Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 04-30-2018, 01:36 PM   #1
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Default Arktikpenguin's Big Turbo Bugeye Build
Hello! I am Tom, and I have been a member of the Subaru community for 3 years now! This site has always been my home, providing plenty of info to help me when I was a noobie, and still helping me even today. I normally lurk, and don't post much other than some sale threads and my recent PPB thread. Recently I happened upon a CCA position with the USPS, and I can finally provide enough content to start a build thread, whereas before I only got new parts every month or so, which seemed boring to me.
Anyhow, I'll be including my current build, all future plans, and everything in between as I build my dream car into my own image.
Some info on my car:
I purchased my PSM '02 WRX on May 22nd, 2015, with an Autometer Boost Gauge, Injen SRI, Spec-D Catback, Gimmick Turbo Inlet, and some beat up spray painted Primax 618 wheels. Everything else was stock! She had 211k miles, original trans with 211k miles, and a newer EJ205 with around 65k miles. It had ugly red and black pinstriping which was immediately buffed off, and the car received a full buff and polish!
Present day pictures:
My goal is to create a car that I can drive daily, but also take to a track and whomp on it with the tune turned down. The close ratio of the v7 transmission should help with the track goal, and also help keep it fun on the street, even with such a big turbo. I'm hoping to get the car down to around 2900lbs with interior intact, and full on fluids. With me that'll put the car around 3125lbs give or take lol. My hope with this build is to build and tune the car exactly how I want it, and to learn a LOT along the way. I have a good grasp on tuning and building a subaru, but there is still much more to learn through hands on experience, and trial and error. While some months may go slow with this build, I do not plan on selling or stopping. Hopefully it turns out the way I envision it, and hopefully you enjoy the thread!
Revamped Future Plans:
Engine/Exhaust/Intake/Cooling:
- BuiltEJ Closed Deck Block
- JE FSR Hybrid 8.5:1 Pistons w/ Coated Skirts and Crowns
- Wiseco Boostline Rods
- King Pmaxkote Rod and Main Bearings
- Stock STi Crank (new)
- S20 Ported Heads w/ Supertech Dual Valve Springs, GSC Valves, Seals and Guides
- BC 272 Camshafts
- IAG Cooper Ring Head Gaskets
- IAG 1/2" Head Studs
- 11mm Oil Pump
- Killer B Ultimate Oil Kit
- OEM Timing Kit
- Mishimoto Oil Cooler Kit
- Mishimoto Radiator, Shroud, Fans, Stays
- 2 Nipple Water Pump for Oil Cooler Delete
- IAG Billet Half Moon Seals
- NA Long Runner Manifold
- Boomba 75mm Throttle Body
- Treadstone 900hp Black Intercooler w/ rotated piping
- Borg Warner S369SXE w/ .91 T4 Divide Housing
- SP Quick Spool Valve
- Rocksteady Tuning Rotated T4 4" Marmon Flange Kit
- 1320 Performance EL Header
- HKS Racing 3.35" Catback Exhaust w/ Titanium Tip
- VSRacing 44mm EWG
- VSRacing 50mm BOV
- AEM IAT Sensor
- AEM 5bar MAP Sensor
- iWire Sensor Adapter Harnesses
- IAG AOS
- 4" Aluminum Velocity Stack
- Chasebays ABS Delete + Brake Line Tuck
- Chasebays BBE Kit
- Chasebays Power Steering Kit
- Chasebays Clutch Line
- Chasebays Windshield Washer Reservoir
Fueling:
-ID2000 Injectors
-Radium Dual Fuel Pump Hanger
-2x Walbro 485s
- -8AN Fuel Feed lines
- -6AN Fuel Return Lines
- IAG Fuel Rail Kit w/ -6AN Fuel Lines
- Aeromotive 1000 FPR
- Radium Engine Bay Fuel Filter (Sits on Radium Master Cylinder Brace)
Drivetrain:
- v7 JDM STi Drivetrain (Brembos, Driveshaft, Axles, R180, Hubs, LCA, Shifter)
- TIC v7 STI swap Shift Kit
- ACT XT 6 Puck Sprung Disc
- ACT XT Pressure Plate
- ACT Streetlite Flywheel
- Fortune Auto 500 Coilovers w/ 7K Front/5K Rear
- Aluminati Motor and Trans Mounts
- TSS Front, Trans, and Rear Tube Crossmembers
- Whiteline 24mm Front and Rear Sway Bars
- BuiltEJ Front and Rear Spherical Endlinks
- Whiteline LCA Bushings
- Whiteline Rack Bushings
- Whiteline Bump Steer Kit
- Everything in the Drivetrain will have Whiteline Bushings.
