Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2019
Old 02-01-2008, 12:27 PM   #1
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Default My All Carbon WRC replica (P2000/ S6)
I realized that while I've often come on these boards for help and for buying/selling parts, I've never really posted what I was doing with my car.
CURRENT PICS:
MOD LIST
Exterior
Aerosim carbon fiber widebody
2000 WRC bumper
Currently making carbon trunk
Bakemono Carbon fiber 22B wing
L'aunsports Stainless duct net grill (Lower 2000 WRC Grill)
Bakemono Carbon roof with carbon kevlar bottom
WRC roof scoop
Carbon P2000 WRC hood
Blacked out headlights and corners
Clear bumper turn signals (from a ver. 3 STI RA, but switching back to amber)
JDM STI Red/Clear Tail lights
Interior
WRC carbon dash (bakemono)
STI v4 cluster with STI 10K tach/ 280km/hr speedo
Prodrive steering wheel on NRG quick release hub
DCCD controls, wired up to correctly display on v4 STI cluster
Bride Zeta 3 seats
Takata harnesses
2004 WRX pedalset
Shift knob from Version 5 STI V-Limited
Removed rear seats
Bakemono carbon fiber door panels
Bakemono carbon fiber rear interior quarter panels
Bakemono carbon fiber rear bulkhead
Defi 60mm Boost Gauge, 52mm oil temp gauge, 52mm water temp gauge, 52mm oil pressure gauge
Wheels/Brakes
18x 9.5" RCT4
Tires undecided
Touge Tuning SS brake lines
Prodrive Alcon front calipers
Stoptech 2-Piece front rotors
2004 STI rear calipers/ rotors
Hawk HPS Pads
Drivetrain/ Suspension/ Handling
Nagisa Auto Rear Wide-track adjustable Lateral Links
Custom axles go match with wide-track arms
1998 STI RA 5 speed 4.44 transmission
TSS Fab front crossmember
TSS Fab Rear crossmember
TSS Fab front control arms
Bilstein PSS9 coilovers
Bakemono front camber plates
Whiteline front and rear swaybar
Whiteline polyurethane bushings fitted to all steering linkage
Engine
2004 Spec C EJ207
Manley rods and pistons
Cryogenic crank
2004 spec C heads
Garrett GT3076 rotated turbo
Perrin up-pipe/downpipe
Aeromotive fuel pressure regulator
DeatschWerks 1000cc injectors
Aeromotive fuel rails
Tial 44mm external wastegate
Grimmspeed Electronic Boost Controller
Process West V-mount Radiator with Spal Fans
DeatschWerks DW300 fuel pump
Bakemono custom carbon fiber intake
Prodrive P1 catback
Intercooler spray removed...figured it was redundant with the meth injection
Intercooler Auto Spray switch rewired to arm and unarm meth injection
Beautification: Glass beaded/clear coated turbo coolant tank lid and various brackets. Powdercoated turbo coolant tank. Cleaned engine bay with rag...one of the best mods one can do
bicanek is offline   Reply With Quote
Old 02-01-2008, 12:27 PM   #2
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Default Interior
The interior has been getting a bit of an overhaul, since i wanted to make sure all the wiring was ok. I got a v3 sti RA motor swapped in 2005 and I've always disliked the wiring job, so I took a look for myself. It was a mess.
I had barewires everywhere, and pinouts on the ECU that weren't connected, such as the check engine light, and O2 sensor indicator wire. I removed a bunch of wiring I no longer needed, such as the ABS wiring (have yet to remove the actual ABS unit though), A/T shift lock, auto transmission wiring, and cruise control wiring. Here's what I removed:
3 pounds 11 ounces worth of wires.
I also rewired the v4 Cluster to make the DCCD indicator work with the v3 DCCD computer.
I'll take more pics of the interior later. I put back in all the dash stuff. I have some 22B front seats I'm going to install, but i want to wait until the car is painted because I don't want to risk damaging them. Here's a pic of one of the seats. It had a tear in the seat and I had to get part of it reupholstered.
