Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 06-26-2003, 12:37 AM   #1
BritSti
Member#: 38057
2010 IS-F
USB
Default Need 12v switched, close to mini fuse box in 04 WRX
Edit: Moved to Electrical forum
http://forums.nasioc.com/forums/show...hreadid=382743
Looking for the right wire to tap for 12v switched power close to the mini fuse box on the drivers side in an 04 WRX Sti, using for a radar detector, I'm trying to stay away from using a fuse tap for power....
Done a few searches and ended up confused on the different years with different colored wires.
Thanks.
BritSti is offline   Reply With Quote
Old 06-26-2003, 05:07 AM   #2
ldivinag
Member#: 13533
04 sti
black???
you can tap off OEM stereo harness:
#10 slot is a YG (yellow-green???) wire that is switched 12 volts.
make sure to verify this before cutting or using a 3m tap...
see the last post here:
http://www.scoobymods.com/forums/sho...harness+wiring
ldivinag is offline   Reply With Quote
Old 06-27-2003, 02:00 PM   #3
fueledbymetal
Member#: 14425
2002 WRX Sedan
SOLD!
Actually, I've read in this forum in the FAQ & Threads of Note that there are some differences in the pre '02 cars and the post '02 cars. Here's a link to the post '02 stock HU wiring harness - I'm guessing that the color codes will be identical to that of the stock STI.
On a related note, I too am looking for a source of 12V power signal for an amp install on a friend's WRX with the stock HU. Can I just tap into the #10 wire in the linked diagram?
fueledbymetal is offline   Reply With Quote
Old 06-30-2003, 02:35 AM   #4
ldivinag
Member#: 13533
04 sti
black???
i wouldnt use that to power an amp.
... wait what did you mean for an amp install?
12v + accessory wire out of fuse box OUScooby Newbies & FAQs 1 02-06-2010 02:31 PM
where can i get those empty switch covers over the fuse box?? bnr34rb26dett Interior & Exterior Modification 5 11-19-2008 12:36 PM
Need 12V+ switched power in engine bay, ideas? bboy Electrical & Lighting 3 06-07-2005 09:29 PM
Securing sub box in 04 WRX? phenemwrx Car Audio, Video & Security 8 03-29-2004 12:33 PM
Need 12v switched on 04 WRX close to fusebox BritSti Electrical & Lighting 0 06-26-2003 12:41 AM
