Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 06-06-2005, 04:24 AM   #1
spooln04
Member#: 85421
92 EG all mota
Default JDM STI V8 vs. USDM STI V8 tranny
I know the JDM version 8 is geared better but how much better? Will it bolt up to my usdm driveshaft or do you have to do a complete swap with diff and all? Are there any other differences between the two?
Also any thoughts on wear to get jdm version 8 tranny?
Thanks
spooln04 is offline   Reply With Quote
Old 06-06-2005, 11:12 PM   #2
WRXskeet
Member#: 69435
2005 Aspen STi,rip02
Bugeye mafia 02 :(
im pretty sure that 1-4th gears are the same ratio's its 5th and 6th that are a little shorter.
-nate
WRXskeet is offline   Reply With Quote
Old 06-08-2005, 09:56 PM   #3
Antonios Kintos
Member#: 81122
08 STi white
I think Kingpin has them
Antonios Kintos is offline   Reply With Quote
Old 06-09-2005, 07:09 PM   #4
InfamousDX
Member#: 25413
IA performance sells them too. And WRXskeet is on the money with 5-6 being shorter.
Old 06-09-2005, 07:39 PM   #5
zoophageousbeing
Member#: 53072
The conversion sticky in the conversion forum has a listing of places that can get JDM engines. These places should be able to get the trannies as well.
The JDM trannies have steel shift forks, and the USDM ones have aluminum ones. Also, another thing to note is that all USDM six speeds have DCCD, whereas only certain JDM models have DCCD. Most JDM six speeds will have a 3.90 front and a 1:1 center, so you'll have to convert your rear to 3.90. You can use a auto WRX driveshaft or get yours shortened.
zoophageousbeing is offline   Reply With Quote
Old 06-10-2005, 05:35 PM   #6
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
so if i get a non-dccd 6-speed w/complete rear end, then does that mean it is a jdm version? if so is the rear a 3.90?
kharris4 is offline   Reply With Quote
Old 06-10-2005, 07:29 PM   #7
ElJefe
Member#: 32968
2002 WRX 6 Speed MT
'05 Evo GSR, 03 ///M3 SMG
Jdm trannys are made in dccd and non dccd models. If you get a whole STi rear end with the 6 speed make sure that the rear end is a 3.9. I currently have a jdm dccd 6 speed along with a us sti rear end installed on my car, no probs for the past 11k miles.
ElJefe is offline   Reply With Quote
Old 06-10-2005, 08:51 PM   #8
kharris4
Member#: 46018
2003 wrx
i know that it has a 180 rear end.
Old 06-11-2005, 03:25 PM   #9
decodeddiesel
Member#: 64102
05 STi
48W
Can anyone tell me, from experience, the approximate cost for a complete drive line swap to a non-dccd STi 6 speed with the R180 and front brembos? I feel competent I could do the transmission and rear end swap on my own (well maybe with the help of a few burly Army buddies). With that being said, figure labor costs as the price of a 12 pack and a pizza
After reading ebeck's posts on his impressions of the JDM drive line I think it is one of the first things I am going to do.
decodeddiesel is offline   Reply With Quote
Old 06-11-2005, 06:41 PM   #10
kharris4
Member#: 46018
2003 wrx
you might do a search in the private classifieds.
Old 06-12-2005, 02:41 AM   #11
InfamousDX
Member#: 25413
What FD is the USDM STI R180?
Old 06-12-2005, 03:28 AM   #12
majmun
Member#: 18298
2004 STi
3.90 Fd
majmun is offline   Reply With Quote
JDM STi r180 vs. USDM STi r180 (6 speed) garface Transmission (AT/MT) & Driveline 9 03-26-2011 02:38 AM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 04:16 PM
How much lower is JDM V7 spring vs. USDM STi or WRX spring txl146 Brakes, Steering & Suspension 3 12-22-2005 08:19 PM
jdm ver. 8 sti heads vs usdm sti heads Peeblesmx445 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 56 12-17-2005 10:00 PM
JDM Ver 7 Vs. USDM STi cams Surb00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-27-2004 04:46 PM
