Welcome to the North American Subaru Impreza Owners Club Friday October 4, 2024
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum > South East Region Private Classifieds
Old 10-01-2022, 03:55 PM   #1
BlobeyeSTi
Member Sales Rating: (53)
Member#: 187877
2004 FXTi
Default AL: GC, GD & Foz Parts - RS, WRX, STi, FXT & LGT
Post #1: Mostly GD WRX & STi but some FXT & LGT
Post #2: 1999 & 2000 GC RS
Post #3: 2002 Forester
Post #4: 1998 Forester
Post #5: 2005 Saab 9-2X
Post #6: 2002 WRX
Post #7: 2004 WRX
Located in Huntsville AL or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
04 FXT
Coolant Sensor from Crossover Pipe $10
05 LGT 111k Pics: https://imgur.com/a/cBZ5tT7
Pistons $25 each
AVCS Intake Cam Gears $75 #13320AA000 RH & #13322AA000 LH
Timing Covers $15
AC Compressor Denso #447260-7940 $100
AC Compressor Bracket $15
Harmonic Balancer / Crank Pulley $40
Coolant Hard Lines $20
Up Pipe Brackets $5
Gauge Cluster Auto $50
GD WRX & STi Parts
Engine & Drivetrain Pics: https://imgur.com/a/xYSVkuV
B25 Left Head (Complete except camshafts and valve cover) $500
EJ205 Left Valve Cover $30
EJ257 Pistons $100 set
EJ205 Rods $25 each
EJ205 Pistons $75 set
AVCS Solenoid #10921AA020 $35
AVCS Right Intake Cam Gear IN RH #13320AA000 $75
AVCS Left Intake Cam Gear IN LH #13322AA000 $75
WRX STi Right Exhaust Camshaft #13034AA352 $75
OEM Left AVCS Lines $15
OEM Turbo Oil Line $25
OEM Turbo Heat Shield Bracket $10
Up Pipe Brackets $5
STi Passenger Side Feed Fuel Rail with Lines $25
JDM SG5 Intake Manifold $75
Clutch Fork $20
WRX Coil Packs for EJ205 #FK0140 $35 each
PCV Hose Assembly #11815AB711 $20
Crankshaft Sensor $20
WRX Camshaft Sensor for EJ205 $20
Knock Sensor $20
Front O2 Sensor Cover $5
Timing Covers $15
Timing Belt Guide $10
OEM Harmonic Balancer / Crank Pulley $40
Crankshaft Sprocket $20
Oil Pump $50
Power Steering Reservoir Bracket #34633FE001 $10
AC Compressor #73111FE040 $100
AC Lines $30
Coolant Temperature Sensor $10
Oil Pan & Baffle $50
Oil Pickup $15
Oil Dipstick $10
Oil Cap $5
02-05 WRX Cruise Control Actuator Module $20
Pitch Stop $10
Radiator Mounts $10
Transmission Mount #41022AC180 $25
05-07 WRX STi Power Steering Rack Cover / Skid Plate $20
Suspension, Wheels, Tires, & Brakes Pics: https://imgur.com/a/1Ms6AE1
Power Stop Z23 Evolution Sport Ceramic Carbon Front Brake Pads & Rotors Kit #K131 $200 New
WRX KYB Passenger Front Strut $50 (2 Broken Studs)
WRX KYB GR2 Driver Front Strut $75
04 WRX Front Calipers $50
04 WRX Front Rotors $25
04 WRX Rear Rotors $25
04 WRX Brake Booster $50
05 WRX Front Calipers (like new pads) $50
05 WRX Front Rotors $25
05 WRX Rear Calipers (like new pads) $50
05 WRX Rear Slotted/Drilled Rotors $25
Front Sway Bar Mounts $20
05 WRX Front Sway Bar $50
