP	KNOCK	A/F	WG	Boost(CL)
4278	19.2	4	98	100	0	  rich	40	250
4312	19.4	4.2	98	100	0	  rich	47	250
4474	19.4	4.1	98	100	0	  rich	42	250
4604	19.8	4.3	98	100	0	  rich	42	250
4444	19.4	3.7	99	100	0	13.8	52	250
4566	18.8	4.3	53	100	0	  rich	45	250
4636	13.1	2.5	0	0	0	  rich	8	ECU.
4456	5.9	2.4	0	0	0	14.6	13	ECU.
4130	-1.2	2.4	0	0	0	  lean	13	ECU.
3866	-7.5	2.3	0	0	0	24.5	14	ECU.
3565	-8.7	2.2	0	0	0	24.5	15	ECU.
3258	-9.1	2.2	0	0	0	24.5	17	ECU.
3106	-9.6	2	0	0	0	24.5	18	ECU.
3055	-9.8	2	0	0	0	  lean	16	ECU.
knertified is offline   Reply With Quote
Old 11-27-2004, 03:22 PM   #2
CMJ
Member#: 39235
Looks like your hitting boost cut. If you have not changed the parameters then it is set to 20psi and you are running very close to that.
CMJ is offline   Reply With Quote
Old 11-28-2004, 09:16 PM   #3
knertified
Member#: 33244
I was thinking it was possibly that but doesnt a CEL flash when that happens? It did before when I didn't have utec and was running a ebc.
Old 11-28-2004, 11:16 PM   #4
CMJ
Member#: 39235
Not always. In this case I'm 99.99% sure that you hit boost cut.
Old 11-29-2004, 12:40 AM   #5
knertified
Member#: 33244
Yeah I think you are right on this.. I will hold off until i get tuned next weekend and still see if i have the problem. The tuner will probally raise it a little and we will see how it goes. Thanks!
Old 11-29-2004, 09:14 AM   #6
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
Look at the line with 4444 rpm - the MAF voltage drops a LOT. if it was a boost leak, the MAF wouldn't drop, as the turbo would be pushing more air (some of it not into the engine). looking at the A/F part going lean (13.8), The air is still there, just not recorded on the MAF. Perhaps a loose wire to the MAF cutting out?
Tom
SlideWRX is offline   Reply With Quote
Old 11-29-2004, 10:17 AM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Flick the FCD on the UTEC hardware itself. This will ensure you never hit ECU generated Boost Fuel cut.
Enable the boost cut in the Open loop fueling menu.
mick_the_ginge is offline   Reply With Quote
AP2 4,500-4,600 RPM Engine cuts out. Jake2006 AccessPort 3 02-12-2007 12:43 PM
UTEC Logs inside -- Aaron'sWRX Engine Management & Tuning 27 06-25-2005 02:01 AM
V7 STI heads on a USDM 2.0 stage 4 vf22. Predictions??? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-20-2004 06:51 PM
I'm getting this bucking below 3k RPM ... Utec log inside! tEkkGOD Engine Management & Tuning 52 06-19-2004 06:05 PM
post stage 4 vf22 dyno results please rjrutzky Proven Power Bragging 25 12-11-2003 08:37 PM
