Welcome to the North American Subaru Impreza Owners Club Wednesday May 21, 2025
Old 12-09-2005, 06:56 PM   #1
skoobidoo
Member#: 91159
2005 WRX Wagon
Default Fuel smell while heater is on.
Im not sure if this is the right forum for this thread but I figured it would be the closest. If not, feel free to move it to the correct one
My wifes '02 WRX has a bad fuel smell when she turns on the heater after the car has been in the cold (never when it has been in the garage). I know this means the hose has contracted causing the clamps on the fuel hoses to become loose. My question is:
Is there a specific fuel hose/clamp that is notorious for becoming loose causing a fuel leak? I find it sort of odd that it is only noticable while the heater is on.
I have poked around and checked for loose hoses/clamps and visible signs of fuel but I cant find any. The smell does seem to be coming from the passenger side of the intercooler though, near the turbo.
Any thoughts?
Thanks in advance
Mike
skoobidoo is offline   Reply With Quote
Old 12-09-2005, 07:06 PM   #2
Mulder
Trust no one
Member#: 11170
13 Mini MT
15 WRX/11 CRZ
Known issue on the 02s, read here-
http://forums.nasioc.com/forums/showthread.php?t=131755
You smell it while the heater is on because the vent fan is running and drawing in outside air, since the fresh air intake is at the base of the windshield it will pick up any fuel vapors from inside the engine compartment.
Old 12-09-2005, 07:09 PM   #3
rewt
Member#: 60794
2007 Solstice GXP
Search much
From what I've read, the smell comes from fuel lines under the intake manifold on the passenger side of the motor. Supposedly, the line transitions from hard line to a soft line (clamped of course), and when the temperature gets low enough, the hard line contracts more than the soft line.
I've heard you can see this line when looking in between the intake manifold runners where your turbo inlet is...
Might want to also search this forum (there's a sticky about this at the top) and the Maintenance forum, too.
rewt is offline   Reply With Quote
Old 12-09-2005, 07:17 PM   #4
skoobidoo
Member#: 91159
2005 WRX Wagon
Originally Posted by rewt
Search much
Awesome, thank you for the help guys! I actaully did search, but I searched on the wrong forum, LOL. Shoulda known to come here first
Thanks again, I appreciate the help
Mike
Old 12-09-2005, 07:28 PM   #5
subeforlife2002
Member#: 100667
2002 WRX stage 4
Yeah I just had the same problem the other night when it got very cold. I was leaking fuel and I checked it out...The leak was coming from the fuel line under the driver side intake manifold. Where it goes from hard to soft. I did get a turn or two out of he clamp and I'm all fixed now.
subeforlife2002 is offline   Reply With Quote
Old 12-09-2005, 07:55 PM   #6
pityr
Member#: 31719
Take it to the dealer and have them replace it if you have the extened warrantee. Otherwise do a search here and find the TSB that was posted about this. It will tell you everything you need to know to fix this.
pityr is offline   Reply With Quote
Old 12-09-2005, 07:56 PM   #7
Mulder
Trust no one
Member#: 11170
13 Mini MT
15 WRX/11 CRZ
Already posted the link, no need to search.
Old 12-09-2005, 09:45 PM   #8
skoobidoo
Member#: 91159
2005 WRX Wagon
Hmmm, was there ever a recall on this problem? The reason I ask is I read the link provided above and went to tighten the clamps, and sure enough the clamp under the V in the manifold is stripped. Yay!! I cant even get it to turn without stripping it further. So I figure if there was a recall on it I can take it in to get it fixed.
Anyone know if there was a recall? I have the mechanical knowledge to take the manifold off and fix it but I dont have the time to mess with this ****.
Thanks
Mike
Old 12-09-2005, 10:36 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2017 BMW X5
No recall, just a TSB.
cdvma is offline   Reply With Quote
Old 12-09-2005, 10:39 PM   #10
jlam86
Member#: 86822
2004 WRX
btw, they only grant it to a CERTAIN batch of 02 and 03s. not 04 or up
jlam86 is offline   Reply With Quote
Old 12-09-2005, 10:57 PM   #11
skoobidoo
Member#: 91159
2005 WRX Wagon
So if I dont have a warranty Im SOL huh? I thought I read in the link that some people without warranties were actually lucky enough to call SOA and get the work done for free. Maybe I'll be lucky as well, but I wont hold my breath.
Thanks for all the help guys! Wish me luck.
Old 12-09-2005, 11:08 PM   #12
lilsix
Member#: 67185
2007 Audi S4
4.2l V8
I am pretty sure SOA has decided to not pay for those repairs also.
No way! Go figure!
lilsix is offline   Reply With Quote
defi gauges not on while car is on position but on before. thisisntjared Electrical & Lighting 5 07-14-2009 11:28 PM
gas/fuel smell when car is warm kingman-442 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-14-2009 05:58 PM
Lingering fuel smell after car is shut off kenlee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-13-2006 04:31 PM
how to rid nasty smell when AC is on workin4audi Service & Maintenance 5 06-25-2004 12:34 AM
weird noise when heater is on mofoporn General Community 3 03-08-2002 10:56 PM
