07-10-2002, 03:32 PM | #1 |
Member#: 14124
Vehicle:2002 WRX Wagon Silver |
Improving the factory boost solenoid - part 2
Okay, after tracking/reading all the posts and comments that followed my original thread on the 3/16" restrictor that leads to the factory solenoid (originally brought to all of our attention by the BoostMonkey folks), I decided to REMOVE my larger 3/16" restrictor and replace it with my original factory restrictor - which is somewhat smaller.
Here is what I noticed upon the change: The responsiveness of the car did diminish somewhat at lower rpms, and my boost gauge indicated probably between .7 and 1 pound less boost. Pulling from 2500 rpm in fourth gear was less dramatic, BUT higher rpm boost stayed around longer, and I got smoother boost performance with less spiking. My car had previously pulled timing due to spikes of around 16-17 psi (no other mods). I now again get that satisfying pull right up through until about 6300 rpm, whereas before it seemed to taper noticeably at 6000 rpm. I did NOT reset my ECU when making this change. I'll leave the factory restrictor in, and drive it for a while to see if the ECU ends up doing something funny. Anybody else have an experience that compares?
07-10-2002, 03:35 PM | #2 |
Member#: 6049
Vehicle:02 WRX & 99 RS Black |
Salt is bad for you...
no its ok you can eat it... NO its bad for you... |
07-16-2002, 12:56 AM | #3 |
Member#: 3474
Vehicle:2013 WRX |
Did you use a 3/16" restrictor or a 3/16" connector. And I thought you already compared both of them about a half hour apart or something two months ago on that other thread and you had nothing but good to say then I believe. What differences did you notice between the two separate tests?
How do you test the Factory Boost Solenoid? | stealthECC | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 02-13-2008 11:24 AM |
What's the GM boost solenoid part # | Henryk | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 09-14-2006 04:32 PM |
does the utec use the factory boost solenoid? | whiterabbit | Engine Management & Tuning | 17 | 03-17-2003 06:40 PM |
Removing the factory boost solenoid | silvercharged | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 08-14-2002 12:28 PM |
Improving the Factory boost guage? | cobra117 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 07-12-2002 06:11 PM |
