Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-01-2017, 03:00 PM   #51
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Really loving the subframe.
Saabaru375 is offline   Reply With Quote
Old 02-02-2017, 05:37 AM   #52
SohcsR4feet
Member#: 455353
I'm loving this so far. If or more likely when I blow my ej25 in my forester I might have to do something along the lines of a ls swap. Especially since it's unheard of in Hawaii.
SohcsR4feet is offline   Reply With Quote
Old 02-02-2017, 06:56 AM   #53
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Lol. It's the way to go after you've been through three motors. Much more cost effective once the motor is in. The hard part it just sourcing everyrhing you want to run. After that and it's in the car it's cheap to maintain. Blow a motor and you can get anot her one ready to drop in for $500 bux. That's a 4.8l or 5.3l that is.
Old 02-02-2017, 04:46 PM   #54
jvsoundwave
Member#: 66060
2007 STI Limited#534
Jet Stream Blue
Sweet!
jvsoundwave is offline   Reply With Quote
Old 02-03-2017, 12:37 AM   #55
SohcsR4feet
Member#: 455353
Yeah that's true. The iron blocks are a dime a dozen and all you need is a cam, springs and head bolts and you can run 800+ to the wheels. If you watch Matt from sloppy mechanics he made 992 wheel hp on a junkyard 6.0 through an auto before he bent 4 of the stock rods and the stock Pistons were fine. Like you said the expensive part is getting everything set up then hoping the 6 speed will handle power
Old 02-03-2017, 06:25 AM   #56
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Precisely! Hopefully the t56 we got will hold up. It's out of a 2007 cts v. Very similar internal components as a z06 trans.
Old 02-08-2017, 01:30 AM   #57
acheung
Member#: 118389
What front/rear axles do you run with these? Do you need custom ones from dss?
acheung is offline   Reply With Quote
Old 02-08-2017, 01:31 AM   #58
acheung
Member#: 118389
Does the r200 mate with the t56?
Old 02-08-2017, 05:42 AM   #59
SohcsR4feet
Member#: 455353
It's not my thread but I will answer these for the op.
No front axles. It's going to be rwd.
It will with a custom driveshaft.
Old 02-08-2017, 06:19 AM   #60
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Yea. I am having custom axles made from DSS. They already have done a few Subarus using this rear frame and differential setup. The driveshaft I'm having custom made here in town. Only thing I have to do is change out the the gear in the differential to get more top speed. Also putting a spool in it as well.
Old 02-09-2017, 12:17 AM   #61
acheung
Member#: 118389
Thanks! Very informative and helpful!
Are the dss axles available on their website? Any reason you don't go through a custom driveshaft with dss too?
Old 02-09-2017, 10:25 PM   #62
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
I'm going through TSSFAB to get the axles from DSS. I could do a driveshaft through them, but I like the idea of having the driveshaft made in town and they will have the car to spec it out perfectly.
Old 02-15-2017, 06:03 AM   #63
SohcsR4feet
Member#: 455353
I'm looking forward to more updates on this.
Old 02-15-2017, 06:18 AM   #64
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Should be soon. Just missing a couple parts to finally put the engine in its home.
Old 02-22-2017, 03:33 PM   #65
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Another day in the office. Anyone know of someone who can do a wire diet on the interior harness. Gutting out all the unnecessary crap.
Old 02-27-2017, 03:14 PM   #66
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
The heart is almost ready.
Old 02-28-2017, 04:12 AM   #67
SohcsR4feet
Member#: 455353
That's a fancy ass bad ass hot side you got going on there. Are you using a twin scroll turbo? I really want to see that fitted in the engine bay.
Old 02-28-2017, 06:20 AM   #68
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Running a Borg Warner S475. It has a divided housing as well.
Old 03-01-2017, 10:05 AM   #69
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Old 03-18-2017, 07:43 AM   #70
SohcsR4feet
Member#: 455353
Now to just put the 2 together. I'm interested to see if using that oil pan will solve the issue with the subframe/steering issue that others have had. Keep us updated!
Old 03-18-2017, 09:37 PM   #71
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
New piece to the puzzle
Old 03-19-2017, 02:25 AM   #72
SohcsR4feet
Member#: 455353
Now that's just too fancy lol. Shoulda just stuck with a ls1 intake manifold but it sure looks pretty.
Old 03-20-2017, 12:42 PM   #73
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
There's nothing wrong with a stock ls1 or ls6 mani but if i was going to stay with stock component's than i could have assed everyrhing else to like use a ls6 cam and valvetrain, truck manifolds, etc....
Old 04-02-2017, 04:26 AM   #74
SohcsR4feet
Member#: 455353
^^^ very true bro. Everything looks awesome! I really want to see the motor mocked in in the car to see how it clears the subframe. If you need more clearance you could always use forester subframe spacers to give you a few more inches.
If you can get it to work with the stock subframe then I might have to find a forester x to put a ls into. Unless I blow up my motor in my fxt sooner then later.
Old 04-23-2017, 02:55 AM   #75
SohcsR4feet
Member#: 455353
So any updates on this bad boy? I'm trying to live my dreams through you but it's hard with no updates!
