Welcome to the North American Subaru Impreza Owners Club Monday April 19, 2021
Old 12-28-2011, 06:18 AM   #1
insane_one
Member#: 301431
2005 Evolution VIII
Post How to DIY: Independent Foglight Mod
There are afew detailed write ups out there and just like my DRL How to thread i wanted to make with a bunch of pictures that made sense on how to actually do this. So here it goes....
First, i followed all directions straight from scoobymods.com. Although i did have to make an account just to view the attatchments (inconveint).
Last, I am not responsible for anything you do to your car.
This works for sure on 2004-2005 WRX. May work on other years as well. Try at your own risk!
Independent Foglights? WHY?
Why? because i think it looks cool. Other than having complete control of your foglights to be on when ever you want, thats the only reason i have for taking the time to do this.
To OEM Spec, Foglights will only be on when the low beams are on. So if you highbeam flash someone, your fogs shut off. They shut off to comply with the law, no more than 4 forward facing driving lights to be on at once. If you have HID foglights, its bad for them to shut off and turn back on like that.
There are many different ways to achieve having independent foglights but this one specifically is imo pretty simple and easy. With doing this your foglights will turn on when you want them to. With your park lights, low beams, and stay on when you turn on your highbeams. Not only that, your foglight button indicator light will also be on when ever your foglights are on.
Remove panel by removing the 3 circled screws. After the screws have been removed, gently pull the panel back toward you and it should just pop out.
Here we see the Fuse box and relays.
Looking closer, we want to remove the fuse box by removing 1 10mm bolt at the top and releasing the clips on the side.
After that i recommend disconnecting the 2 blue plugs on the fuse box to give you more room to bring down the box like so
^^ with using needle nose pliers, release the 3 clips holding the relays in place
now looking on the other side and we see a RED with GREEN stripe wire connected to the 3rd relay from the bottom
CUT IT. The side that goes to the relay, we use. The side that part of the rest of the harness, we dont use.
Leave the cut wire alone for a bit and go back to the fuse box. Unplug the center plug from the fuse box and locate a solid orange wire.
insane_one is offline   Reply With Quote
Old 12-28-2011, 06:21 AM   #2
insane_one
Member#: 301431
2005 Evolution VIII
Using wires and these connecters to make everything work.
using this connecter we are going to "tap" into the orange wire. NOT CUT OR DISCONNECT IT. And have a new wire go to the RED & GREEN wire from the relay box
now to make the indicator light turn on on your foglight switch anytime your foglights are on, follow these steps
from the grey plug that connects to the foglight switch we want to locate the RED & GREEN wire and the YELLOW & BLUE wire
the RED & GREEN wire connects to our "NEW Wire" ( the one thats connected to the Orange Fuse box wire and Red & Green Relay wire)
the YELLOW & BLUE wire connects to a ground. I Already had another switch that went to a ground so i taped into that
a good ground spot would be the bolts holding the hood release lever
in the end it should all look like this
do a quick test and put it all back together.
Old 12-28-2011, 06:22 AM   #3
insane_one
Member#: 301431
2005 Evolution VIII
Old 12-28-2011, 06:34 AM   #4
Handsdown
Member#: 29355
[peeks head out from under rock... wonders, "is moment of self-realisation upon us?"]
[nope. chuck testa. sees nasioc users are still living up to their usernames and high member numbers. groundhog sees shadow, goes back into his cave for six more weeks of winter, or years off the board]
[insult to injury: hid foglights, because it looks cool]
Handsdown is offline   Reply With Quote
Old 12-28-2011, 09:38 AM   #5
RSXNTN
Member#: 287358
2006 2.5i
Regal Blue Pearl
Why waste your time ****ting on this guy?? Do you really have nothing better to do? If you dont care about what he's writing about simply move on.
Awesome right up, will be doing it soon. Just ordered the blazer fogs from TRS and dont want to kill my ballast/bulbs.
RSXNTN is offline   Reply With Quote
Old 12-28-2011, 02:09 PM   #6
insane_one
Member#: 301431
2005 Evolution VIII
Handsdown- sorry this wasnt your cup of tea. Move on to the next thread made by a "newbie" and bash on them
Hey glad i helped someone. Post pics when you get it all done!
Old 12-29-2011, 01:28 AM   #7
05GDF
Member#: 281488
2005 STi
Nice write up bruh!! Keep up the good work!!!
05GDF is offline   Reply With Quote
Old 12-29-2011, 04:15 AM   #8
insane_one
Member#: 301431
2005 Evolution VIII
Thanks! Hope this helps out
Old 12-31-2011, 08:39 PM   #9
phenryiv1
Member#: 91212
2011 WRX 5DR
Starting through this thread I was all 6-to-midnight. Then I saw that it was not for an 08+ and went back from midnight-to-6.
I knew somethis was amiss when there was mention of the plug to the foglight switch, which on the GR is in the stalk.