2002-2006 WRX STi Front ABS Sensors: #27540AE000, #27540AE001, #27540AE010 $25
2008-2014 Subaru Impreza WRX STi Forester Driver Front Left ABS Sensor OEM 27540AG111 $20 (Broken Clip)
5x100 Spare Tire $25
Jack & Handle $10
Exterior Pics: https://imgur.com/a/o4gYp1I
Front Sedan/Wagon Doors PSM $100
Rear Wagon Doors PSM $100
Passenger Rear Sedan Door PSM $100
Door Windows $40
Door Window Motors $30
Door Handles $25
Door Trim $20
Door Wiring $30
Wagon Gas Lid PSM $20
Wiper Motor & Linkage $40
Exterior B Pillar Molding with Weather Stripping $20
Fuel Fill Neck $30
Fuel Fill Neck Cover $10
Interior Pics: https://imgur.com/a/G7vOkeh
Glovebox $50
Cluster Surround $20
Heater Core #72110FE032 *& 72110FE033 $75
Blower Motor 72210FE020 $100
05 WRX Steering Column $50
06 WRX Steering Column $50
Map Light $25
Dome Light $20
3rd Brake Light $20
Visor Clips $5 set
Rear View Mirror $20
Mirror Covers #94251FE000 & 94251FE010 $5
Passenger A Pillar Sedan $20
A Pillar Wagon $20
Door Kick Molding Trim $10
Seat Belts $40
Seat Belt Buckles $10
Gas Lid Release Cable $10
Weather-Stripping $5
Jack & Handle $10
Jack Cover $5
Parking Light Combo Switch $20
Sunroof Drain Tubes $10
Electronics Pics: https://imgur.com/a/QuPpVtK
2005 STi Rear Harness #81502FE312 $50
2006 WRX Rear Harness #81502FE293 $50
OEM Front Speakers $20
OEM Rear Speakers $20
05-07 Mirror Switch $10
Window Switch $10
Lock Switch $10
Hazard Switch $10
Map Light $20
Dome Light $20
Headlight/Blinker Combo Switch $25
Wiper Combo Switch $25
Switch Blank $5
Rear Defrost Switch $10
Cruise On/Off Switch $10
OEM Horns Set of High & Low $10
Horn Switch (Behind Airbag) $10
Metal ECU Cover $15
Wiper Motor $40
Battery Terminal Cable $40
DRL Module #84067FE060 $10
04/05 Control Unit Air Bag #98221FE110 $30
WRX STI Left Front Air Bag Sensor #98231FE070 $10
WRX STI Right Front Air Bag Sensor #98231FE060 $10
WRX STI Left Side Airbag Sensor #98235FE150 $10
WRX STI Right Side Airbag Sensor #98235FE140 $10
WRX STI Left Side Airbag Sensor #98231FE010 $10
WRX STI Right Side Airbag Sensor #98231FE000 $10
WRX STI G Sensor ABS #27540FA022 $10
Fuel Injector Resistor Module #684227 $10
02-14 Impreza WRX STi Door Ajar Sensors #83331AE001 $5 each
02/03 WRX Keyless Entry Module #88035FE021 $20
04/05 WRX STi Keyless Entry Module #88035FE140 $20
04/05 WRX STi Integrated Control Module #88281FE160 $20
Security ECU #H7110SS010 $25
04-07 WRX STI Clarion Antenna Amplifier Assembly #86327FE071(Wagon) #86327FE090(Sedan) $15
04-07 WRX STI Clarion Defrost Module $15
BlobeyeSTi is offline   Reply With Quote
Old 10-01-2022, 03:56 PM   #2
BlobeyeSTi
Member#: 187877
2004 FXTi
OMGHi2U
Parts are from 1999 & 2000 RS coupes both 5 speeds but have automatic starter & brake pedal.
