03-02-2005, 02:12 AM | #1 |
Member#: 75686
Vehicle:2002 WRX black |
M2 vs TurboXS vs APS . . . What's the best cheap way to quiet and clean my exhaust?
I currently have a tuned WRX [email protected] and [email protected] running a Helix DP and Borla XR-1 . . . no cats/no resonator. What's the cheapest method of "quieting" my setup? Borla doesn't make a silencer.
I was thinking of replacing the Helix with a catted unit. How much hp should I expect to lose with the typical aftermarket DP? Does anybody make 3" DPs with two cats (including the midpipe)? I'm trying to improve my emissions . . . and reduce the "truckish" sound emanating from my car. VF34, usual package, FMIC, HKS FCON V Pro
03-02-2005, 03:11 AM | #2 |
Member#: 26739
NWIC
if you put a sti can on your exhaust you should quiet it up some and still have a good looking exhaust.
I have a sti catback on my car just because i wanted something that looked a little different, rest of my exhaust is SS headers, catless up pipe, and HKS down pipe. i currently have 279hp at 1.15bar and somewhere around 263tq. So its not like its going to choke out your system. Maybe the Sti can does not flow the BEST out of all the exhausts out there, but if you want somethign a little more quiet, it is a option, and a cheap one at that. |
03-02-2005, 06:05 AM | #3 |
Member#: 42253
Vehicle:2003 RWD WRX Alcohol injected, WRB |
The Borla XR-1 is a large bore straight through racing muffler, it is NOT quiet. The cheapest thing you can do is cut that sucker off and replace it with a street type muffler.
03-02-2005, 07:43 AM | #4 |
Member#: 66558
NESIC
I would also have to go with you getting a different muffler set-up ... That would likely be the best way to quiet down your ride ... As a side note, I've also heard alot about the "Spiral Auger Style Muffler" ... You can go to this site here ... http://www.speedwaymotors.com/default.asp ... Search for part number 91013984 ... (I'd give the direct link but it's too damn long, sorry) I've never used one myself, but I have met a couple guys at local meets that have them, and swear by them ... Hope it helps ... Oh yeah, they are not supposed to rob HP, they quiet you down, and they're cheap too ...
03-02-2005, 09:00 AM | #5 |
Member#: 24660
Vehicle:2005 FXT Black |
Try welding in a round body muffler, like the Magnaflow Magnapacks or the Dynamax race muffler. They are straight through and should not reduce flow at all. They just drop the pressure of the gasses. Put this before your muffler somewhere should help.
03-02-2005, 10:43 AM | #6 |
Member#: 59591
Vehicle:$100 Up/Downpipe Installs PM me!!!!!!!!!!! |
take it off?
03-02-2005, 10:53 AM | #7 |
Member#: 20442
NESIC
Vehicle:2022 WRX Limited WRB |
Another vote for ditching the XR1 muffler. I had one before on my Neon race car, and they're insanely loud. You might as well just be running a straight pipe.
03-02-2005, 11:07 AM | #8 |
Member#: 42979
Vehicle:03 wrx blizzzack stage IV |
i used a dynomax super turbo muffler that was designed for modified RV motors. it 3 inch in and out and recirculates the exhaust through it 3 times and has the airflow charateristics of a strait pipe. i didnt notice any power loss and my car sounds stock again. the only bad thing is that its huge and was hard to fit under there. but was well worth it inth end. i also have a 290whp setup and didnt want to loose any power, just the anoying sound.
03-02-2005, 11:12 AM | #9 | |
Member#: 80664
03-02-2005, 11:18 AM | #10 |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
Buy a dynomax bullet race muffler and have it welded in your midpipe (would effectively be a resonator).
A local did this and it really helped quiet it down and take the edge off. |
03-02-2005, 01:31 PM | #11 | |
Member#: 80664
03-02-2005, 02:04 PM | #12 |
Member#: 60174
Vehicle:2002 wrx MBP |
http://www.kteller.com/store/product...roducts_id/224 I just had one of these welded into my perrin catback it was way to loud with the helix catless dp. It quited it down some but mainly it made it a much mellower not so obnoxious tone.