Interior/Safety/Driving Shiz:
- Sparco P310 Steering Wheel
- NRG Quick Release and Short Hub
- Cusco Bolt-In 7 Point Full Passenger Around-Dash Cage
- Braum Harness Bar
- Braum 5 Point Harness
- Braum Elite Series Blue Reclinable Seats
Engine Management:
- Link G4+ Plugin V7-9 WRX ECU
- Carberry Tuned Stock ECU for inspection and emissions lol
Wheels/Tires:
Rota Titan 17x9 et42 5x100 in Speed Bronze <--- Street and Track Wheel
Federal 595RSRR 255/40/17 <---- Street Tire to start
Mickey Thompson 275/40/17 Street S/S <---- Street and Track Tire
Rota Slipstream 17x8 et48 5x100 in Bronze <---- Drag Wheel
Hoosier 28x10x17 Drag Slick <---- Drag Tire
ARKTiKPENGUiN is offline   Reply With Quote
Old 04-30-2018, 01:58 PM   #2
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
So currently sitting, I'm running a fairly safe tune @22.5psi on 93 octane making roughly 370whp/330wtq. I will be trying out e85 and bumping up to 24psi once I get my id1300x injectors and hopefully I'll make 420-440whp. I'll be swapping over to a rotated setup w/ the Borg Warner S369SX-E over the summer, grabbing the full sti swap, and then building the engine/heads over the winter while having it painted.
My "goal" is 600whp, which won't be difficult at all with the planned setup but I'm sure I'll encounter some headaches during the build. I am getting a killer deal on my turbo and piping setup, plus I love huge turbos. Lag is a nonfactor to me. I have an FP Green on my 2L and I get around town and pass people just fine now, with a 2.5 I'll have a good bottom end bump and that will be more than enough. I will be doing some track days, and some drag racing. I don't expect much in the way of 1/4 mile times with the short ratio of a JDM 6 speed but I'm not chasing times, I just want to have fun!
Things should get interesting very soon, stay tuned for next week!
Old 05-06-2018, 01:06 PM   #3
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Id1300x injectors are on their way, and I will be throwing some e85 in with my fp green to see how it does! Wish my 5 speed luck!
Old 05-06-2018, 03:07 PM   #4
TDagen
Member#: 163648
2002 Resurrected WRX
Sounds like fun!! E85
Be easy on the 5mt to make it last.
TDagen is offline   Reply With Quote
Old 05-06-2018, 03:30 PM   #5
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Im fairly gentle! Even with 22.5psi on my fp green every day it hasnt skipped a beat! Im quite surprised for the mileage it has on it
Old 05-12-2018, 08:14 AM   #6
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Got my id1300x in! Didnt even know you could pull the silver cap off to reveal which model of x injector it is, so now I know! Once I get some time off work I can get these suckers in and retune it, then make the switch to corn!
Old 05-12-2018, 10:46 AM   #7
Madmax6688
Member#: 484432
Good luck with your build bud, Just completed a full bugeye build
Madmax6688 is offline   Reply With Quote
Old 05-12-2018, 06:30 PM   #8
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Thank you! I plan on getting my v7 sti drivetrain transplant next, but I may grab the clutch and super shifter set first. Might also grab a DSS aluminum 1 piece driveshaft to go along with the setup. We shall see!
Old 05-12-2018, 10:50 PM   #9
TDagen
Member#: 163648
Just throwing this out there you may already know but figure it doesn't hurt just in case, the clutch, shifter and driveshaft from the 5 speed and 6 speed aren't interchangeable, so if you get ones for the 5mt you will have to swap to 6mt stuff when you do the v7 swap.
The 5mt clutch will work in the 6mt if you have a 5mt flywheel and possibly some other variables, but I have made the 5mt clutch work before with an 07 6mt. Anyway I am rambling on but wanted to throw that out there in case you were gonna get 5mt parts.
Old 05-13-2018, 06:02 AM   #10
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Yep, I know they arent interchangeable. I was just gonna have the shifter set driveshaft and clutch waiting for when i do the 6 speed.
Old 05-13-2018, 08:36 AM   #11
TDagen
Member#: 163648
I figured you knew. Now I see you said "to go along with the setup" I must have been reading through a little fast lol.
The v7 6mt with those taller tires should kick some serious ass too.
Old 05-13-2018, 01:00 PM   #12
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Hell yeah, and with a slightly higher rev limit I should atleast hit 60 in 2nd. On my 5mt I see 72 on the dash, so around 69-70 real world lol
Old 05-14-2018, 07:41 AM   #13
TDagen
Member#: 163648
2nd at 8000rpm is 67 mph with 26" tires and jdm 6mt gearing. 64mph @ 8000rpm with 25" tires. 60mph @ 7500rpm with 25" tires. You can figure out different setups with this gearing calculator.
http://www.apexgarage.com/tech/gear_ratios.shtml
Old 05-15-2018, 05:40 AM   #14
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
I totally needed that in my life! Thanks a lot man!
Old 05-21-2018, 10:08 AM   #15
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Got my new o ring set and tossed the id1300s in today. Threw the base tune on and she fired right up. These run much smoother than my five o injectors, probably due to having actual data for tuning and not doing a guesstimate.
All in all, i should have gone id1300s right away. ID are very good and the install was about 20x easier than my five o injectors.
Old 08-14-2018, 02:49 PM   #16
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Never updated this, but I ended up bending a rod while out testing spark cut launch control. My plans have changed a bit and I'll update the parts I'll be going with when I have some time. For now, she's at my brother's body shop being torn apart for a full repaint. Fixing all the dents, removing rust properly, and rolling the front and rears properly as well. New paint code will be 86f, which is Blue Steel Mica off of the 1999-2000 gc8.
