Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 05-08-2017, 02:48 PM   #1
Eazy_E_Rich
Member#: 439637
Default SilverFox Twin Turbo H6 GG Impreza
Hello,
I'm hear to share the success of my previous NA EG33 build and to follow up with my current project.
Over the last 2 years I was building my bugeye chassis from basically scrap to a fine performance machine.
BlackKnight
EG33 Swapped 2002 Impreza Outback Sport
MNSubaru build
This Fall when attempting to change out the fuel tank I ended up scrapping the chassis due to major structural rust in the rear end.
Thus I began building my 2006 2.5i to be the next iteration of the project.
SilverFox / EazyOnCars
MegaSquirt Twin Turbo EG33 Swapped 2006 Impreza 2.5i
The goal for this project will be to have a fun Daily Driver that can keep up with other cars on the race track.
Thus far I've swapped in some STI interior parts, did a rear battery relocation, built a fresh EG33, and made preparations to install the EG33 into the impreza.
I have also aquired a MS3X to install, along with 2x Garret T25 turbos.
Thus far the project has been a blast and I'm not going to stop until this thing makes boost.
Check out my youtube channel to get a better look at what I'm doing.
I will continue to post progress I make on this build.
-Eazy
Eazy_E_Rich is offline   Reply With Quote
Old 05-08-2017, 04:27 PM   #2
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Wagon and EG33
Subscribed
Gigs90 is offline   Reply With Quote
Old 05-08-2017, 04:28 PM   #3
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
What is the end goal for the silver wagon ?
Old 05-08-2017, 06:04 PM   #4
Eazy_E_Rich
Member#: 439637
First iteration will be mildly ~400hp.
I really want a stable DD that can keep up on the track.
Old 05-09-2017, 02:21 PM   #5
Eazy_E_Rich
Member#: 439637
Installed the intake, soon this EG will meet the impreza chassis for the first time.
Old 05-10-2017, 09:17 AM   #6
subbi7
Member#: 241967
02 wrx
Which turbos you are going to use?
subbi7 is offline   Reply With Quote
Old 05-10-2017, 05:02 PM   #7
Eazy_E_Rich
Member#: 439637
I'm using Garret T25's from a 2G DSM.
Old 05-17-2017, 08:53 AM   #8
Eazy_E_Rich
Member#: 439637
Default Engine the installation
Old 06-06-2017, 09:03 AM   #9
Eazy_E_Rich
Member#: 439637
Old 06-06-2017, 10:41 AM   #10
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
good videos !
Old 06-06-2017, 03:13 PM   #11
Eazy_E_Rich
Member#: 439637
good videos !
Thanks, it takes a bit of work. Nice to see some subaru love from the 'D'.
Old 06-06-2017, 10:42 PM   #12
jpn6438
Member#: 410917
2005 Impreza RS
might have to re-think my ej207 swap for next year to eg33
jpn6438 is offline   Reply With Quote
Old 06-07-2017, 09:38 AM   #13
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Its way more involved , EJ207 is easy compared to what he is doing.
EG33 is my final power solution if I ever want to go over like 420whp and test my 6mt strength.
But to do it correctly requires things like a Haltech Elite / Link G4 and lots of supporting mods.
Old 06-07-2017, 02:21 PM   #14
Eazy_E_Rich
Member#: 439637
Or like in my case a $400 MegaSquirt3 DIY kit rather than the $2k on a link or Haltech.
That being said if you have the means both the Elite or the G4 will be a much more refined solution.
Old 06-26-2017, 09:43 AM   #15
Eazy_E_Rich
Member#: 439637
Old 08-08-2017, 11:16 AM   #16
Eazy_E_Rich
Member#: 439637
Old 08-09-2017, 01:20 PM   #17
admiral snackbar
Member#: 272810
2010 STI
@digitalseagull
I admit I'm super curious to see it boosted. I love it NA if I"m honest
admiral snackbar is offline   Reply With Quote
Old 09-06-2017, 12:57 AM   #18
Eazy_E_Rich
Member#: 439637
Getting closer to boost. Now running on Megasquirt 3.
Old 09-13-2017, 01:32 PM   #19
HumanBoost
Member#: 440291
Nice job so far. I'm curious to know the following:
1. What pistons, piston rings, and connecting rods are in your eg33 engine and what is the final static compression ratio?
2. Does your motor have any other stronger parts to prepare it for boost like arp head studs, etc?
3. How much boost do you plan to run on 93 octane pump gas?
4. Will you mount the turbo's above or below the engine (for best boost response)?
5. Why did you not go with the EZ30 R engine that has variable valve timing (and valve lift), and the more stout timing chain setup?
6. Does Matt Farah appear smaller or bigger in person?
HumanBoost is offline   Reply With Quote
Old 09-13-2017, 03:14 PM   #20
Eazy_E_Rich
Member#: 439637
10:1 I am Running the stock rotating assembly with freshly polished crank, new rings and moly coated pistons. I know you can change it up with EJ22 parts since the rods and pistons will be the same spec.
Not really, I did do timeserts with the factory headbolts and they are very stout.
Right off the bat I'll be running stock wastegate pressure (9-11lbs) of the T25's. Honestly I would be happy with 5-10PSI start, as I do plan on adding boost control. I will be tuned for 91 octane to start. As I stated earlier I'm looking for around 375hp
I've decided to do low front mount, near the fog lights location. Most of this decision is because turning the headers around is easy and this makes the hot side around 1 foot total length. As has been done several times I plan to rotate the intake 180 degrees. Not decided on the intercooler setup yet. I may look at water-to-air.
Cost mostly, the EG33 cost me like $200 original investment. Besides that I really like the EG33, it's a beast of a motor. Look up Andy Forrest, he is running an EG33 making like 1200hp with low boost, I've yet to see anyone build an EZ based engine doing anything close to that. (Though I've seen the MCM guys have a spare EZ36 on an engine stand which makes me wonder if they will do forged internals). Also the EG33 is non-interference, so even if the timing belt were to break, all I have to do is put another one on.
lol, he's a pretty big dude. Though he has been slimming down quite a bit from what I hear. He's a pretty cool dude, making the video you could tell it's his job, which occasionally takes away the fun parts of it.
Old 09-13-2017, 04:38 PM   #21
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
The MCM guys have a spare EZ36 on hand probably because the car has suffered engine failure multiple times
Old 09-13-2017, 05:16 PM   #22
Eazy_E_Rich
Member#: 439637
Interesting. I'd like to know more / what the failure was.
It's funny that my original build gets compared to Supergramps a bit and I understand why. I hadn't heard of MCM until just after I purchased the EG33 but I really loved the gramps build. I've got a much lower budget than MCM and no turbo yoda to weld or do my wiring, but I think I'll have a pretty sick ride once this thing makes boost.
Old 10-20-2017, 10:08 AM   #23
Eazy_E_Rich
Member#: 439637
Default Coils 'n' Stuff
New Coil setup, new injectors, slight amount of tuning.
Old 10-20-2017, 11:37 AM   #24
bspencer
Member#: 434432
nice build.
bspencer is offline   Reply With Quote
Old 10-20-2017, 08:09 PM   #25
mazdan
Member#: 322018
This is great. Makes me want to build one too. Keep it up.
mazdan is offline   Reply With Quote