Engine & Drivetrain Pics: https://imgur.com/a/F23PkWq
AC Compressor $100
AC Hardlines $25
Auto Starter $50
OEM Flywheel, Pressure Plate & Clutch Disc - Pressure Plate & Clutch brand unknown but plenty of life $150
1998 RS Engine Harness #24020AB990 $50
Crankshaft Pulley $30
Air Assist Injector $35
EJ SOHC Timing Covers: Outer Left #13574AA081, Inner Left #13575AA112 & Inner Right #13573AA091 $10 each
Gas Cap $10
Fuel Pump $20
Fuel Rails and Lines $50
Fuel Pressure Regulator $25
Injectors $40 set
Slave Cylinder $20
Throttle Cable $10
Ignition Coil $25
Plug Wires $25 set
Throttle Body $40
Oil Fill Neck and Cap $15
Cam Gears $10
Coolant Overflow Tank $10
Air Box Intake Tube Resonator $20
Engine Bay Fuse Box OEM #82232FA100 $20
Suspension Pics: https://imgur.com/a/vaSJf0R
End Links $20 set
Interior Pics: https://imgur.com/a/zlSelwm
Steering Column Harness #83115FC020 $25
Auto Brake Pedal $25
Steering Wheel $20
Driver Airbag $40
Passenger Door Lock Actuator $20
Hood Release Handle $5
Dome Light $10
Tweeter Cover $10
ECU Metal Cover $10
Hood Release Cable $10
Electronics Pics: https://imgur.com/a/3779vWz
Knock Sensor $10
Door Ajar Sensor $10
Horn Switch $10
Antenna with Hardware $20
[b]I keep this list up to date so not a lot left from the GCs.
Old 10-01-2022, 03:57 PM   #3
BlobeyeSTi
Member#: 187877
2004 FXTi
2002 Subaru Forester 5 Speed 211k
Engine, Drivetrain, Suspension & Brakes
Intake Manifold $50
Engine Harness #24020AC710 $50
Intake Scoop $10
Intake Resonator Inner Fender #A32AC08 $10
End Links $20 set
Power Steering Lines $25
Front ABS Sensors $15
Front Brake Calipers $25
Clutch Slave Cylinder $20
Plug Wires $25
Ignition Coil $30
Fuse Box $25
AC Lines $30
Fuel pump $20
Pitch Stop Mount $10
Gas Cap $10
Oil Dipstick & Tube $10
Oil Cap $5
Oil fill neck $5
Radiator Mounts $5
Exterior
Fog Lights $20
Driver Headlight Trim $15
Taillight Trim $15
Wiper Arms $20 set
Rear Wiper Arm $15
KYB Rear Hatch Struts $25 Set
Interior
Rear Harness #81532FC100 $50
Hatch Harness #81812FC101 $25
Roof Harness #81801FC210 $25
Driver Airbag $40
Steering Wheel $20
Steering Column $50
Ignition and Key $40
Rear Door Ajar Sensors $10 set of 2
Map Light $35
Dome Light $10
Headlight Switch $25
Wiper Switch $25
Master Switch $25
Window Switch $10
Door Lock Switch $10
Rear Wiper Switch $10
Interior Plastic Pieces $10+
LEDs for map, dome and rear interior lights $5
More pictures: https://img.nasioc.com/album/2002-fo...-part-out.NXO7
Old 10-01-2022, 03:57 PM   #4
BlobeyeSTi
Member#: 187877
2004 FXTi
1998 Subaru Forester 5 Speed with EJ22
End Links $20 set
Intake Scoop $10 "Engine Air Intake Outlet" #46021FC0000
Plug Wires $25
Ignition Coil $30
Fuse Box $25
AC Lines $30
Fuel Pump $20
Gas Cap $10
Oil Cap $5
Oil Fill Neck $5
Radiator Mounts $5
Exterior
Fog Lights $20
Headlight Trim $15
Wiper Arms $20
Rear Wiper Arm $15
Interior
Driver Airbag $40
Steering Wheel $20
Steering Column $50
Dome Light $10
Map Light Assembly $35
Wiper Switch $25
Master Switch $25
Window Switch $10
Mirror Switch $10
Nasioc image server has been broken forever so just send me a message if you want pictures of a certain part. Copy & paste this link into your browser for the below pictures: https://imgur.com/a/PvzAOoy