After she's painted she'll be going into storage until next Spring. I'll be amassing parts and the built engine, and we will go from there.
Old 12-19-2018, 08:05 PM   #17
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Its been a while, but I've got some updates. Car is apart for paint, found some rot in my front fenders and also got the quarters cut out and welded with new subie savers panels. Engine bay is being painted as well as the radiator support. My new front bumper has been trimmed around the fog bezels, license plate holder shaved, and the prodrive + limited lips moulded to the bumper and smoothed out.
Engine has been pulled and disassembled, and I figured out what broke! With my **** luck, a shim broke off of a bucket and took that cam out with it but no other damage has been taken. If anyone wants a cheap 2.0 shortblock with the oil and water pumps still attached with some **** heads to use for cores they are for sale!
I also received a ton of parts! In this time I've amassed the following:
- JDM STi HID Headlights w/ ballasts
- Lightwerkz Harness
- ej257 Shortblock
- s20 heads ported with supertech beehive springs and retainers/guides/seats
- JDM STi Foglight covers painted 86f
- Sparco P 310 Steering Wheel
- NRG Short Hub
- NRG Short Quick Release
- Redlinegoods medium gray w/ grabber blue stitch solid leather shift boot + e brake boot + extended armrest cover
- Torque Solutions Pitch Mount
I know it doesn't seem like much but Im also paying off paint and body work at the same time! I plan to finish paint and body wotk in January, then Ill have the block and heads sent out to be drilled for 1/2" studs and closed decked by outfront. Afterwards we will see what comes!
Also, happy holidays to any readers!
Old 12-19-2018, 09:12 PM   #18
TDagen
Member#: 163648
Doing stuff the right way! Good work. If you don't your new paint will look like crap fast. Looking forward to more updates on that front.
Looks like a nice list of goodies! I bet those ported heads are gonna come in handy.
Old 12-19-2018, 10:47 PM   #19
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Quick picture of the fog covers in the new color! Definitely in love with it.
Old 02-28-2019, 04:47 PM   #20
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Quick update! Going to bullet point to make things easier to read:
-New front bumper molded, license plate holder shaved, shaved vents, shaved foglight holes, and shaved for a Treadstone 900hp FMIC to fit
-Old quarters chopped, wheel wells cleaned up and patched, new quarters welded in and primed.
-New OEM Fenders came in, primed up.
-New Rear Passenger Door Hinges
-POR15 Metal Prep + Gray RPC on it's way for the engine bay and rad support
-NRG Short Hub, V2 Quick Release, and Sparco P310 installed. Amazing fitment and feels great.
-S20 Ported Heads torn down, porting verified, shimless buckets found, Supertech Dual Valve Springs w/ Titanium Retainers found.
-Acquired new BC272 Camshafts, GSC Intake + Exhaust Valves, GSC Valve Guides, Supertech Valve Seals.
Up next is more body work, primer, and paint! I can't wait! Also going to be prepping the engine bay and brushing on the POR15 Gray RPC, and also removing the AC, ABS Pump, Brake Booster, and other such things.
Stay tuned!
Old 03-08-2019, 01:17 PM   #21
jaidmaster
Member#: 213446
PSM, Forged Hybrid, GT35R
Always good to see a bugeye being taken care of.
jaidmaster is offline   Reply With Quote
Old 03-08-2019, 02:16 PM   #22
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
I'm enjoying taking care of her and making things right haha
Progress pictures!
Head build parts:
New wheel! Messy interior lol
New fenders
Primed up
Patched and primed quarter, other side looks the same lol
Cleaned and degreased the engine bay, moved a bunch of stuff so I can start the engine bay painting this weekend!
Old 03-08-2019, 02:57 PM   #23
TDagen
Member#: 163648
Looking good!!
I like the wheel.
Old 03-14-2019, 02:34 PM   #24
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Bit of bad but also good news. I degreased and metal prepped the bay, went to brush on the POR15 and of course it's fisheyeing. I take prepall and wipe down the entire bay, still fisheyeing!! We sand down part of the rad support and it still fisheyes! So either my POR15 is contaminated, or my brushes are contaminated. We said screw that and are gonna actual spray and clear the engine bay then. My brothers made a custom color that I have not seen yet, but they said I will like. I'll post pictures once it's finished in a few days!
More good news is my new OEM 05 WRX rear bumper has shown up, along with new mounting brackets. Once we get the fenders rolled it's finally ready for finishing body work and being painted. I'm definitely excited to get this finished!
Old 03-19-2019, 02:17 PM   #25
ARKTiKPENGUiN
Member#: 421347
2002 Impreza WRX
Got the engine bay all scuffed down and cleaned again. My brother opted to seal it off, base coat it and lay some clear. Color is B39 (Mineral Grey Metallic, BMW Color) with some Subaru silver added in. I love the way it looks and should contrast well with my exterior!
Don't mind the ugliness under the battery, we aren't too worried about it after neutralizing and sealing it.