Old 02-01-2008, 12:27 PM   #3
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Default Custom Metal Widebody
I'm not much of a fan of fiberglass and did not want to get a fiberglass widebody. I mean the car to be driven...somewhat roughly at times, and don't want major unremoval body panels to crack from gravel etc. I decided to pony up and get a metal widebody kit made. The guy that is doing it has done a lot of work for JIC. He does quality work, but it has been very frustrating. His vision and my own don't seem to match. I told him "22B!" and "WRC", but the results have been far from the smooth, rounded contours of the WRC look I've been going for. Instead, I have gotten agressive sharp lines, like these:
Unlike some, who have pulled out stock bumpers to meet with Do-Luck fenders, i have pushed in my widebody bumper to meet the bottom of my fenders, which don't come out as far as the top of the fenders...ugly eh?
Here's more of what I had in mind for the front (photoshopped):
In my frustration, I procured some WRC panels on loan from England and am just going to say "here! copy this!" Shouldn't be too hard, right? They arrived on tuesday, and the car is being dropped off today. Unfortunately, I got shipped off to New Mexico for work until the 8th, so I'm going to have to rely on my dad to relay what I want correctly.
Old 02-01-2008, 12:28 PM   #4
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
and saved again for a bit more pics
Old 02-01-2008, 12:34 PM   #5
Freeman
Member#: 50872
2002 Impreza WRX
dark side
nice...so what color??
Freeman is offline   Reply With Quote
Old 02-01-2008, 12:44 PM   #6
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
I'm thinking rally blue pearl. I really wanted to get a gun metal gray...but with all the 22B and WRC parts, it would be almost blasphemous not to go RBP.
Old 02-01-2008, 12:50 PM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I'm not trying to bite on your thread, but the mention of color (and that car is frikkin HOT BTW) just as an axample of a color that is close, but different
Mine is an "Infinity" blue from a G20 from a few years ago... close but much different than RBP...
Old 02-01-2008, 12:54 PM   #8
ryno50485
Member#: 79878
13' Crosstrek
ISM
Can't wait to see this project when it is completed!! keep up the good work!!
ryno50485 is offline   Reply With Quote
Old 02-01-2008, 12:55 PM   #9
Boostinwagon
Member#: 138070
2005 BoostinWagon
Looking good man keep us posted on the progress
Boostinwagon is offline   Reply With Quote
Old 02-01-2008, 12:59 PM   #10
dubya05
Member#: 91319
2005 05wrbWRX...SOLD
gas sucker yukon
suscribed!
dubya05 is offline   Reply With Quote
Old 02-01-2008, 01:02 PM   #11
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
holy crap! everything is amazing! looove the seats. i know you want some good ol usdm 04 sti seats. i'll even do ya straight trade ,being the nice guy i am
vtecTHIS is offline   Reply With Quote
Old 02-01-2008, 01:02 PM   #12
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Sweet Jesus this is going to awesome!
Sticky?
(and not just my underpants!)
Edit:
It's even a 98 (the proper year)
I forget the exact colour, but the WR cars and 22-B were not WRB or even 555 Rally blue pearl, IIRC they were a unique colour.
I vote for Rally blue w/ accompanying graphics or pure white (always something hot about WR test cars bathed in all white)
Old 02-01-2008, 01:03 PM   #13
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Not biting my thread at all. Thanks for the contribution. That's a nice color. The blue color is growing on me in general. For some reason rally blue pearl makes me hungry...I think it might be some sort of subconscious association with cotton candy.
Old 02-01-2008, 01:09 PM   #14
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
You ARE a nice guy. Haa..no way I'm getting rid of those seats though. I've been offered 2 grand for them, but I just can't do it. I'll never get the chance to import another set. Most of those seats remain on the 22B's to ensure their collector status. The guy I got all my 22B stuff in Japan was a guy I used to drive with when I lived there (we both had s13's back then). He decided to get a 22B and race it, removing a lot of the stock parts. He pulled out the door panels (which I also have), sold me the trunk lid w/ spoiler (since he's running a CF trunk with some sort of GT wing), seats, and wheels. I had to give up the seats to one of my suppliers in Japan. In return I got the genuine WRC bumper and prototype 1998 WRC hood, so I don't think I came out of the deal too badly. Anyway, that's that story...
