View Poll Results: So what goes into your tank? | |||
I use straight HOSE WATER | 13 | 52.00% | |
I buy gallons upon gallons of DISTILLED WATER | 4 | 16.00% | |
I use a HOSE WATER and ALCOHOL SOLUTION | 0 | 0% | |
I use a HOSE WATER and CLR (or something similar) | 0 | 0% | |
I use HOSE WATER and run CLR through it every month or as needed | 0 | 0% | |
I use WASHER FLUID | 4 | 16.00% | |
I use SOMETHING DIFFERENT (please explain) | 4 | 16.00% | |
Voters: 25. You may not vote on this poll |
10-28-2003, 12:37 PM | #1 |
Member#: 36468
Vehicle:2003 Wrx 4EAT Hard Water WRB |
What Solution do you use in your IC sprayer!?
I know this has been dealt with before and i've done a search. I just installed a Spec C tank last night with the Quantum racing kit and love it!. i just want to know what you're using for spray.
Distilled Water can be a PITA when you have to re-fill every 3-4 days and can get quite expensive and look somewhat weird when you're buying 10gallons of it every week I don't want the grocery bagger to think im some tighta$$ that only drinks sunnyselect distilled water or has some distilled water fetish. Anyway, first off tell me what you're using....then tell me in how many parts like a ratio. If you're using something differnt post that too. BTW: anyone know how to distill water at home... enough to make 12L a week??? Thanks, eric
10-28-2003, 12:50 PM | #2 |
Member#: 18071
Vehicle:2005 STi |
Hose water...
10-28-2003, 01:39 PM | #3 |
Member#: 12841
SCIC
The water in my area is too hard and left deposits on my IC after the first 12l.
Another member directed me to Walmart 59¢/gal distilled water. I buy about 15 gallons at a time every month. I end up drinking one gallon when I'm too lazy to change the water filter and another for general cleaning. I guess I go through 12l (3 gal) every week/week and a half depending on how hard I drive - I'm using an Autospeed intellegent IC spray controller instead of a manual switch. |
10-28-2003, 03:21 PM | #4 |
Member#: 4507
Vehicle:05 STI Aspen White- No wing |
50/50 distilled water and high-grade methanol (I work in a research university and get it through lab stores).
10-28-2003, 03:24 PM | #5 |
Member#: 4507
Misread the original post. This is what I use in my water injection. I don't have an IC sprayer.
10-28-2003, 05:55 PM | #6 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
If you use tap water, the dissolved solids will eventually clog your nozzles. If they are plastic, they will have to be replaced.
If your tap water is very hard, you may be replacing nozzles at about the same interval as putting gas in your car.... |
10-28-2003, 05:58 PM | #7 | |
Member#: 36468
I figure seeing how i have hard water i'll add a cup of CLR in the Mix everytime and stir it up |
10-28-2003, 06:20 PM | #8 | |
Member#: 16200
...but I guess you will find this out the hard way... Might want to read the label on the CLR container REAL close.... |
10-28-2003, 06:27 PM | #9 |
Member#: 22290
TXIC
Vehicle:2002 STI Ver 9 Spec C Wagon |
I travel to Antarctica to get the purist glacial ice one can find and then I thaw it on the way back and dump it in my washer-fluid reservoir. If it's inconvenient to drive down there when the reservoir is empty, I just use the water hose.
10-28-2003, 06:28 PM | #10 |
Member#: 46128
Vehicle:04 Evo Black - 11.1 @ 131.05 |
I believe most people use distilled water, whether you like it or not ... oh wait looked at the poll and most use plain water, but beware of deposits.
10-28-2003, 06:39 PM | #11 |
Member#: 18928
South East
Vehicle:2002 jdm wrx v7/v8 inter/w Spec C roof vent |
Can you please take some photos of your spec C tank setup..
Im going to buy that tank,but I wanna see what is involved and how it comes together.. Please |
10-28-2003, 07:20 PM | #12 | |
Member#: 36468
eric |
10-28-2003, 08:14 PM | #13 |
Member#: 12841
SCIC
Here's a pic from my install.
10-28-2003, 08:20 PM | #14 |
Member#: 20904
Vehicle:2012 CT200h I miss my bugeye |
I use RO water (Reverse Osmosis). I bought and installed a 5 stage RO unit from Premiere Water Systems (found at Costco and Sam's club at about $150). It's just $35 every 6 months for new filters. Also, I connected my frige icemaker to it and get great tasting ice and water (for cooking, drinking, etc).
10-28-2003, 08:29 PM | #15 | |
Member#: 18928
South East
How have you got it wired to activate.The manual sti switch or other?? |
10-28-2003, 08:42 PM | #16 | |
Member#: 16200
'Planning' on using the wrong water scource and then trying to fix it later with something like CLR is not the way to do it. Either buy bottled distilled water or buy and use a system like tk_1971 describes or you will have problems. What part of this don't you understand? |
10-28-2003, 08:50 PM | #17 |
Member#: 12344
Vehicle:2002 2JC blue |
Distilled water from Walmart. About 50 cents an gallon.
Blue washer fluid from Walmart. About a dollar a gallon. Vary ratio from 100 water to 100 winter formulation washer fluid on local freezing sequence. The freezing point depression of the washer fluid is due to methanol (methyl alcohol or wood alcohol). You can use isopropanol (rubbing alcohol) but it is not quite as effective as methanol. I use about 1 to 1 water/washer fluid right about now in Maryland. The system has 12 fine misting nozzles and they did fine on the distilled water in the summer. I don't have enough data on the washer fluid yet. So far, so good. |
10-28-2003, 08:57 PM | #18 | |
Member#: 12841
SCIC
http://www.autospeed.com/cms/article.html?&A=0534 It works exactly as advertised. |
10-28-2003, 09:12 PM | #19 |
Member#: 38071
Vehicle:2003 WRX Silver |
I use the water out of my dehumidifier..I have been using it for 8 months with no problems...(and its free)
10-28-2003, 09:24 PM | #20 | |
Member#: 18958
BAIC
Vehicle:13 TDI pollutr Black as my heart |
thats an AWESOME IDEA!!!! anyone have any insight on this? I have one of those things that we just dump the nasty water out of...considering its been in everyones lungs and such. |
10-28-2003, 09:24 PM | #21 | |
Member#: 16200
10-28-2003, 10:07 PM | #22 |
Member#: 38071
I believe it is distilled water.. I fill up gallon jugs and use cheese cloth to filter anything that might have got in there.....
10-28-2003, 10:17 PM | #23 |
Vendor
Member#: 12347
SCIC
Vehicle:ECU ReProgramming Dynapack AWD Dyno |
I always liked CH4O injection
Chris I-Speed USA cescamilla@i-speedusa |
10-28-2003, 10:37 PM | #24 | |
Member#: 16200
10-28-2003, 10:39 PM | #25 | |
Member#: 16200
What engine oil do you use in your subies Sacramento? | MAJRMSA | Bay Area Impreza Club Forum -- BAIC | 1 | 12-03-2005 07:01 PM |
What fluid do you use in your rear differential? | Bobert540 | Transmission (AT/MT) & Driveline | 1 | 10-10-2005 03:26 PM |
What octane do you use in your stock 2.5 engine? | Geoffman72 | Normally Aspirated Powertrain | 54 | 08-04-2004 10:04 PM |
What cleaners do you use on your interior? | MF-DIF | Interior & Exterior Modification | 29 | 07-09-2004 07:42 AM |
What suspension do you use in your rally car? Looking for PGT setup for an Impreza L. | Sean | Motorsports | 43 | 08-08-2002 08:32 PM |
