Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2019
Old 08-25-2018, 11:04 AM   #1
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Default 2JZ No *****!
Well this was the final straw for me having an EJ as a power plant. Sick of this ****.
First motor, preventatively removed and replaced with a built Outfront CDB. Outfront doesnít seat wrist pin clip fully, pin walks out, ruins block. I then get a warrantied shortblock and decide to build the heads with a full suit of GSC products. Get it all together, get dyno tuned to 616 whp and 545 wtq. Get back home and tweak tune to elevation. Make first pass on highway after completed tune. At the top of 2nd gear all hell letís go and engine seizes.
So I rip the motor apart an find that for some reason my gsc +1 mm valve has raped cylinder 3. It sent metal into the IM and into all cylinders. Wild amounts of damage. I couldnít believe it.
Build overview
-Haltech elite 2500 ecu with all bells and whistles
-Borg s364.5sx-e turbo
-Closed deck outfront block
-I beam Manley turbo tuff rods
-cp pistons
-1/2Ē studs
-GSC beehive springs
-GSC s2 billet cams
-GSC +1 valves
-heads built by outfront
-tuned on ethanol (flexfuel too)
-37psi
Engine teardown notes and supporting info
-timing was correct
-tune was good (have data log from 30 secs prior to failure)
-only issue was the one broken intake valve
-no debri wrecked the valve
-bottom end bearings fine
-no signs of det.
-cylinder did not overheat. Have egt probes in each cylinder.
-rev limit 7500 rpm
-keepers and retainers still attached to stem
Such a waste. Lol
So instead of selling the car and buying a different car, I decided to make this one into what I want. After all I love fabrication. So the car is now going RWD with a 2JZ. New engine arrives tomorrow and then the fab begins.
Iíll be posting lots of pics of the swap on my IG @lelandsti if you are interested.
I--RIDE--BIKES is offline   Reply With Quote
Old 08-25-2018, 11:08 AM   #2
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
I now have all my rear end components figured out. Doing an r200 with vlsd from a 350z with new 350z axles and hubs. Iím getting the hubs machined to accept the Subaru wheel bearing and then machine out the rear rotor slightly. They are 2 piece rotors so Iím not concerned with having to do that each time I need new rotors.
Got the diff cleaned up and painted, now just to powder coat the cover with all the other parts later.
Old 08-25-2018, 11:14 AM   #3
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
And here she is in all her glory
Old 08-25-2018, 03:02 PM   #4
gjkrisa
Member#: 461897
Is the melted metal on the Piston a melted valve or is that the Piston?
gjkrisa is offline   Reply With Quote
Old 08-25-2018, 04:51 PM   #5
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Thatís just the piston top after being pounded by the valve head at 7500 rpm.
Old 08-25-2018, 09:28 PM   #6
andyfb20
Member#: 462200
This'll be exciting to following, good luck this go!
andyfb20 is offline   Reply With Quote
Old 08-26-2018, 03:59 AM   #7
ghostismyname
Member#: 473908
Jesus, looks like someone had a bad day. But either way 2jz swap. Can't really go wrong there.
ghostismyname is offline   Reply With Quote
Old 09-01-2018, 08:26 PM   #8
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
Good luck with your build! Iíll be watching. Iím on my forth ej in 11k miles. My luck has been as good as yours.
Android287 is offline   Reply With Quote
Old 09-02-2018, 09:28 AM   #9
ThomasEFJ
Member#: 490941
Nice work. Will be following closely.
ThomasEFJ is offline   Reply With Quote
Old 09-08-2018, 08:44 PM   #10
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Hubs, axles and wheel bearings arrived and I have now cut my rad support out. It will now bolt back in and make fab work much easier. Now fully committed haha.
Old 10-06-2018, 04:22 PM   #11
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Turpid Porpoise is online now   Reply With Quote
Old 10-08-2018, 02:56 PM   #12
TabooCakeKO
Member#: 492456
cant wait to see this running!
TabooCakeKO is offline   Reply With Quote
Old 10-13-2018, 12:49 PM   #13
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Got some of the powder work completed at the shop the other day. Now to get the motor back together.
Old 10-13-2018, 06:30 PM   #14
Morroue
Member#: 492667
Default I love it
I really liked how you swapped this powerplant. Keep up the good work
Morroue is offline   Reply With Quote
Old 10-16-2018, 08:01 PM   #15
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
A big piece of the puzzle arrived today. My new close ratio Tremec T56 Magnum transmission. This thing is a beast!!!
Old 10-17-2018, 07:45 AM   #16
Turpid Porpoise
Member#: 476573
Can't wait to see your mounting solutions so I can pick your brain a bit. Just had to replace the OEM SB with an IAG block but if that goes I'll be following your lead.
Old 10-17-2018, 06:50 PM   #17
Luizwrx17
Member#: 489282
2017 WRX
That's going to be awesome!
Luizwrx17 is offline   Reply With Quote
Old 10-17-2018, 07:24 PM   #18
ssssssantimonio
Member#: 411867
2011 Impreza 2.5i
Is this nissan r200 better than the subies lsd?
ssssssantimonio is offline   Reply With Quote
Old 10-17-2018, 07:56 PM   #19
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
The diff is much stronger and larger. The viscous lsd isnít amazing and Iíll be upgrading that eventually to an aftermarket one.
Old 10-19-2018, 09:32 PM   #20
FullerJ1
Member#: 486105
2007 Impreza WRX STI
Urban Gray Metallic
Can't wait to see how well the engine/trans mounts up. BTW, the green powder coat looks sickkk!
FullerJ1 is offline   Reply With Quote
Old 10-19-2018, 10:50 PM   #21
Sboarderk03
Member#: 465407
This is insane! I'm fairly new to the Subaru community and I would've thought a lot of people would call this blasphemy but let me repeat myself, this is insane! In for the finished product.
Sboarderk03 is offline   Reply With Quote
Old 10-20-2018, 11:58 AM   #22
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Thx everyone. Lots of work ahead though. The idea is to make this a clean and highly functional setup with tons of reliable power
Old 10-20-2018, 11:59 AM   #23
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
New vs old diff for comparison.
Old 10-22-2018, 12:41 AM   #24
PO Blobeye
Member#: 493041
This looks like it will be crazy! Can't wait to see the finished product.
PO Blobeye is offline   Reply With Quote
Old 10-24-2018, 04:29 AM   #25
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
sub'd.
JDMJNKY is offline   Reply With Quote
