Welcome to the North American Subaru Impreza Owners Club Saturday May 24, 2025
Old 01-02-2009, 10:06 PM   #1
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Default Does the inside of your windshield freeze?
Every time I go out to my car after work on a cold day I have the joy of scraping ice off the inside of the windshield. I leave the vents closed and HVAC setting pointed away from the windshield but that doesn't help. Anybody have a solution for this?
iyzmi is offline   Reply With Quote
Old 01-02-2009, 10:12 PM   #2
stiluv2xl8
Member#: 167027
02 WRX Sedan
stiluv2xl8 is offline   Reply With Quote
Old 01-02-2009, 10:17 PM   #3
2.5GTLegacy
Member#: 111219
Windows down?
2.5GTLegacy is offline   Reply With Quote
Old 01-02-2009, 10:25 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Move to CA? I don't have that problem
Audiosavvy is offline   Reply With Quote
Old 01-02-2009, 10:31 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Mine hasn't but my moms outback does sometimes when it's really cold out.
Old 01-02-2009, 10:49 PM   #6
knockknockknock
Member#: 150915
2007 wrx tr
smurf blue
If you have high humidity in the car when it is warm. Then when you park it in the cold, and it cools down. You will get frost on the inside of the windows. Most common is your carpets being wet, from rain/slush/snow tracked in by your feet.
knockknockknock is offline   Reply With Quote
Old 01-02-2009, 10:56 PM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
It happened to my mom's outback too.
The air inside must warm up and create condensation then instantly freeze.
I wonder if it would be a good idea to bring those hand warmer packets to hold against the window.
Smoke is offline   Reply With Quote
Old 01-02-2009, 11:38 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
id put a dessicant of some sort inside the car and open the vent off of 'recirc'
the above is one of the most hilarious things ive heard in a LONG time!!!11
Old 01-03-2009, 01:06 AM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
AC on (or either defrost setting which forces on AC above 32F). Don't sit in the car after it's off. Breathing adds humidity. Don't set the adjust to recirculate either. The main key is to minimize internal humidity.
Old 01-03-2009, 01:57 AM   #10
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Wait, you're saying to keep it on the windshield defrost setting and to let the outside air in? That's the exact opposite of what I've been doing, I'll give it a try though.
Old 01-03-2009, 02:21 AM   #11
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Yep.
Run the A/C and set to defrost with Recirc off. I.E out side air open.
Leave it like that when you turn car off.
That will fix your problem.
Badmunky is offline   Reply With Quote
Old 01-03-2009, 02:27 AM   #12
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Whenever I forget to close the vents and aim away from windshield, and I leave the recirc off and set to defrost mode, I come back to my car to find the same problem... I'll try it some more times though, maybe it'll start working for some reason.
Old 01-03-2009, 12:13 PM   #13
SeriousInquiry
Member#: 185189
Yes, every morning i wake up to f'in frost on the INSIDE of my windshield. You have to leave the windows slightly down, just a crack, and you'll be fine.
SeriousInquiry is offline   Reply With Quote
Old 01-03-2009, 09:13 PM   #14
Bluefoton
Member#: 141373
2022 Crosstrek Sport
6MT
check the carpets under the footrests. It might be a symptom of a completely soaked carpet.. either from a leak, or from melting snow from your boots.
In my old escort, this was the cause of the inside frost. Every spring I would have to lift the driver carpet up as much as I could and dry it over 2 days with the sun, heater, hairdryer, and whatever else I could find. All of that till I realized my rubber mat had a hole in it, allowing a river of melted boot slush to leak onto the upholstery.
Old 01-03-2009, 09:29 PM   #15
sconniescoob
Member#: 161488
2002 '14 CRV
Yes, that is exactly what you need to do (and, what I believe, your manual suggests too). Driving around with recirculate, you keep adding moisture to the interior every time you exhale, so the moisture/humidity builds up. That moisture freezes at night (for those of us who actually get cold). You can crack your windows, or let the air in from the outside...remember, cold air is much, much dryer than hot.
sconniescoob is offline   Reply With Quote
Old 01-03-2009, 09:54 PM   #16
911-3.2
Member#: 71421
2005 Sold - WRX
Salty Gray Metallic
Thumbs up
That's exactly what caused my truck to frost up on the inside recently.
911-3.2 is offline   Reply With Quote
Old 01-03-2009, 09:59 PM   #17
DC16A2
Member#: 174357
2002 OBS
+1. That's why your lips crack in winter, and not the summer.
DC16A2 is offline   Reply With Quote
Old 01-03-2009, 10:19 PM   #18
bullworm562
Member#: 166091
1998 Outback Limited
Green
my outback does the same thing sometimes
bullworm562 is offline   Reply With Quote
Old 01-03-2009, 10:48 PM   #19
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
cycle the a/c on defrost, and make sure your drawing in outside air.
Mavrik is offline   Reply With Quote
What does the inside of an oem WRX muffler look like? cfvwtuner Member's Car Gallery 177 09-15-2013 10:21 PM
So what does the front of your car look like after you removed your FMIC? disque71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-25-2006 09:43 AM
How did you paint the inside of your 04-05 headlights edaniele1212 Interior & Exterior Modification 2 03-19-2005 07:42 PM
Ever Wanted to see the inside of your brake booster? Legacy777 Brakes, Steering & Suspension 14 12-06-2004 09:39 AM
Cleaning the inside of your windows zzyzx Interior & Exterior Modification 26 08-28-2001 11:29 PM
