Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 02-09-2003, 04:12 PM   #1
Yellow03Wrx
Scooby Scammer- Do Not Buy From User
Member#: 32204
03 WRX
Yellow
Default Question about Utec install!
I just installed the boost controller that came with the Utec should I have an extra tube to the old boost controller that came with the car sitting in the engine bay?? Or do I remove that, or did I do something wrong! Should I be turning the boost up this the Allen key or will the Utec does that??
I also have no idea how to mount the boost controller con someone please helps me out!!
Yellow03Wrx is offline   Reply With Quote
Old 02-09-2003, 04:35 PM   #2
jjunior887
Member#: 16738
2015 WRX Limited
CWP
You did something wrong, you shouldn't have any hoses flopping around freely. It sounds like you removed the T instead of the black restrictor. The only one you should need to tie out of the way is the ABC(bleed valve that came with the UTEC). The only thing you remove is the black restrictor in the line to the factory Boost Contoller(this is not a "T" it's just a straight through piece), that's where you put the ABC inline. I'm pretty sure you use the metal plate with the holes in it to mount it under the plastic cover where you're factory BC is. It comes with a tie wrap to strap the ABC to it then you just use one of the existing bolts back there to mount the plate. You should be able to figure it out once you get in there. The UTEC manual has pictures of it installed too.
jjunior887 is offline   Reply With Quote
Old 02-09-2003, 05:03 PM   #3
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Here's the piece that comes out
Old 02-09-2003, 07:35 PM   #4
Yellow03Wrx
Member#: 32204
03 WRX
Yellow
I fixed the proglem, but It now feels like I have lost power I am only getting .05 on my boost Gauge
Old 02-09-2003, 07:48 PM   #5
jjunior887
Member#: 16738
2015 WRX Limited
CWP
could be a few things, make sure you are running open loop boost control in the paramters if you're just running the base map(#'s in the 80's and 90's on the boost map). You might need to open the ABC a bit, maybe a turn or two, shouldn't need much more than that. I would say three at the most. -James
Old 02-10-2003, 09:44 AM   #6
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
I had to turn mine 4 times counterclockwise to get it to 0.11 MPa.
T-WRX is offline   Reply With Quote
Question about utec Hey_wrx Mid West Subaru Owners Club Forum -- MWSOC 8 02-06-2016 12:40 PM
question about UTEC map switch install David Medina UTEC 6 02-13-2006 03:48 PM
questions about newly installed UTEC m4r10 Engine Management & Tuning 7 06-29-2005 12:31 AM
question about utec Yellow03Wrx Engine Management & Tuning 4 02-21-2003 07:10 PM
Questions about UTEC and tuning ability MadWagon Engine Management & Tuning 8 12-14-2002 01:50 AM
