Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2019
Old 01-31-2015, 09:58 PM   #26
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
Hmm... where to go from here...
I say you purchase a Subaru roof vent kit and have it fitted to see how well it fits the VA cars, then let me know!
And TE37's are timeless and look fantastic on these cars. Great choice!
Shik is offline   Reply With Quote
Old 02-01-2015, 12:44 AM   #27
Stickers
Member#: 301428
2015 WRX
CWP
Hmmm.... definitely goes with the direction things are headed... (if only that fender was for sale and not something custom)
Also, thanks! Crazy watching how the TE37 keeps evolving, I wonder where they'll be going after the Ultra, hahaha.
Stickers is offline   Reply With Quote
Old 02-01-2015, 01:57 AM   #28
tempted
Member#: 157525
2015 STI
CWP
Kind of close to that fender.
tempted is offline   Reply With Quote
Old 02-01-2015, 11:22 AM   #29
Stickers
Member#: 301428
2015 WRX
CWP
Unfortunately it is a faux wide fender, and Extreme Dimensions has always made crap parts.
Old 02-07-2015, 04:03 PM   #30
Stickers
Member#: 301428
2015 WRX
CWP
Finally installed.
Old 04-10-2015, 01:31 AM   #31
underskore
Member#: 223303
2015 WRB WRX LIMITED
Package 22 6-Speed
Car looks great Alex!
Wanting to see some shots from the front but showing the amount of poke... friend of mine has a set of RE30s from his Evo X that are 18x10.5 +25 and he has them for a price so low I would be a fool not to try them on! lol I'm just curious as to how much poke yours are showing... -1.5 camber is pretty damn close to stock so that isn't a problem.
underskore is offline   Reply With Quote
Old 04-10-2015, 10:57 PM   #32
Stickers
Member#: 301428
2015 WRX
CWP
Thanks! At the moment the front end is a bit messed up from an accident, I'm waiting for someone to release a nice aftermarket option. I'll take a shot tomorrow from front on, but this angle kind of shows the poke.
With the wider wheel and lower offset you'll be pushing an extra 14mm wider than this setup, so you'll most likely need 2-3 degrees camber to stuff them under the fender, or just run mexi-poke. My fenders are rolled and pulled, you'll definitely need that as well.
Old 04-13-2015, 09:30 PM   #33
Stickers
Member#: 301428
2015 WRX
CWP
Arrow
Slightly more helpful shot.
Old 09-11-2019, 07:17 PM   #34
Stickers
Member#: 301428
2015 WRX
CWP
Four years later...
Becoming a parent and all that entails have dictated that the car get sidelined a bit for other things in life. Recently I have been able to work on the build again, including refinishing my TE37s and getting them back on the car. (hit me up if you need a set of OEM wheels with TPMS, btw)
I'm in the final stages of prep for my brake upgrade, and will be doing my best to document and see if there are any pieces of data I can provide to the community on it. I am no expert, but I figure we can all benefit from helping one another out on this. I am going to be going with West End Alignment in Gardena for the install. They've worked on my car in the past (second post is when they put my wheels on), and I trust them with getting everything buttoned up correctly.
Leftside pictures are Detective Coating, LLC. I worked with Jason and he was helpful every step of the way, including answering some questions I had about specs for a part unrelated to my powdercoating job with them. Work was completed in a timely fashion and with quality workmanship in mind. They've probably done thousands of sets of calipers at this point. Rightside pics are a different shop I worked with, as you can tell things didn't go so great.
I'm on instagram as @originalstickers if you want to chat or look at other photos of the car.
Old 09-12-2019, 01:14 AM   #35
wuuusaa
Member#: 92894
2015 Wrx
I'm a sucker for purple, i love the brembos.
Old 09-13-2019, 02:56 AM   #36
Stickers
Member#: 301428
2015 WRX
CWP
thanks! Can't wait to see what they look like against the white.
Old 09-17-2019, 01:57 PM   #37
Stickers
Member#: 301428
2015 WRX
CWP
One small note is to make sure that you prepare the holes for the pad pins. As you can see above, powdercoat will fill in the hole a bit and make it smaller.
A round file works great for the backside hole, and then some 220 grit sandpaper rolled into a tube can do the frontside one. The frontside hole jumps down to a smaller diameter, and the tip of the pad pin seats on this lip.
If you are installing your freshly powdered calipers yourself, this will save time on the day-of. If you're having a shop do it then it'll prevent them from having to take extra time to clean out the holes and charging you for the extra labor... OR preventing the shop from bashing the pins in with a mallet and then having a bad time taking them out the next time you need to change pads.
TL/DR - put all your stuff together before you reinstall. This will save you time and trouble.
