08-05-2021, 03:58 PM | #351 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
Wow... THIS is toooo coool... My good friend Christy Carlson made this 'Showboard' for my STi.. I am beyond words.. its Laser'd into the wood... This is totally awesome and will help show off my STi at future Events.
08-18-2021, 12:24 PM | #352 |
Subtly Outspoken
4 days to SubieFest Midwest... Here I will show off my work on the STi in the Carshow portion... Can't wait. ..Its going to be epic. Wish me luck
09-05-2021, 05:02 PM | #353 | |
Member#: 90957
SCIC
Vehicle:2016 WRX Crystal White Pearl |
The look of this car is so clean especially with those wheels. I've been waiting to get those but also want to drop weight which those don't do. They do look good though. Thanks for the update. |
09-07-2021, 08:30 AM | #354 |
Member#: 145105
Vehicle:2015 Honda Accord |
Bill - How you doing? Hope you are feeling better. I know you had to miss Subiefest
09-07-2021, 08:26 PM | #355 | ||
Subtly Outspoken
Bill |
09-18-2021, 11:27 PM | #356 |
Subtly Outspoken
Currently negotiating for this Titanium S204 JDM exhaust to continue my JDM theme... Hope it works out.. would lo have on the STi.
09-20-2021, 08:54 PM | #357 |
Subtly Outspoken
Soooooo .... I am thinking about swapping a EJ207 From a Ver 9 STi into the STi. Swapping the engine I understand.... But I have a few Questions:
1. Can it use the USDM Harness to run. 2. I understand if I want to use the Dual AVCS I would have to get the I-Wire harness to make it work. If I get the VER9 ECU for the 207. I understand I would have to have a Open Source Tune... 3. Is it pretty much Plug and Play??? Just something I am kicking around. I know I would have to find a Down Pipe to work with the Twin Scroll. What kind of power will it make with a full tune.. and Larger Injectors with E-85 conversion.??? 4. This goes along with my JDM Theme.. I would keep the original Ej257 just to have.. Thoughts please Bill Last edited by Scooby South; 09-20-2021 at 09:15 PM. |
09-24-2021, 10:30 AM | #358 |
Member#: 526707
Very very nice!
09-24-2021, 02:14 PM | #359 |
Subtly Outspoken
After some Research. I decided to go ahead and pull the trigger on brand new OEM RA shortblock. and OE Gasket kit... to have when and if I need it..Will also be putting on a 12mm STi Oil pump , new OE Water Pump, OE Timing belt kit. Will get the OE Heads redone. I am going to opt for OE Valve train components.. that still utilize the Sodium filled Exhaust valves... will refresh the springs and get everything back to OE Spec, When and if I ever need to . The Ver 8/9 option EJ207 would have been fun... but way to much work to basically give me the same power level that I am at now..so I scrapped that idea for the RA...
More later Bill |
09-25-2021, 10:14 AM | #360 |
Subtly Outspoken
Got some updated interior and engine compartment...ENJOY
09-26-2021, 12:26 PM | #361 |
Subtly Outspoken
Was able to get some new shots of the STi today and enjoy some of the awesome weather we are having..and I got drive the STi...Been a minute PERFECT 70 degree weather .. Enjoy
09-27-2021, 10:35 AM | #362 |
Member#: 122306
Vehicle:2002 Sti PTE 6262 Interlagos Blue 610/580 |
You get to feeling better maybe we can plan an day to get your long block pulled to send the heads off and then another to get the engine together and in.
09-27-2021, 12:00 PM | #363 | |
Subtly Outspoken
Thanks
My Health, as you know, is not the greatest but I am trying to improve that. But if it doesn't work out and I can't enjoy it any longer then it will go up for sale...to hopefully someone that can appreciate all the things i did to the car..and most impportantly.. it's not a CLAPPED OUT POS.. and to get premium dollar for my efforts ... So I know you understand . Bill |
09-27-2021, 06:57 PM | #364 |
Member#: 521869
Vehicle:2015 Sti Limited Silver |
Blob eye best eye, starting to regret my 2015 sti limited lol
09-29-2021, 04:53 PM | #365 | |
Member#: 122306
10-01-2021, 10:44 AM | #366 | |
Subtly Outspoken
10-05-2021, 04:35 PM | #367 |
Member#: 253498
SCIC
Vehicle:02 RSTI MURK'D |
Nice decision on the block. I just grabbed some new heads myself. I've been on the fence about what do with my car as well. I've been torn between building the sleeved block I have or just ordering a short block, but living in CA......I just might stick with a stock engine config. and a modified VF48.
10-06-2021, 06:40 PM | #368 | |
Subtly Outspoken
Understand... since I am not looking for crazy power.. I will be happy with my port and polished, 11 blade billet wheel'd VF48 also.. I am also going to check the ring gap in the RA block just to see what it is set at.. I will probably ensure the ring gap is: 0.0028 or 0.0035 for my liking.. to avoid ring land failure.. not going to push more than the current 21.5 lbs of boost anyways.. that should be plenty for me.. Bill |
10-06-2021, 08:40 PM | #369 |
Member#: 253498
SCIC
All of that sounds like the perfect plan. Looking forward to the results.
10-07-2021, 03:34 PM | #370 |
Member#: 454659
Vehicle:2004 WRX Wagon Java Black Pearl |
10-07-2021, 08:00 PM | #371 | |
Subtly Outspoken
Bill |
10-07-2021, 08:04 PM | #372 |
Member#: 454659
Yep, makes sense. I guess I'll just tape mine off and hope for the best. Lol thanks
10-17-2021, 07:21 PM | #373 |
Subtly Outspoken
Went on a good 100 mile drive yesterday... Love that I don't have to worry about anything as it runs great.. But I did kinda get into it with a boosted Altima, later model.. It hung but the STi was the victor.. anyways.. I am putting together a build list for the RA Block. The plan will be to *EXCHANGE the engine complete, minus Accessories that will be MILDLY built...And put the original engine on a stand to have it.. as a Original Equipment (Numbers matching), an yes I know there are no numbers on it. that way if me or someone wanted to bring the car *completely back to stock, they can..
Proposed build: -12mm STi JDM oilpump -New OE Waterpump -New OE timing Kit...(Belt, tensioner, Idler pulleys.) -Going to try to get some Used STi Heads, and port and polish them with Stock Valvetrain but maybe some 292 BC Cams.. -Change the intake/TGV's to topfeeds, 1400ID should fit the bill.. not going corn so those should be plenty, already have the intake to use for this. -upgrade the Fuel pump over my Walboro 255 that I am currently using. -not cutting the front bumper and car will remain with TMIC... -Coated UEL Headers... -Replace ALL Hoses on Engine with OEM -Killer Bee. oil pickup. baffle and oil pan.. -+1 Sparkin plugs -New coils -OEM Gasket Set -STi Hard inlet pipe - That Should about do it. maybe a 18/20g turbop...We'll see.. than yank out the OE motor and put it on the stand.. That should satisfy my urge for some Power.. What says YOU??? Feasable or nahhh Bill |
10-25-2021, 11:56 PM | #374 |
Member#: 527094
Vehicle:1998 Impreza 2.5rs Maroon |
That's a rad and meant to be kind of story. I wish I could have the same story with a '68 C10 that I used to own. Car is a real subtle beauty!
10-28-2021, 08:42 PM | #375 | |
Subtly Outspoken
In other news, I found a set of 2017 STi limited wheels for a great price. Gonna get them refinished in STi Gold. I think it definitely pop on my STi... What do you think??? |