Old 10-01-2022, 03:57 PM   #5
BlobeyeSTi
Member#: 187877
2004 FXTi
2005 Saab 9-2X Aero 128k Miles 5 Speed
Engine & Drivetrain
Front Axle $75
AC Compressor $100
AC Lines $25+
Clutch Fork $20
Clutch Fork Rod $20
Cruise Control Actuator $40
Timing Covers $15
Suspension, Wheels, Tires & Brakes
Front Rotors $25
Front ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
Exterior PSM 01G
Doors $100
Gas Lid $20
Trim & Weather Stripping $10+
Interior
Seat Belts $40
Glovebox $50
Heater Core #72110FE101 & 72110FE033 $75
Steering Column $50
Window Motor $30
Door Harness $30
Headlight Combo Switch $25
Hazard Switch $10
Blank Switch $5
Mirror Switch $15
Window Switch $10
Lock Switch $10
Map Light $25
Dome Light $20
Nasioc image server has been broken forever so just send me a message if you want pictures of a certain part. Copy & paste this link into your browser for the below pictures: https://imgur.com/a/tUKjixJ
Old 10-01-2022, 03:58 PM   #6
BlobeyeSTi
Member#: 187877
2004 FXTi
2002 Subaru WRX 189k Part Out
Engine
Crank Sprocket $20
Harden Race Pitch Stop Mount $50
Knock Off TurboXS BOV $25
JDM Ignition Coil $50
JDM Fuel Lines with FPR $75
JDM 440cc Yellow Side Feeds $125
Coil Packs FK0140 $35 each
AC Lines $25+
Coolant Lines $20
Throttle Cable $10
Timing Covers $15 each
Steering Shaft Joint $25
Transmission & Drivetrain
Rear Differential Housing Case Only $50
Rear Differential "T" Crossmember $100
Shifter Linkage Assembly $50 (Cut Shift Lever)
Starter $50
Axles $75 each
Clutch Fork $20
Clutch Fork Rod $20
Suspension, Brakes & Wheels
Scion TC Black Wheels 17x7 +45 (Needs Tires) $200
Mostplus Coilovers $100
Front Rotors $25
Brake Booster $50
Front ABS Sensors $25 each
Exterior
OEM Taillights $50 each
Doors $100 each
Door Harness $30
Window Motors $30
Windows $40
Mirrors $50 each
Rear Bumper Cover $100
Trunk & Wing $50
Trunk Latch $20
Passenger Side Skirt $50
Gas Lid $20
Gas Cap $15
Gas Tank $75
Fuel Neck $40
Charcoal Canister $40
Interior & Electronics
Heater Core #72110FE032 $75
Gauge Cluster 201k Miles $75
Rear Harness $50
Battery Harness $40
Door Cards $25 each
Outside Dash Vents with Black Circle Trim $25
Glove Box $30 (Broken Stoppers)
Center Console $50
Ashtray with Lighter $20
Interior Fuse Box $25
OEM Subwoofer $25
OEM Tweeter #86301FE060 $10 (only have one)
Steering Column $75
Window Motor $30
Door Harness $30
Wiper Switch $25
Hazard Switch $10
Mirror Switch $15
Window Switch $10
Map Light $25
Dome Light $20
Oh **** Handles $20 set
Interior Panels $10+
Crank Sensor $20
Camshaft Sensor $20
Knock Sensor $20
Old 11-17-2023, 03:37 PM   #7
jaxscuby
Sammo Hung
Member Sales Rating: (24)
Member#: 10613
2002 USDM WRX
Engine
EJ205 Heads Complete with Camshafts <100k New Valve Cover Gaskets & Cam Seals $500 each
Crank Sprocket $20
Tsudo Bellmouth Catless Downpipe made for Cutout $100
TMIC $40
TMIC Brackets $20
OEM Intercooler Splitter (Modified for STi Scoop) $100
Intake Manifold $75
JDM Long Runner Intake Manifold (Off Late 90s Turbo Foz) $150
JDM Purge Valve Solenoid $20
JDM Engine Harness $20 (Damaged/Cut)
JDM DBC Throttle Body $50
JDM Fuel Lines with FPR & 440cc Yellow Side Feeds $150