I just want to find the indicator-light-actually-works-with-the-foglight-mod-mod for the GR...
phenryiv1 is offline   Reply With Quote
Old 12-31-2011, 09:06 PM   #10
kh15
Member#: 132400
2006 WRX
nice write up! thanks!
kh15 is offline   Reply With Quote
Old 01-03-2012, 11:40 PM   #11
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
There was an older thread on here where the guy ran a line from a fuse, it looked kinda sketchy so I opted out of that method, saw a write up similar to this on scoobymods and now tomorrow I will be following your write up. I too should be getting HID fogs, they are the blazer fogs so it wont be blidning to traffic and with the 3000k HIDs I should have a nice deep yellow.
Great write up!
One quick question, you mention they are on for everything from no headlights to high beams. But do they still turn off when the vehicle is off? I don't want to find myself going to work only to come out to a dead battery cause driving Subaru for 4 years has taught me my lights shut off when the car turns off.
subaru_steve is offline   Reply With Quote
Old 01-04-2012, 12:18 AM   #12
insane_one
Member#: 301431
2005 Evolution VIII
yes doing this mod they will still shut off when the car is off even if the button is ON. glad my write up was helpful!
Old 01-04-2012, 04:48 PM   #13
T-Wills
Member#: 290813
2011 WRX Limited
any idea if this would be the same for a 2011??
T-Wills is offline   Reply With Quote
Old 01-04-2012, 05:26 PM   #14
insane_one
Member#: 301431
2005 Evolution VIII
Sorry guys , to my knowledge this will ONLY WORK ON 02-07 wrx. Actually even 07's might be a tad different
Old 01-04-2012, 09:24 PM   #15
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Awesome writeup! Ill havento give this a shot.
mechatricity is offline   Reply With Quote
Old 01-06-2012, 10:21 PM   #16
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
I would be VERY interested to know if somebody with an 06 wrx has done this as I was JUST going to post and ask about doing this to my 06 wrx.
I have found that being able to toggle the fogs at will is a great thing in snow and fog.....and having the extra 'wide angle' light on dark nights in the boonies on narrow, winding, 2 lane back roads is great for helping avoid **** like deer
I am REALLY happy with the Osram 65w Rallye H7 and Phillips(GEN3) 9011HIR combination for the 06-07 wrx....
Quite shocking, really.....the new GEN3 HIR's are just ...they throw some LIGHT
Old 01-06-2012, 10:41 PM   #17
kh15
Member#: 132400
2006 WRX
I plan on doing this on my 06 tomorrow....hopefully the wires colors match up! I will keep you posted!
Old 01-07-2012, 02:56 AM   #18
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Just did this tonight, I have been working on my car for 3 days straight now...
- HID Projectors
- Hella Supertones
- Yellow Tinted Fog Lights
Just to name a few
Its 2:30a and I finally finished everything, including this mod which took about 10 min.
Not the best picture but you get the idea...
Old 01-07-2012, 02:24 PM   #19
kh15
Member#: 132400
2006 WRX
works perfect on 2006 wrx models! all the wires are the same color and its very easy! took my about an hour but thats because i have to solder and heat shrink everything or else i cant fall asleep at night.
Old 01-07-2012, 03:18 PM   #20
insane_one
Member#: 301431
2005 Evolution VIII
Hey there ya go. Sweet!
Old 01-08-2012, 11:04 PM   #21
Uncle Scotty
OK buy Nates beans
w000000000000000000000000t
So that's that....now I just gotta find time to do it
And I have a BernzOmatic butane torch that has a neat soldering tip that is perfect for these kinds of wiring jobs.....it is one of the neat little tools that everybody should have.
It works great for stuck/frozen bolts and nuts because you can spot heat them and then spray them with penetrant while they are hot and cooling which REALLY helps wick the penetrant into where it can work....one of my 'tricks'.
Old 01-09-2012, 09:33 AM   #22
kh15
Member#: 132400
2006 WRX
always wanted to know how well those bernzomatic soldering things worked...might have to pick one up now!
Old 01-09-2012, 10:53 AM   #23
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Nice write-up, Insane. I might be getting in touch with you to do this soon since I plan on installing Blazers to replace the stock fogs.
Old 01-09-2012, 05:03 PM   #24
kh15
Member#: 132400
2006 WRX
more info on the blazer set up? I've been hearing more and more about them!
Old 01-10-2012, 10:33 AM   #25
phenryiv1
Member#: 91212
2011 WRX 5DR
This thread has my impressions of the Blazers as fog lights. You have to search through the thread because it got a little off of the topic im places, but near the end of the first page I get into my actual impressions of their performance.
http://forums.nasioc.com/forums/show....php?t=2272901
How to DIY: DRL Disable insane_one Electrical & Lighting 28 09-14-2020 12:18 AM
Independent Foglight Mod writeup for the BE Guys MitchGT Legacy Forum 5 04-29-2005 12:20 AM
how to change the foglight bulb Grey Ghost Electrical & Lighting 12 04-27-2005 10:25 PM
how to aim my foglights? legacy2003 Electrical & Lighting 2 09-24-2004 09:14 AM
How to aim stock foglights? ShutUpGeek Electrical & Lighting 2 01-11-2004 07:20 PM
