Welcome to the North American Subaru Impreza Owners Club Sunday May 16, 2021
Old 04-29-2009, 07:18 PM   #1
choiboi
Member#: 126614
2006 WRB WRX TR
OS Stage 2
Default Need to change parking brake shoes?
So my emergency brakes are wearing out (e brake handle went sky high) so they were adjusted and engage in like 5 clicks. But i'm just wondering if the brake shoes every wear out like brake pads? When do you replace them? Is it hard to replace them?
choiboi is offline   Reply With Quote
Old 04-29-2009, 08:01 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
they do wear out, but it takes a long long long long time. Unless you're doing handbrake turns. if you are your 5mt center diff will die first.
Old 04-29-2009, 10:16 PM   #3
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
^ haha yeah if you are playing with the Ebrake your diff will go first , your car seems newish 06 , maybe you just need to tighten up the cable.
vik_wrx is offline   Reply With Quote
Old 04-29-2009, 10:49 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
The ebrake cable will stretch out before the pads wear. That's probably what happened.
(unless you use the ebrake while moving...)
sniper1rfa is offline   Reply With Quote
Old 01-24-2010, 08:39 PM   #5
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
I think mine is stretched - it engages wayyy high now - how do I adjust it?
FleaDog is offline   Reply With Quote
Old 09-14-2010, 06:23 PM   #6
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Adjust star cams in rear brakes
Old 09-15-2010, 04:16 PM   #7
istayaway
Member#: 237996
05 STi
Anyone else notice the loud "CLUNK" if you engage the ebrake when going anywhere over 3mph?
istayaway is offline   Reply With Quote
Old 07-24-2019, 11:43 AM   #8
some dude
Member#: 100300
06 WRX
CGM
^ my 2006 does this sometimes. I feel the parking brake dragging and at low speed I just have to pull on the handle a little to un-stick them.
But when I do, I hear a loud clunk, and feel it too.
After that they are not dragging.
some dude is offline   Reply With Quote
Old 07-24-2019, 10:19 PM   #9
some dude
Member#: 100300
06 WRX
CGM
Ok, I'm working on my car, replacing the parking brake pads on one side due to wear... and I swear to God I friggin' HATE the stupid keeper springs in the middle of the pad.
Old 07-25-2019, 01:39 PM   #10
some dude
Member#: 100300
06 WRX
CGM
Ok, got the hardware put on. Now, the rotor will not fit back over the pads.
The adjuster is all the way reduced to make pad diameter small as it goes but old rotor will not fit over. What am I missing?
Do I just take it all off and try again? It's all lined up and everything sure looks correct.
Any ideas? I'd love any input
Old 07-25-2019, 01:47 PM   #11
bspec
Member#: 215964
2018 Forester XT
Heritage Blue
IIRC they are a pain to get properly lined up. Also, could you have reversed something? It has been a few years, but I remember having a moment of 'crap, did this piece face the front of the car or rear?'. They do fit tight, are you sure the rotor doesn't fit over? If you've double-checked the install, are you sure you have the right shoes? Could you have possibly gotten STI ones or thicker adapter shoes (needed for the Legacy on Brembo swaps, not sure about the WRX).
bspec is offline   Reply With Quote
Old 07-25-2019, 08:23 PM   #12
xSacred
Member#: 478767
1999 Subaru Impreza
white
Once you are sure everything is assembled correctly pull up on the parking brake a few times. This helps center everything so you can slide the rotor on.
xSacred is offline   Reply With Quote
Old 07-26-2019, 02:48 AM   #13
some dude
Member#: 100300
06 WRX
CGM
Ok, so centering isn't the problem as the rotor hits the pads and stops before the studs touch the rotor.
New pads appear identical in dimension to old.
I took everything off and put back on, same problem.
My only thought I have as of now is I adjusted my cable 2 months ago and back then i had my original parking brake pads.
I tightened the cable a fair amount under center storage bin.
Would the tightened cable with old pads cause the new pads to not be able to get small enough? Do I need to loosen the cable adjuster?
Old 07-26-2019, 03:00 AM   #14
some dude
Member#: 100300
06 WRX
CGM
It's easy for me to post a video so anyone interested in double checking my setup
Old 07-26-2019, 06:20 AM   #15
some dude
Member#: 100300
06 WRX
CGM
I'm thinking of removing a small amount of metal where the star adjuster touches each shoe at the bottom. Like 0.5mm each side, then the rotor might fit over.
Is this NOT recommended?
Old 07-26-2019, 06:31 PM   #16
REDI-wgn
Member#: 38068
03 WRX Wagon
Yeah don't do that. Not 100% sure about Subaru, but there should be a primary and secondary shoe. Make sure you have in correct location. Everything looks ok, always hard to diag without actually being there. Compare parts to other side to make sure parts are correct. Including the new adjuster.
REDI-wgn is offline   Reply With Quote
Old 07-26-2019, 08:48 PM   #17
some dude
Member#: 100300
06 WRX
CGM
Ok, I have new pads coming tomorrow but in the meantime I will try different stuff attempting to solve this. I will report back.
Old 07-31-2019, 06:45 PM   #18
some dude
Member#: 100300
06 WRX
CGM
New pads fixed the problem, rotors slid back over them.
Now, I cant get the pads to bite on any type of incline.
Adjusting them from behind the rotor through the slot.. I have a pretty hard time doing that. Not much room there.
I took off rotors and adjusted until rotor would not go back on, turned it back a few clicks and rotor slid back on. But still not biting.
So I go to adjust the cable under center console and adjust it all the way tight, still won't bite.
Then I noticed maybe the metal where cable meets adjuster nuts looks bent.
Here's another video showing the bend I'm talking about. Is that supposed to be straight?
Old 08-01-2019, 11:57 AM   #19
some dude
Member#: 100300
06 WRX
CGM
Well I just saw a video of another 2007 WRX and their adjuster linkage is bent just like mine. Guess it's like that from factory.
I finally got them to bite correctly. I just needed to expand them a few more turns at the star adjuster.
Now they work great again holding the car on a good incline both forward and backward.
Old 03-04-2021, 01:43 PM   #20
manoflego
Member#: 514822
Editted: Nevermind. I scanned through the posts too quickly.
You fixed the issue of it binding for no reason by swapping in new shoes and hardware?
manoflego is offline   Reply With Quote
Can anyone point me to a parking brake shoe replacement tutorial? palmerx141 Service & Maintenance 7 12-10-2012 08:56 AM
How often do you need to change your brakes? plunk10 Off-Topic 114 04-08-2010 09:30 AM
Help! Need to change a brake light. hocky11 Tribeca Forum 3 02-03-2008 12:20 AM
need to change the brake for the 05 sti with 18k miles any good suggestion? fishdotcom Brakes, Steering & Suspension 7 08-09-2005 09:55 PM
What size line wrenches do I need to change the brake lines? dsc Brakes, Steering & Suspension 5 04-25-2002 07:03 PM