Coolant Crossover Pipe $50
AC Compressor Bracket $20
AC Condenser $50
Coil Packs FK0140 $40 each
Oil Fill Neck with Cap $30
Passenger Intercooler Bracket $20
AC Bracket $20
AC Lines $25+
Coolant Lines $20
Throttle Cable $10
Group N Engine Mounts $75
Fuse Box $30
Front Differential with Ring Gear & Male Axle Stubs $150
Starter $50
Rear Differential $100
Axles $75 each
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Fork Rod $20
'U' Front Subframe $200
Transmission Mount $25
Scion TC Black Wheels 17x7 +45 (Needs Tires) $300
OEM Struts with Lowering Springs $200
Mostplus Coilovers $150
Front Sway Bar $25
Front Rotors $25
Brake Booster $50
ABS Control Module $40
ABS Sensors $20 each
Exterior
OEM Headlights $75 each
OEM Foglights $40 each
Grille Trim $20 each
Fenders $50 set
Driver Side Marker Light $20
Doors $100 each
Mirrors $50 each
Hood $100
Scoop $50
Hood Latch $20
Bumpers $100 each
Bumper Beams $50 each
Trunk & Wing $50
Trunk Latch $20
Chassis $500
Gas Lid $20
Gas Cap $15
Gas Tank $75
Fuel Neck $40
Bulkhead Harness $200
Front Harness $100
Rear Harness $50
Cluster Harness $40
Battery Harness $25
Clock Spring $75
Front Seats $100 each
Rear Seats $50
Seat Belts $40 each
Door Cards $25 each
Dash $75
Clutch & Brake Pedal Assembly $150
Shifter Bezel $25
Center Console $50
Radio/HVAC Trim $25
Fuse Cover $10
Interior Fuse Box $40
E-Brake Handle $25
OEM Subwoofer $25
OEM Speakers $25 pair
Steering Column $75
HVAC Controls $40
Window Motor $25
Door Harness $25
Wiper Switch $25
Fog Light Switch $10
Hazard Switch $10
Mirror Switch $15
Master Switch $35
Window Switch $10
Center Vents $25
Rear View Mirror $25
Center Sun Shade $10
Map Light $25
Dome Light $20
*No grille or stock exhaust parts
*Body panels are pickup only but everything else can be shipped
*Polished the headlights but only the first picture is after
Nasioc image server has been broken forever so just send me a message if you want pictures of a certain part. Copy & paste this link into your browser for the below pictures: https://imgur.com/a/4k1D2sN
so this car is gone?
Old 11-17-2023, 05:26 PM   #8
BlobeyeSTi
Member#: 187877
2004 FXTi
I still have the chassis with all the body panels, trim & glass but the rest has been stripped. Whats not listed in the original post has been sold.
Old 10-01-2022, 03:59 PM   #9
BlobeyeSTi
Member#: 187877
2004 FXTi
2004 Subaru WRX 221k Stage 2 Part Out Knocking
Aftermarket
Cobb SS Cat Back Exhaust $500
Cobb SS Turbo Heat Shield $50
Cobb Short Shifter $150
K&N Drop In Filter $40
Engine
EJ205 Case $300
Crankshaft $150
Pistons $100 set
Rods $100 set
Left Driver Head $400
Right Passenger Head $400
Camshafts $75
Cam Gears $50
Valve Covers $30
Timing Covers $15
Head Bolts Set Of 12 #11095AA042 $40
Front O2 Sensor $80
Rear O2 Sensor $40
Exhaust Manifold $150
Uppipe Catted $50
TD04 Turbo $100
Turbo Heat Shield Bracket $20
Boost Controller Solenoid #16102AA360 $50
Boost Controller Bracket $20
Intercooler $50
Intercooler Splitter $75
Intercooler Bracket Driver Side Only $25
Oil Fill Neck & Cap $30
Intake Manifold $100
Throttle Body $50
TGVs $200 set
Fuel Lines $100
Fuel Injectors $50
Engine Harness $100
Air Box Lid $50
Intake Scoop #45012AE100 $30