03-02-2005, 02:49 PM | #13 |
Member#: 1983
RMIC
Vehicle:2008 STi Dark Grey Metallic |
You could consider adding a high flow cat to your downpipe. I have the catless Invidia downpipe and my local tuning shop is going to add a metal dynamics high flow cat to it (the same high flow cat that Cobb uses in their street downpipe and claim it does not affect performance), mostly because I also want to quiet down the car a bit and be environmental as well. It's on order and will probably take a few weeks to install, but I could pm you the results.
03-02-2005, 03:49 PM | #14 |
Member#: 34576
Vehicle:2003 WRX silver |
throw an insulated muffler tip on the end of the Borla. i was running the same can and it was freakin loud!!! put a 3" free flowing cat from flowmaster in line and all it did was smooth out the cylinder impulses while on the highway.
finally i got a 3" input to 4" output insulated exhaust tip...and just like that....it was quiet. when you would really get on it though it got loud again. so it was only bad when you wanted it to be loud!!!! you'll prob have to shorten up the exhaust otherwise the tip may stick out too far....but without seeing your setup i can't say. later, riggs |
03-02-2005, 03:58 PM | #15 |
Member#: 15194
Vehicle:2004 Lightning, 2001 BMW 330ci |
Ditch the setup you have. Why don't you run the Borla hush CB? You could also go Greddy since they use a resonator to quiet things up. Anything that has a resonator or a non-canister muffler will be quieter then your setup.
03-02-2005, 04:01 PM | #16 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
magnaflow has some weld in resonators that will quiet your exhuast down if you want to keep your current setup
03-02-2005, 09:13 PM | #17 |
Member#: 75686
Wow! A lot of good . . . albeit disparate advice. I'm toying with the idea of selling this car but I wanted to make it "legal" and "less loud". I will probably go with a catted DP +/- the Auger Muffler.
03-02-2005, 10:39 PM | #18 | |
Member#: 34723
NWIC
Vehicle:fwd FTL! |
wickedscorpion- the bullet is made from aluminized steel. |
03-03-2005, 04:00 AM | #19 | |
Member#: 48881
South East
Vehicle:2013 Fiat 500 Abarth |
03-03-2005, 11:10 AM | #20 | |
Member#: 80664
03-03-2005, 11:57 AM | #21 |
Member#: 41902
Vehicle:2003 wrx&97 legacygt yellow |
add a hight flow cat will not hurt you much and will quit it up alittle
03-03-2005, 03:07 PM | #22 |
Member#: 75686
What about these pipes from xcceleration?
http://www.xcceleration.com/itemdetails.cfm83.htm Does it make sense to replace the Helix with two catted pipes for $670 and just keep the Borla axelback? Seems like that would clean up my emissions while being much quieter. It's a shame it costs more money to run a clean setup (2 cats = $670) than a dirty one (no cats = $470). |
03-03-2005, 03:31 PM | #23 |
Member#: 62327
VIC
Vehicle:2005 WRB STI [S600BY] |
if I had the money, I'd sell my TBE set up and get the TXS stealthback and add a stock STI axelback
my APEXi GT is considered loud around here.... and I usually travel at mid night.... so there's a few routes and streets that I'm not suppose to take after midnight... or else cops! |
03-03-2005, 03:43 PM | #24 | |
Member#: 1594
2.5" or 3" as well as other diameters... The longer the more sound it will consume I.E. the quieter it will make things. Make sure you've got room for the size you choose however. |
03-05-2005, 12:56 AM | #25 | |
Member#: 48881
South East
[Exhaust ? #69876]What's the best way to go about this? | Krems | Newbies & FAQs | 2 | 03-03-2009 07:18 PM |
What's the best way to get satellite radio in my 03 wrx? | streko | Car Audio, Video & Security | 4 | 06-05-2008 12:04 PM |
What's the best way to insure my mods ? | Okeyd57 | General Community | 21 | 03-10-2007 10:32 PM |
what's the best way to extract a sticker from my bumper? | dingo dave | Interior & Exterior Modification | 15 | 03-18-2004 05:08 PM |
What's the best way to check for exhaust leaks? | wgknestrick | General Community | 5 | 02-20-2003 10:33 PM |
