Welcome to the North American Subaru Impreza Owners Club Thursday May 22, 2025
Old 02-11-2025, 08:27 PM   #1
hunterc05
Member#: 539372
Subaru Banner 2004 Subaru impreza wrx E85 conversion
Hello, I got into looking at doing an E85 conversion on my 04 subi. But im having a hard time trying to figure out what I would need. I see E85 conversion kits but im not sure what ALL I will need. I saw a post from awhile ago that I would only need bigger injectors and a tune but I highly doubt that. I am just curious if anyone can help me and explain and tell me what I need to do to swap my wrx to E85
hunterc05 is offline   Reply With Quote
Old 02-12-2025, 09:04 AM   #2
Laddder
Member#: 540251
I'd ensure that you'd upgrade your fuel pump and injectors. Even if the kit has all you need theres some things that you'd want to upgrade because it's worth it/supports it so well
Fuel lines doing okay, my 04 has fuel leaks, and tank doing okay?
Laddder is offline   Reply With Quote
Old 02-12-2025, 04:39 PM   #3
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
To run on E85, you need a larger volume of fuel. Injectors, fuel pump, fuel line. You also need to be tuned to run it. It is possible to build your own sensor controller to sense how much E85 is in the fuel and adjust tuning to the level. But you do need to understand the whole system to do this and I don't see that you do with the questions posed.
E85 isn't magic that you pour in your tank and become one to dominate all. Even if you overnight fuel from Japan. You need an integrated system. If you don't want to do that, just buy a car with more power.
Old 03-29-2025, 12:57 AM   #4
wrx43v3r
Member#: 331119
I have a 2004 WRX with E85. I had it done less than 10 years ago. The install was done by a popular/reputable tuner (the business no longer does tuning).
Tuning was achieved using CarBerry ROM - you will need a 2002 or 2003 ECU to use CarBerry ROM.
We used the Delicious Tuning flex fuel kit (it's pretty cool - they offer an app to monitor E85 levels). Like others have said, you will need to upgrade fuel delivery parts (I also went with rails).
Why don't you go to your local tuner and discuss everything you'll need (it's definitely possible to do it)?
wrx43v3r is offline   Reply With Quote