Post MAF Hose #46013FE001 $25
MAF #22680AA310 $25
Turbo Inlet $25
Purge Valve $25
Purge Solenoid $25
Coolant Expansion Tank $75
Alternator $50
Alternator Cover $10
Radiator $50
Radiator Fans $50
Radiator Brackets $20 set
Hood Prop Rod $15
Power Steering Pump $100
Power Steering Reservoir $25
Power Steering Bracket $15
Power Steering Lines $50
AC Compressor $100
AC Tensioner $35
AC Condenser $40
AC Hoses & Hard Lines $25+
Clutch Master Cylinder $45
Pressure Plate & Clutch $100
Flywheel $100
Group N Engine Mounts $50
Engine Coolant Bypass Pipes $50
Coolant Overflow Tank $20
Fuel Filter Bracket $25
Engine Fuse Box $40
Turbo Oil Line $25
Oil Pickup $15
Oil Dipstick $10
Clutch Slave Cylinder $50
Crank Sprocket $20
Coil Packs FK0186 $35 each
Throttle Cable $10
Windshield Washer Tank $35
Crank Sensor $20
Camshaft Sensor $20
Knock Sensor $20
Skid Plate/Splash Shield #56410FE211 $50
Shift Linkage Assembly $150 (Like New)
5 Speed Transmission Case Front Section $150
Front Differential with Ring Gear $150
Gear Sets Complete Assembly with Shift Forks, Linkage & Extras $500
Transfer Case Housing #33101AA680 $50
Transfer Gears with Tail Shaft Housing $200
Center Differential $150
Rear Differential $150
Rear Differential Ring & Pinon $150
Rear Differential Rear Cover $75
Rear Differential Housing $75
Driveshaft $100
Axles $75 each
Starter $50
Clutch Fork $20
Clutch Fork Rod $20
Wheels, Tires, Brakes, Suspension & Subframes
205/55/16 Falken Pro G4 All Seasons 8/32nds with Wheels $500
Front Calipers $50 pair
Front Rotors $25 pair
Rear Calipers $50 pair
Rear Rotors $25 pair
Brake Booster $50
Brake Proportioning Valve $25
ABS Control Module $50
ABS Sensors $25
Struts & Springs $200 set
Knuckles $100
Control Arms $50
Trailing Arms $40
Lateral Links $25
Rear Sway Bar $50
Front Sway Bar $50
Sway Bar Mounts $20 set
Rear End Links $25
Front End Links $25
Steering Rack $100
U Frame $300
Front Crossmember $200
Rear Crossmember $200
Transmission Crossmember $100
Exterior
Stripped Chassis $500
Grille $75
Headlights $100
Headlight Brackets $20
Fog Lights $40
Fog Light Trim $40
Taillights $100
Fenders $100
Doors $100
Door Windows $40
Door Handles $25
Heated Mirrors $75
Hood $250
Hood Latch $25
Scoop $100
Front Bumper Cover $100
Front Bumper Beam $100
Rear Bumper Beam $100
Trunk & Wing $150
Trunk Latch $20
Side Skirts $50
Wiper Arms $50 set
Wiper Motor & Linkage $50
Gas Lid $20
Gas Cap $15
Gas Tank $75
Fuel Neck $40
Heated Front Seats $500 set
Rear Seat Cushions $100
Seat Belts $40
Seat Belt Buckles $20
Seat Bolt Covers $20
Carpet $75
Floor Mats $40 set
Trunk Board $30
Jack & Tool $20
Tool Kit - Pouch, Tow Hook, Lug Nut Wrench, Screwdriver, Wheel Cap Lever #97010FE030 *$30
Sunroof Assembly $250
Headliner $50
ECU $150
ECU Cover & Bracket $25
Fuel Pump $25
Fuel Pump Controller $50
Fuel Hanger $50
Gauge Cluster 221k Miles $75
Cluster Harness $50
Bulkhead Harness $250
Front Harness $250
Rear Harness $50
Roof Harness $20
Trunk Harness $20
Battery Harness $40
Clutch & Brake Pedal Assembly $200
Gas Pedal $50
Dead Pedal $10
Auto Dimming Rear View Mirror with Compass $50
Dash $150
Clock $20
Center Vents with Trim #66060FE110 $30
Passenger Air Bag Cover $20
