Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 07-28-2006, 11:17 PM   #1
indelible
Member#: 99573
2015 FXT
Default Hella Supertones or Stebel Nautilus Air Horn?
I'm debating between the Supertones (118db) and the Stebel Nautilus (139db). As you all know, the Supertones can be mounted facing outwards from the grill. However, the best placement for the Nautilus, that I have seen, is under the driver's headlight (in an '05 STi) and facing down so nothing can get into the compressor. Since the Nautilus is mounted in an enclosed area, which will be louder, the Supertones or the Nautilus?
Nautilus Install
indelible is offline   Reply With Quote
Old 07-29-2006, 12:03 AM   #2
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2017 Golf
Alltrack
This has been covered in many threads...the 2 horns sound VERY different. There are a few guys in my local club with the Supertones, and I have the Nautilus. It's difficult to say which is louder, because of the different sounds. If you have a db meter, find someone with both...and measure As for mounting the Nautilus, I have mine in the front of my '06 off to the driver's side of the grille. You have to mount the Nautilus nearly straight up and down for it to work properly, and the compressor intake points straight down. I have been running this setup for several months now, trouble free, even in rainy Vancouver.
semaj is offline   Reply With Quote
Old 07-29-2006, 02:03 AM   #3
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
*subscribe*
I would like to know more...
Rapid_Roo is offline   Reply With Quote
Old 08-17-2006, 03:21 PM   #4
WRXDriftR
Member#: 65065
2004 EJ205 STi
2007 Forester STi
If you get a Nautilus and put it down inside the bumper somewhere, its gonna have all the glory muffled when you beep. It wont sound as loud since its lower and blocked by plastic and metal!
The supertones located in the top grill are a direct shot at someone who cuts you off. If you get quick enough you can blast them right in the ear thru their back or side window as the turn in front of you. (funny when its a convertible with the top down)
scares pedestrians if they ever purposely walk in front of you too. just be prepared if they throw something at your car in return.
WRXDriftR is offline   Reply With Quote
Old 08-19-2006, 03:41 PM   #5
indelible
Member#: 99573
2015 FXT
Well the problem is, the Nautilus is 139db and the Supertones are 118db, 21db difference between them, (for every 3 dB there is a doubling in sound, so there is 7 doubling which is 2^7) making the Nautilus 128 times louder than the Supertones and I'm wondering whether or not the bumper cover would negate that difference.
edit: and if they happen to both be just as loud, i'd rather get the Nautilus, costs less and it won't attract any thieves looking into your grill.
Old 08-19-2006, 09:16 PM   #6
semaj
Moderatour
Member#: 113533
2017 Golf
Alltrack
My Nautilus appears to be the same volume as a local's supertones, maybe a little louder...but they obviously sound different. I have my Nautilus in the centre grille opening of my '06...and it's invisible from the front Oh yeah...the Nautilus costs about 1/3 of the supertones as well. Nautilus FTW!
Old 08-19-2006, 09:26 PM   #7
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
supertones
easy install, great tone on the German models [dont get the Indian ones,] and they add a nice cosmetic flare at times
JohnnyWas is offline   Reply With Quote
Old 08-20-2006, 12:56 AM   #8
indelible
Member#: 99573
2015 FXT
Originally Posted by JohnnyWas
supertones
I'm not worried about looks or ease of install (both are easy to install), I just want to know which one is louder or best bang for the buck.
Old 08-21-2006, 06:56 PM   #9
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
PM me for my install pics of the Nautilus if you would like more creative ideas.
Mine are quite loud, I have not compared side by side with supertones but I definately prefer the more "German car" sound over the more "American" type sound.
Drew888 is offline   Reply With Quote
Old 08-21-2006, 08:44 PM   #10
indelible
Member#: 99573
2015 FXT
PM sent and I believe the Nautilus sound is supposed to be Italian, not German.
Old 08-22-2006, 04:47 PM   #11
hypov
Member#: 9563
Nautilus Install
I have both.
Supertones behind the grille and the Nautilus behind the fender.
Suggestion to indelible. Get both. They compliment each other very well.
The front firing Hella gives you forward coverage, whilst the Nautilus gives you perimeter coverage.
-Dave
hypov is offline   Reply With Quote
Old 08-22-2006, 11:20 PM   #12
indelible
Member#: 99573
2015 FXT
Originally Posted by hypov
I have both.
-Dave
I would get both, but I don't feel like spending that much more money on something that I wont use that much.
Old 08-28-2006, 07:17 PM   #13
indelible
Member#: 99573
2015 FXT
bump it
Old 06-18-2009, 11:44 AM   #14
Garandman
Member#: 101117
2009 WRX, 14 OB 3.6R
Any hints on Stebel install for an 09? I'm trying to decipher if the stock horn has a relay or I have to wire one to run the Nautilus. I think I'm going to mount it on the center strut near the stock horn, but lower down.
Garandman is offline   Reply With Quote
Old 06-18-2009, 12:25 PM   #15
25rsti
Member#: 166324
from the dead....it awakes
Old 11-13-2009, 11:29 PM   #16
JohnnyW
Member#: 226171
2010 STI
I jsust bought a nautilus one. Not too sure on how to wire it.
Any write up ? I have a 2007 wrx wagon
JohnnyW is offline   Reply With Quote
Old 01-25-2010, 07:35 AM   #17
Craig - Sydney
Member#: 236306
The sound pressure figures advertised are usually very misleading.
The Hella Supertones and Stebel Nautilus both have the same output at 2 metres 118 dBA.
The 139dBA for the Nautilus is at 100mm or 4 inches.
Craig - Sydney is offline   Reply With Quote
Old 05-23-2010, 12:17 AM   #18
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, since someone bumped this thread into this year already...
My fiancee wants louder horns for rush hour. I have Supertones now but she's trying to decide between the Supertones and the Stebel Nautilus. The reason the Supertones might sound louder is that they're in a frequency range to which the human ear is more sensitive.
However, what I'm really here for is to ask you guys who have had the Nautiluses for a while if they still work. I'm hearing some rumors of poor reliability with them. Any truth?
Old 08-09-2010, 12:05 PM   #19
Garandman
Member#: 101117
I've had one on my motorcycle for three years: granted it doesn't see winter weather.
I particularly like them because they don't make people angry the way a diaphragm horn does. While loud, you can give a short beep and it gets attention without making them try to kill you....
Stebel Nautilus Air Horn Install writersblock Interior & Exterior Modification 26 08-10-2007 01:13 PM
Hella Supertones vs Stebel Nautilus Splinter Vancouver Impreza Club Forum -- VIC 21 06-23-2007 10:29 PM
Horn questions,Wolo or Stebel Nautilus Kahres05 Interior & Exterior Modification 14 06-15-2007 04:39 PM
Question to everyone who has the Hella Supertones connected with the OEM horns... thsiao Interior & Exterior Modification 23 10-07-2005 03:23 PM
Wanted: Hella Supertones or Air Horns sawlid Private 'Wanted' Classifieds 0 04-12-2004 06:40 PM