Old 02-01-2008, 01:12 PM   #15
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
I think you're correct. I really need to figure out the color. I guess I can color match the trunk-lid, but who knows how much that may have faded. The bumper has been painted Prodrive blue to match the previous owner's car. Maybe I can flake it off and get to the original WRC paint.
Old 02-01-2008, 01:21 PM   #16
grzydj
Member#: 84984
2006 Impreza 2.5i 5D
'04 Toyota Tacoma TRD
I really hope you paint your hood to match the rest of the car. Raw carbon fiber looks horrible.
grzydj is offline   Reply With Quote
Old 02-01-2008, 01:23 PM   #17
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Haha. I am. I'm not too much of a CF fan, and I think it would look out of place. I'm going for a more WRC look. The only CF you ever see on those is all in the engine bay.
Old 02-01-2008, 01:25 PM   #18
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
You are doing what I have always dreamed of doing. I can't wait to see the final product.
SuBart is offline   Reply With Quote
Old 02-01-2008, 01:30 PM   #19
wickedscooby
Member#: 55963
99rs sti v5 LISC #57
how much did you pay for that lip?
wickedscooby is offline   Reply With Quote
Old 02-01-2008, 01:31 PM   #20
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
1 set of 22B wheels for the bumper, lip, and hood.
Old 02-01-2008, 01:49 PM   #21
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Very possibly. Does anyone know what paint code that is? I guess I should do a search before I ask.
Old 02-01-2008, 01:54 PM   #22
ahowell
Member#: 152106
'96 One More Part
For State Of The Art
I want to see how this project turns out.
Let's go-
Subscribed!
ahowell is offline   Reply With Quote
Old 02-01-2008, 02:11 PM   #23
akademiks
Member#: 36181
according to scoobynet
Sonic Blue 74F
akademiks is offline   Reply With Quote
Old 02-01-2008, 02:23 PM   #24
bicanek
Member#: 84092
1998 RS WRC replica
2015 WRX
Sonic Blue 74F
THANKS! I appreciate it. Anyone have any recommendations for type of paint?
Originally Posted by aspect View Post
Oh, and where did you get your 280km/hr cluster?
From a parts network that I am a part of in Japan. We sell used parts on consignment, strip cars in Japan and sell off the parts in Japan as well as here. I bring parts in from Japan as a side business, under Bakemono Imports on RS25, but since i don't pay for a vendor account on NASIOC, I want to keep away from advertising myself on here.
Old 02-01-2008, 02:41 PM   #25
akademiks
Member#: 36181
not OEM subaru paint
quick search on google led me to Glasurit paints:
http://www.elisauto.com/Glasurit.htm
which was recommended from here:
http://www.x5world.com/articles/x5/g...formation.html
but i'm just going from the fact bmw and other european car finishes
are usually better (someone with paint expertise please correct me) than subaru's
Pics of my now finished WRC replica. Thanx Undergroundgrfx! Hotrodguru Texas Impreza Club Forum -- TXIC 31 02-27-2004 01:34 PM
Stolen: White 22B adjustable replica wing WRX11 Mid Atlantic Impreza Club -- MAIC 0 01-08-2003 03:45 PM
FS: MRT 22B wing replica for 99-2001 Impreza yunyun Bay Area Impreza Club Forum -- BAIC 3 12-08-2001 11:54 PM
I want a Carbon Fiber 22b/WRC bumper! JoelR Interior & Exterior Modification 6 06-06-2001 12:47 AM
v5 replica wing or wrc replica on 01 sedan subaimprez01 Interior & Exterior Modification 1 05-08-2001 12:45 AM