Headunit Faceplate Only $10
Headunit Brackets $10 set
Tweeters $30 pair
Speakers $40 set
Speaker Brackets $20 set
HVAC Controls $50
Heater Core $75
Blower Motor $75
Ash Tray $25
Cigarette Lighter Cover $5
Shifter Boot & Trim $50
Shift Knob $10
E-Brake Boot & Cupholder Section $30
E-Brake Handle $30
Center Console $50
Glove Box $50 (Broken Stops)
Glove Box Lamp Harness $20
Fuse Box $25
Door Cards $50
Door Handle Bezels $10
Door Wiring Harness $30
Window Motors $30
Clock Spring $100
Steering Wheel $40
Steering Column $75
Lower & Upper Steering Column Trim $40
Ignition & 2x Keys $50
Key Ring Light $30
Parking Light Switch $20
Wiper Switch $25
Cruise Switch $30
Cruise On/Off Switch $25
Fog Light Switch $25
Defrost Switch $20
Hazard Switch $10
Mirror Switch $15
Left Heated Seat Switch #83075FA011 $20
Right Heated Seat Switch #83075FA001 $20
Window Switch $10
Lock Switch $10
Master Switch $40
Master Switch Trim $20
Sunroof Switch with Map Light $50
Dome Light $20
Visors $40 set
Rear Dash $40
Other Interior Panels $10+
Impact Sensors $20
G Sensor #27540FA022 $20
Daytime Running Light Control Module #84067FE010 $20
Vapor Canister Purge Solenoid & Canister Filter #42072FA030 & #42084FA120 $25
Valve Pressure Control & Wiring #42084FA110 & #42086FA041 $75
Cruise Control Module #87022FE020 $20
Integrated Unit Control Module $25
Intermittent Wiper Control Mitsuba RK-0098 12V #86571FE000 $25
Keyless Entry Unit Module #88035FE141 $25
Security Unit ECU Module #H7110SS010 $20
Daytime Running Light Resistor #84057FE011 $10
Control Unit Module #98221FE110 $25
Clarion Defrost Module #NSA-170-100 $15
Original MSRP Window Sticker $40
Old 10-01-2022, 03:59 PM   #10
BlobeyeSTi
Member#: 187877
2004 FXTi
Old 10-28-2022, 03:32 PM   #11
BlobeyeSTi
Member#: 187877
2004 FXTi
Old 01-03-2023, 08:10 PM   #12
BlobeyeSTi
Member#: 187877
2004 FXTi
Original posts updated
Old 03-03-2023, 07:38 PM   #13
BlobeyeSTi
Member#: 187877
2004 FXTi
Old 04-07-2023, 03:05 PM   #14
BlobeyeSTi
Member#: 187877
2004 FXTi
bump.
Old 06-19-2023, 05:14 PM   #15
BlobeyeSTi
Member#: 187877
2004 FXTi
Original posts updated & added the 2002 WRX
Old 07-07-2023, 12:54 PM   #16
BlobeyeSTi
Member#: 187877
2004 FXTi
Updated
Old 07-27-2023, 03:12 PM   #17
BlobeyeSTi
Member#: 187877
2004 FXTi
Updated
Old 08-18-2023, 08:39 PM   #18
BlobeyeSTi
Member#: 187877
2004 FXTi
Updated
Old 09-23-2023, 12:54 PM   #19
BlobeyeSTi
Member#: 187877
2004 FXTi
Original Post Updated
Old 11-14-2023, 12:07 PM   #20
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
from your 02 bugeye part out..
hood
headlights
rear view mirror?
Old 11-14-2023, 12:08 PM   #21
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
hood
headlights
rear view mirror?
Old 11-14-2023, 01:54 PM   #22
BlobeyeSTi
Member#: 187877
2004 FXTi
hood
headlights
rear view mirror?
Have all of those parts left from the bugeye
Old 11-14-2023, 03:17 PM   #23
BlobeyeSTi
Member#: 187877
2004 FXTi
Old 11-22-2023, 07:56 PM   #24
m1keyp92
Member#: 536128
Vouch for this guy. Shipped fast and everything came packed super nice.
m1keyp92 is offline   Reply With Quote
Old 11-23-2023, 12:41 PM   #25
BlobeyeSTi
Member#: 187877
2004 FXTi
Thanks for the feedback!
