Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 03-13-2018, 09:34 AM   #51
Eazy_E_Rich
Member#: 439637
Eazy_E_Rich is offline   Reply With Quote
Old 03-13-2018, 12:37 PM   #52
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
That manifold looks pretty nice
I would have the injectors flow tested for sure
iirc there are oem Denso sidefeeds that are like 700cc that people have ran on these in the past but most just do a topfeed conversion.
Gigs90 is offline   Reply With Quote
Old 03-13-2018, 06:56 PM   #53
Eazy_E_Rich
Member#: 439637
I should send them out for testing, that would be the way to know for sure.
Old 03-15-2018, 09:32 AM   #54
Eazy_E_Rich
Member#: 439637
Default Scavenge Pump
Old 03-30-2018, 11:28 AM   #55
Eazy_E_Rich
Member#: 439637
Old 04-12-2018, 10:54 AM   #56
Eazy_E_Rich
Member#: 439637
Old 04-13-2018, 09:55 AM   #57
Eazy_E_Rich
Member#: 439637
Default EG33 Charge pipes
Been welding up my charge pipes. Making them from 16ga mild steel because I had a bunch of it, and can only do MIG currently.
Video on this probably this weekend or early next week.
-Eazy
Old 04-13-2018, 11:07 AM   #58
Eazy_E_Rich
Member#: 439637
Old 04-13-2018, 11:12 AM   #59
jjbtexas
Member#: 229546
10 STI
Looks awesome. Are you going to have a removable radiator support? What's your plan for the hood latch now?
Removable radiator support: 15m 32s*
*stupid auto youtube video input won't let me set the time in the link...
jjbtexas is offline   Reply With Quote
Old 04-13-2018, 11:17 AM   #60
Eazy_E_Rich
Member#: 439637
Removable radiator support: 15m 32s* https://youtu.be/fYaqMIpbkxA?t=15m32s
Just watched that video when it came out, that dude Mike? has some great fabrication skills, not to mention turbo yoda.
I've been running hood pins since I did the original engine swap, which I'm totally fine with.
The radiator and support are removable, but I'll have to remove the charge pipes to get it out.
Old 04-25-2018, 09:47 AM   #61
Eazy_E_Rich
Member#: 439637
Old 06-01-2018, 11:18 PM   #62
Eazy_E_Rich
Member#: 439637
Old 06-06-2018, 10:34 PM   #63
Eazy_E_Rich
Member#: 439637
Here's the latest progress, cold side pipes complete.
Looks like I'll be making at least the start of a full exhaust before I get it fired up. Stay tuned...
Eazy
Old 06-11-2018, 09:39 AM   #64
Eazy_E_Rich
Member#: 439637
Old 06-13-2018, 11:38 AM   #65
Eazy_E_Rich
Member#: 439637
Default Twin Turbo update
I wound up making custom downpipes because the hater pipes were going to be an issue for three reasons:
  1. Outside Air could easily get to my O2 sensor, throwing off my tune.
  2. I would have to scrap the hater pipes completely to go full exhaust
  3. 2G DSM O2 housing would not allow for full exhaust
These mandrel bends are not sharp enough to get it back under the car with the factory 2G DSM housing.
My solution was to start making the full exhaust and leave it just short enough to start the car and possibly drive it.
So I started with this ^
Around lunchtime I had this ^
Mounted up with O2 sensor in.
Sneaking out under the car. I will probably run it like this for a bit. I want to see how cool it sounds
Here are both mostly finished pipes pre-paint.
That's a sneak peak for a future episode. I posted the latest video today one post up if you've not seen it.
-Eazy
Old 06-25-2018, 12:35 AM   #66
Eazy_E_Rich
Member#: 439637
Old 06-28-2018, 08:09 AM   #67
Eazy_E_Rich
Member#: 439637
Old 07-01-2018, 04:58 AM   #68
unicarscooby
Member#: 487817
Originally Posted by Eazy_E_Rich View Post
I'm using Garret T25's from a 2G DSM.
How you gonna feed the turbos with oil and water since the eg33 is na?
unicarscooby is offline   Reply With Quote
Old 07-01-2018, 08:59 AM   #69
Eazy_E_Rich
Member#: 439637
Oil filter sandwich adapter with a additional fitting. I used the coolant path for the throttle body. Working great.
Old 07-02-2018, 03:34 PM   #70
TDagen
Member#: 163648
2002 Resurrected WRX
Downpipes turned out really good.
TDagen is offline   Reply With Quote
Old 08-08-2018, 10:16 PM   #71
Eazy_E_Rich
Member#: 439637
Old 09-17-2018, 11:59 PM   #72
Eazy_E_Rich
Member#: 439637
Old 09-18-2018, 12:44 AM   #73
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Really cool man, love it.
D-Rodman is offline   Reply With Quote
Old 09-27-2018, 12:38 AM   #74
Eazy_E_Rich
Member#: 439637
Old 10-07-2018, 08:24 PM   #75
Eazy_E_Rich
Member#: 439637
