12-13-2011, 11:09 AM | #701 |
Member#: 20204
Vehicle:05 lgt wagonista! SWP |
love this pic...this whole time i thought it was a 4th gen, until just now.
12-13-2011, 11:28 AM | #702 |
Member#: 20204
12-13-2011, 11:43 AM | #703 |
Member#: 249533
Vehicle:05 legacy gt ltd obp |
That's a badass wagon naylor
12-14-2011, 01:30 PM | #704 |
Member#: 289356
Vehicle:2002 BH 06 wrx swap |
Here's my swapped outback, took the body and suspention lift out tho so it counts.
12-14-2011, 03:11 PM | #705 |
Member#: 97495
NWIC
Vehicle:2013 Outback 3.6R GGM |
^ sweet car
12-14-2011, 03:24 PM | #706 |
Member#: 222527
NWIC
Vehicle:2013 Forester XT Ice Silver Metallic |
Catepisode, you have a build list of your beautiful wagon? You should check out sl-i.net as well
12-14-2011, 03:49 PM | #707 |
Member#: 303415
Vehicle:06 Legacy GT SWP |
Just started my own thread but just saw this one.. This is my semi stage 3 Legacy..
17x7.5 5zigen wheels Megan coilovers FMS front mount HPS Short ram intake TurboXS MBC FP Green STI catless uppipe Nameless catless down pipe Custom 3" straight pipe (single) The car hits hard but is on stock injectors so I'm limited right now |
12-14-2011, 07:51 PM | #708 |
Member#: 289356
started off as a 2002 subaru outback 2.5L cold weather package.
i Have done so much to it that i will do my best to remember. Suspention, steering and brakes Outback body lift removed replaced with legacy bits. Bilstein Sport wagon HD struts H&R legacy wagon lowering coil springs (wrx spring perches to fit them in front) Whiteline roll center adjustment kit (ball joints) tie-rods) 2007 wrx steering rack and steering column 2006 wrx front crossmsmber whiteline 22mm front swaybar w/ endlinks whiteline 20mmHD rear swaybar with adjustable endlinks kyb strut mounts drilled and slotted rotors forgot what kind hawk brake pads 2006 WRX 4 pot front calipers and 2 pot rears new wheel bearings all around Engine/Drivetrain: 2006 WRX ej255 DOHC Turbo Engine 32,000 miles on engine Cobb SF Intake with post MAF hose Mishimoto top mount intercooler hose kit Mishimoto turbo legacy radiator with hose kit Cobb accessport running stage 2 map for now Walbro fuel pump 2006 wrx 5 speed transmission 2006 wrx r160 rear diff 2006 wrx front axels 2003 legacy driveshaft. 2006 transmission crossmember Exedy stage 1 clutch Exhaust: Cobb 3" catted Downpipe 3" piping to a 3" Borla proxs muffler cobb heat shield too i guess Interior 2006 wrx dash and center console 2006 wrx pedals, because i went from auto to maunal 2006 dbw gas pedal with ecs pedal mount bracket Cobb shift knob ATI clock gauge pod 2 gauge pillar pod jvc stero & new speakers i forgot what kind, they sound good tho Exterior: rear spoiler legacy grille roof painted black 2004 baja turbo hood painted black to match the roof 2006 wrx wheels may match the bottom panels to the green someday, but i still like the slow outback look it makes it not stand out so much. Thanks for looking- Andrew |
12-15-2011, 02:40 AM | #709 |
Member#: 20204
12-15-2011, 12:47 PM | #710 |
Member#: 268039
NESIC
Vehicle:2005 Legacy GT SWP |
My 2005 Legacy GT
My 2005 Legacy GT Limited Sedan.5MT. On top of the luxuries like heated/power/leather seats, its got:
Stage 2/3, Cobb AP tuned Slowboy Racing 20g turbo (~17 psi) Perrin inlet SPT intake Greddy BOV Hallman Manual Boost Controller Perrin up-pipe (catless) Perrin down-pipe (catless) Perrin 3-in dual exhaust Walbro255 fuel pump Perrin FMIC Nex adjustable coilovers Camber bolts 17" STI BBS(blue now, soon to be gold?) for winter 19" Privat 3-piece rim for summer 8000K HIDS Custom molded sub +amp box in trunk wrapped in suede JL Audio W6 and 600W JL Audio amp STI Floorjam pieces Boost-gauge (mounted in top storage compartment) Black plasti-dip roof and trunk LED lights in the trunk Coming soon: DW 740cc injectors EFI Logics Stage 3 Tune Spec Stage 2 clutch Tial EWG White hella horns (iPhone pics, sorry some are crappy) Last edited by rpelletier; 01-11-2012 at 10:57 PM. |
12-15-2011, 01:08 PM | #711 |
Member#: 268039
NESIC
Naylor, by any chance do you know the paint code for those bronze wheels? looking to go in that same direction with my BBS....
