06-22-2017, 12:12 AM | #251 | |
Member#: 300583
Vehicle:2002 WRX Hybrid WRB (for now!) |
06-22-2017, 12:35 PM | #252 |
Member#: 135252
Vehicle:2002 WRX Wagon |
Is there a thread somewhere with instructions for getting good night shots of beam patterns and cutoffs?
06-22-2017, 04:35 PM | #253 | |
Member#: 127099
BAIC
Vehicle:02 IMPERZA WRX BLACK |
06-22-2017, 05:07 PM | #254 |
Member#: 416655
Vehicle:2008 STI |
Hey man, it cost 125 for the eBay headlight housings, and 375 for the projector kit. Fits only on bugeye, the bulbs are 5500 if I remember correctly. The labor to retrofit the eBay headlights is no easy task, and the headlights were only on my car for 6 months before I got rid of the car. You can see the date I completed the retrofit within this thread, but I say 6 months because I finished the retrofit last summer and took the car to school. At school it was hardly driven and garage kept. The aiming could be adjusted slightly, but the adjusters all work fine so that shouldn't be an issue. The reason I got the eBay headlights is because the adjusters broke in the process of retrofitting and I couldn't aim the headlights properly. Make an offer based upon that, been asking 500 since that was the cost of the parts, they are practically brand new, if cleaned the lenses look brand new, and the labor is a bitch..
Last edited by kayfunlite; 06-22-2017 at 05:11 PM. Reason: clear up some possible confusion |
06-22-2017, 06:15 PM | #255 |
Member#: 135252
Do you have output shots?
06-24-2017, 06:29 PM | #256 |
Member#: 416655
Vehicle:2008 STI |
06-25-2017, 01:59 AM | #257 |
Member#: 135252
07-25-2017, 08:50 AM | #258 |
Member#: 451412
International
Vehicle:2001 Impreza WRX Bug Black |
Pics are broken. Any chances the pics can be reuploaded? Maybe to imgur? Or do anyone know if this thread exists anywhere else with working pics?
09-17-2017, 10:11 AM | #259 |
Member#: 466600
Pics from the original post are no longer there. Do you think you could post a link to the images?
12-16-2017, 12:28 PM | #260 |
Member#: 174060
Vehicle:2002 WRX PSM |
I am wanting to do this. Car is in repair sitting in the garage on blocks, so the opportunity is here. I have a question: What did you all do about the OEM DRLs for the retrofit to HIDs?
12-17-2017, 11:45 AM | #261 |
Member#: 135252
12-18-2017, 08:47 PM | #262 |
Member#: 174060
Thanks
07-09-2018, 04:46 AM | #263 |
Member#: 457162
wiring changes model year
Were there any changes in any of the headlight wiring from 02 to 03? Random
07-19-2018, 03:41 PM | #264 |
Member#: 135252
How much does a completed bugeye retrofit usually cost around here?
08-05-2018, 08:44 PM | #265 |
Member#: 487728
Vehicle:2003 Wrx Wrb |
Halfway lit high beam indicator
I believe that just means your fog lights are on. Try turning them off and see if the lights go away
08-05-2018, 08:48 PM | #266 |
Member#: 487728
Sorry
01-03-2019, 02:57 PM | #267 |
Member#: 482022
Vehicle:2014 Impreza WRX White |
How to mount shroud
Hate to revive an old thread.
I'm in the middle of the retrofit and I am using the ocular shrouds, but I don't have any way to mount the shroud to the projector. It sits on top of it but I have no way of connecting them. Anyone else have this issue? What is supposed to connect the shroud to the projector? |
01-03-2019, 03:03 PM | #268 | |
Member#: 14851
Vehicle:2002 WRX Wagon buh buh buh...Blick |
02-18-2019, 12:18 PM | #269 |
Member#: 124118
Vehicle:2008 FSXT 5sp DGM |
All -
So sorry about the pics in the post. I put in a lot of work to this how-to and I feel like ppl were benefiting from it, but alas, photobucket went full moron. To be honest, I don't have the original photos anymore, and photobucket wanted some ridiculous amount to retrieve photos. It's a crime, really. I have since switched over to imgur, but I can't really do much about this post. If you PM me, I can answer questions directly, but I don't really check the thread often. |
02-18-2019, 12:28 PM | #270 | |
Member#: 124118
I retract my previous statement. Photobucket has actually updated their site and users can retrieve their photos for free. AllI did was to reclaim my account and the pictures were restored. Hope this thread continues to help retrofitters! |
05-01-2019, 04:45 PM | #271 |
Member#: 482022
So I've been running my retrofit with this exact setup and I only have 1 issue now. My DRLs on my bugeye do not function as they used to with the stock headlights. They used to toggle between the DRLs and the low beams, but now my low beam and DRLs will be on together and I'd like to retain the old functionality of toggling.
To be more specific, when I turn my headlight stalk to the off position but am driving around town, I would like my DRLs on but my low beams off. When I manually turn my headlights on, I would like my DRLs to turn off. Does anybody know how to accomplish this? Here's a pic of my car, and thanks for any and all help. |
05-04-2019, 11:56 AM | #272 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
Another: Same thing on the "power" side, but use the low beam as the "signal source", with a relay that has an "always closed" pin. When ignition is on but low beams are off, the circuit is closed (i.e. DRL gets power). When ignition is on and low beams are on, the circuit is open (i.e. DRL doesn't get power). In this case, it doesn't matter what the DRL circuit does, so you can either revert the DRL resistor and controller per OE or not. |
05-04-2019, 12:03 PM | #273 | |
Member#: 482022
04-06-2020, 07:54 AM | #274 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
DIY: Bugeye HID Projector Retrofit (Morimoto Mini H1 4.1) - Minimal Modifications
I did my first Morimoto projector retrofit in 2013, I sold that wagon. I find myself in the middle of a Morimoto projector installation now that I own a bugeye again. Started yesterday and ran into a problem right away when started testing projector fitment. The new projector threads stripped wile reversing the nut out. They unthread properly one or two threads and they begin to cross thread. I managed to damage both projectors that way. Now I’m waiting to hear from Lightwerkz to see if There is any recourse, I’m beyond frustrated.
04-06-2020, 07:18 PM | #275 |
Member#: 110078
Lightwerkz answered my email quickly, politely and took care of the situation promptly. That is real customer service, those guys earned my business exclusively from here on.
anyone install MORIMOTO MINI H1 4.1 in their bug eye housings? | hella_sti | Electrical & Lighting | 12 | 06-19-2012 02:18 PM |
Installed My Morimoto Mini H1 Projectors | Ryguy32789 | Electrical & Lighting | 37 | 01-15-2012 10:45 AM |
FS SOCAL: 04-05 HID Projector Retrofits & JDM HID fog retrofits | BiggSean | Exterior/Styling | 6 | 10-13-2009 08:32 PM |
hid projector retrofit into bugeye | scarsofterror | Interior & Exterior Modification | 27 | 01-05-2007 02:49 PM |
HID Projector retrofit | CalcVictim | Interior & Exterior Modification | 2 | 03-08-2005 09:53 AM |
