04-23-2021, 09:38 PM | #1 |
Member#: 109567
07 STi AVCS delete
Gents, long story short...
Have 07 Sti, with so much trouble getting avcs work. The car drive ok below 5000 rpm no issue at all, never gone above that as I have been troubleshooting why the avcs is stuck at both heads (5 deg driver side, 14 deg passenger side) now feed up and want to delete the whole avcs thing What is the correct way to do it ?
04-23-2021, 10:38 PM | #2 |
Member#: 125887
NWIC
Vehicle:2001 EJ207 V7 RSTi, Mica Blue |
Lock them in place and zero out AVCS timing
04-24-2021, 06:29 AM | #3 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
What have you done to test the function of the solenoids themselves? They can fail over time and your car is getting up there in years. Might just need to swap them out for new ones. Also check those stupid filters for contaminants. The oil lines might not be flowing properly if there's build up in the filters. If they haven't been removed already that is.
04-28-2021, 04:41 AM | #4 |
Member#: 109567
I have done the oil line filter delete, not helped, replaced the solenoids with new ones, didn't help. Then I put new intake cam gears, same results. I'm just fedup with it.
So correct me if wrong for the delete. I need IAG delete kit with non-acvs cams only right? |