12-15-2011, 02:33 PM | #712 |
Member#: 20204
Not sure. You would probably have to check with Mackin. That bronze is the color the CE28's came from Volk. To replicate would be pricey because the spokes are matte, but the barrells and lips ate anodized.
12-15-2011, 02:47 PM | #713 |
Member#: 268039
NESIC
thanks, ill check it out
01-20-2012, 07:40 PM | #714 |
Member#: 225791
Vehicle:2006 Legacy Alantic Blue |
01-30-2012, 12:59 PM | #715 |
Member#: 160988
Vehicle:08 LGT satin white |
shot taken this weekend after I repainted my winter wheels. Color is Antique Bronze Metallic
02-04-2012, 07:19 PM | #716 |
Member#: 131347
Vehicle:2007 Legacy 2.5i SE |
Nothing fancy just my daily driver, 2007 Legacy 2.5i SE w/ SPT catback.
At my old work when I was a Subaru Serivce Advisor All clean. |
02-24-2012, 10:07 PM | #717 |
Member#: 51221
Vehicle:2009 WRX Hatch DGM |
Crappy iPhone pic from this morning. Need to keep this thread alive!
03-08-2012, 12:10 AM | #718 |
Member#: 225791
03-12-2012, 02:25 AM | #719 |
Member#: 122139
NESIC
Vehicle:two '17 Imprezas & 05 Forester |
subscribe.
03-12-2012, 04:25 AM | #720 |
Member#: 187950
SWIC
Vehicle:06 LGT 11.669@124 satin white pearl |
06 legacy gt bought it stock back in 08
67k on her now mods are: Cp 9:1 pistons Acl race bearings Crower 1400hp rods Forged crankshaft Killer b oil pick up Gs power division 272 cams Ported heads STi intake manifold Invidia catless dp Greddy up pipe Amr cxr 550 turbo Perrin turbo inlet and short ram intake Avo fmic Tein s tech lowering spring Lexus rx330 hid retro fit 05 STi 6mt transmission 05 STi r180 Magnaflow cbe Custom painted headlights And I think that covers most of it larger turbo to come this fall |
03-12-2012, 04:26 AM | #721 |
Member#: 187950
SWIC
03-12-2012, 10:20 PM | #722 |
Member#: 234377
Vehicle:2005 Legacy GT STI Black |
03-14-2012, 03:20 PM | #723 |
Member#: 289356
This this is soooo sick!!!!
03-14-2012, 05:30 PM | #724 |
Member#: 255773
Vehicle:'05 Legacy GT VF52 Brilliant Silver Metallic |
03-14-2012, 05:55 PM | #725 |
Member#: 306721
Vehicle:05 LAGacy GT OBP |
That shot of the emblem looks awesome!
Calling all Legacy Turbo owners | inzomniac | Legacy Forum | 12 | 04-29-2002 11:31 PM |
calling all legacys........ | sub soob | Legacy Forum | 14 | 10-20-2001 11:13 AM |
Calling all Legacys...in MD, VA, DC would be nice!!! | CRAZY KEN | Legacy Forum | 4 | 07-11-2001 07:15 PM |
Calling ALL legacy owners out there!!! | SubieKidTK | Legacy Forum | 31 | 05-04-2001 11:46 AM |
Calling all Legacy guys! There's now another choice of bolt on exhaust's for us! | GTBGUY | Legacy Forum | 20 | 03-22-2001 07:17 PM |
