Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 09-19-2018, 11:25 PM   #4826
ozborne1031
Member#: 463015
2005 Impreza 2.5RS
Regal Blue Pearl
Originally Posted by neight38 View Post
Suspension specs?
Fortune Auto Coilovers 8k spring rate all around. -3.2 front -1.8 rear
ozborne1031 is offline   Reply With Quote
Old 09-21-2018, 10:51 AM   #4827
LanceKA-T
Member#: 491735
Anyone interest in some forged Prodrive GC-07C's? I'll be post up a set in GTR specs in the for sale section.
18x9.5 +15 5x114.3 all around, 18lbs each.
Could run some nice sized tires on these.
LanceKA-T is offline   Reply With Quote
Old 09-26-2018, 05:29 PM   #4828
c4lvinnn
Member#: 479833
285/30/18 RE71R on 18x9.5 NT03
c4lvinnn is offline   Reply With Quote
Old 10-12-2018, 11:28 PM   #4829
DSTi06
Member#: 370892
2006 STi
295/30/18 on work xd9 18x10 + 18
DSTi06 is offline   Reply With Quote
Old 10-15-2018, 05:49 PM   #4830
kaeknows
Member#: 357191
2016 WRX
ISM
still dialing in the rear, but should be good by this weekend
kaeknows is offline   Reply With Quote
Old 01-07-2019, 12:46 PM   #4831
c4lvinnn
Member#: 479833
285/30/18 RE71R
Old 01-08-2019, 10:49 AM   #4832
Itsdavedubail
Member#: 335906
2002 Forester
Green
I think this is pretty respectable for a forester!
245/40/18
IMG_0760 by Dave DuBail, on Flickr
Itsdavedubail is offline   Reply With Quote
Old 01-09-2019, 09:00 AM   #4833
Zombie Panda
Member#: 425346
295/30-18 Toyo R888R on Advan RGIII 18x10.5
Zombie Panda is offline   Reply With Quote
Old 01-17-2019, 12:54 PM   #4834
Shecker141
Member#: 368756
2005 STI
Originally Posted by c4lvinnn View Post
285/30/18 RE71R
That is beautiful sir.
Shecker141 is offline   Reply With Quote
Old 02-19-2019, 02:26 PM   #4835
oldenoughtoknowbettr
Member#: 497063
2015 WRX
rollover white
love your car the rims & tires look great (i also like the single exhaust & would like to do that to my '15 wrx but this is the wrong thread for that)
tho you live in the wrong neck of the woods if you love mountains
oldenoughtoknowbettr is offline   Reply With Quote
Old 02-19-2019, 02:45 PM   #4836
Member#: 497063
2015 WRX
rollover white
also i can't link pics yet but the blue wagon with sweet white wheels
annnyhoo
getting lots of great ideas from this thread
i want to make my car look like a muscle car but not with chrome mags
with whitewalls , i doubt hoosier makes something but i'm on the low end of the learning curve
Old 03-05-2019, 12:57 AM   #4837
james-30
Member#: 430450
2019 STI
Lapis Blue
2019 sti putting down 430 on flex. I’m going with a 18 9.5 wheel with a 45 offset. I’ve been told a 275/35 tire will work without having to roll my finders or worry abt rubbing. Is this true? I’m stock ride height as of now. I do plan on coil overs but I’m only lowering a little. Probably not even 1” thanks for your reply’s
james-30 is offline   Reply With Quote
Old 03-05-2019, 01:15 AM   #4838
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
Originally Posted by james-30 View Post
2019 sti putting down 430 on flex. Iím going with a 18 9.5 wheel with a 45 offset. Iíve been told a 275/35 tire will work without having to roll my finders or worry abt rubbing. Is this true? Iím stock ride height as of now. I do plan on coil overs but Iím only lowering a little. Probably not even 1Ē thanks for your replyís
The +45mm works nicely on stock struts. Not so much when on coilovers. The coilovers are larger diameter (where it matters for tire clearance) and you will hit them with a 275 +45.
Are you dead set on coils? A set of swift spec r lowering springs and a 18x9.5 +40mm offset wheel with 275 tires is a great setup on the VA.
WRX8XB is offline   Reply With Quote
Old 03-05-2019, 04:44 AM   #4839
james-30
Member#: 430450
2019 STI
Lapis Blue
I mean I could stick with a 265 tire if that’ll work with coil overs and a +45 wheel? No I’m not stuck on coils and would install a quality strut with lowering springs if need be. I’d really like to stick to a +45 wheel if I can.
That being said, if I stay stock struts and springs would a 275 tire on a 9.5 +45 wheel work without modding finders and without rubbing?
Old 03-06-2019, 02:35 PM   #4840
WRX8XB
Member#: 45323
265 +45 is very close to coils up front. It will depend on brand, spring length, alignment etc.
On stock struts and swift spec r the 9.5 +45 and 275 should fit nicely. Inboard isnít an issue and fenders should be clear. Maybe a tiny bit of hammering if it hits at full load and dips.
Old 03-08-2019, 03:45 PM   #4841
james-30
Member#: 430450
2019 STI
Lapis Blue
On stock struts and swift spec r the 9.5 +45 and 275 should fit nicely. Inboard isn’t an issue and fenders should be clear. Maybe a tiny bit of hammering if it hits at full load and dips.
Answer me this guys. If I stayed with factory struts and ran a 275 tire on a +45 wheel would I need to do any modification to clear these fat tires?
Is lowering car a midge with factory setup and 275 tires possible without modifications?
Old 03-08-2019, 04:07 PM   #4842
kaeknows
Member#: 357191
2016 WRX
ISM
Old 03-08-2019, 04:42 PM   #4843
WRX8XB
Member#: 45323
You quoted me answering your question. Lol.
You may need some slight fender work.
Lowering on swift spec r works fine with that size.
Old 03-08-2019, 05:18 PM   #4844
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Yeah, but will you need fender work?
subydude is offline   Reply With Quote
Old 03-08-2019, 08:10 PM   #4845
james-30
Member#: 430450
2019 STI
Lapis Blue
Originally Posted by kaeknows View Post
What is your set up?
Old 03-10-2019, 01:40 AM   #4846
Lancaster
Member#: 476041
2014 WRX
Good ol 275s on Rays 57 SP spec
Lancaster is offline   Reply With Quote
Old 03-10-2019, 03:37 PM   #4847
Endothrow
Member#: 331749
2013 Impreza
Gotta say that I cannot recommend the Falken Pro G4 for cooler climates. Relatively inexpensive but takes a while to warm up during the winter. Has some crashing during the cold morning drive until about 5 miles are covered.
Endothrow is offline   Reply With Quote
Old 03-11-2019, 08:05 PM   #4848
prostcj
Member#: 498052
285/30/18 RE71R
Gorgeous!
prostcj is offline   Reply With Quote
Old 03-12-2019, 12:20 AM   #4849
danividi
Member#: 484789
Are those SA 10-Rs?
danividi is offline   Reply With Quote
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
