10-02-2006, 04:50 PM | #1 |
Member#: 127858
Vehicle:2007 Impreza STI LTD Urban Grey Metallic |
MB Quart 6.5 " PCE216 or QSC216 - fit?
Looking for someone who has successfully mounted these speakers in the front doors of a recent model STI, including the crossover. Do they fit? If so, were spacers required? And where did you put the crossover?
Thanks.
10-02-2006, 05:35 PM | #2 |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
All MB Quart 6.5" drivers require some modification to fit. Usually some cutting.
I don't know if a 6.5" spacer has enough room, but I do know you can fit almost any 5.25" driver there. |
10-02-2006, 06:25 PM | #3 |
Member#: 127858
Cutting?
You mean cutting out metal from the door?
I took some measurements yesterday and looked up the speaker size too. Front speaker hole width in 2007 STI: about 5" or 5 1/16" across (my measurement) "Cutout dimensions" spec for QSC 216: 5.61" So does this mean the magnet on the back of the speaker is too large in diameter for the speaker hole in the door? |
10-02-2006, 10:36 PM | #4 |
Member#: 127858
bump - anyone have these installed?
10-03-2006, 02:03 AM | #5 |
Member#: 127925
Vehicle:2003 wrx blue |
i installed these ... can't remmeber the exact model - they are 2 years old and are 6.5" reference series. I installed in a my front doors with great difficulty. The door trims do not sit correctly either. If i were you, I'd spend a little more and gert 5" dynaudio splits for up front ... I know if i had the chance, i'd get the dynaudio for sure!
10-03-2006, 12:56 PM | #6 |
Member#: 94494
NWIC
The magnets on MB Quartz are small. The driver's diameter is very big, so the basket hits the whole. A spacer may help.
10-03-2006, 01:01 PM | #7 |
Member#: 4273
NESIC
Vehicle:2015 Taco & 2015 Legacy Ltd. |
IA performance spacers ftw, or just cut out some mdf and make spacers... I had MB Quart QSD 6.5" components in the front door of my 2004 WRX and in my 2006 WRX. The crossovers are huge so you may want to mount them under the seats or in the trunk. Luckily with Imprezas, it is fairly easy to fish speaker wire from insid the car into the door.
10-03-2006, 01:33 PM | #8 |
Member#: 127858
So you were able to install the 6.5" with no metal cutting? I'm afraid the spacers won't help with the small diameter speaker hole...I think they just help with mount depth...
10-03-2006, 02:30 PM | #9 |
Member#: 4273
NESIC
10-03-2006, 03:42 PM | #10 |
Member#: 99289
Sort of. They may push out the speaker enough for the natural taper of the speaker to allow for fitment.
10-03-2006, 04:24 PM | #11 |
Member#: 127858
Thanks guys. I also just got this back from Iaperformance (they responded in 3 hours, pretty nice!):
"The following info is assuming this is for the front doors: 1.Our supplied door panel extension pack will take care of mounting depth issues. 2. MB quart fit perfect with our adapters. This would be the ideal setup for a front set: http://www.iaperformance.com/product...oducts_id/1482 This would be an ideal setup if you were to add in the MB quart 5.25" coax rears: http://www.iaperformance.com/product_info.php/products_id/243" I'm getting ready to buy these speakers online and they'll probably not be returnable so I just want to make triple sure. Looks like I'm ready to go. |
10-04-2006, 04:31 AM | #12 |
Member#: 94494
NWIC
save money on your rears...don't buy them
10-04-2006, 06:52 AM | #13 |
Member#: 49895
NESIC
Vehicle: 09 Forester 06 Legacy 2.5i Wagon |
I installed the PCE216 speakers using the IAP thick spacers - no problems at all. I mounted the crossovers in the center console.
12-05-2006, 09:36 PM | #14 |
Member#: 65166
TXIC
Vehicle:2019 E53 AMG |
Anyone have any feedback on these speakers? I am wanting ot pick up a set of components and have had the JBL P650c's before and they were great and all just a bit too bright...these PCE216 component's ahve been catching my eye though...
12-05-2006, 10:54 PM | #15 |
Member#: 128530
TXIC
Vehicle:2013 BRZ WRB |
Listen to them first please.
MB Quarts are good but to me the titanium tweeters are very bright and require some attentuation or softening. Silk dome tweeters are easier for me to bear and feel more natural. So it is encouraged to please go listen to your favorite kind of music on them first. I am considering something like Diamond Hex 600s or some Focal's when I'm ready to build my system. |
FS: MB Quart 6.5 component speakers ESA 216 | takemetoothemoon | Canada Region Private Classifieds | 0 | 07-21-2006 04:18 AM |
Fitting aftermarket 6.5"s in WRX ... Thanks Joe | Concillian | Car Audio, Video & Security | 10 | 05-19-2001 08:56 PM |
Widest 16" tire to fit WRX 6.5" wide rim? | JahWind | Brakes, Steering & Suspension | 5 | 03-18-2001 12:51 AM |
6.5" Quart Component Install Success! | TimCat | Car Audio, Video & Security | 3 | 03-03-2001 10:13 AM |
Fitting 6.5"s in a 99 coupe... | Overtime | Car Audio, Video & Security | 6 | 02-12-2001 12:57 AM |
