04-20-2017, 12:14 PM | #26 |
Vendor Sales Rating: (7)
Member#: 228856
South East
Beefy ProCross ProCool LA Sleeve cylinder liners fitted in this ML700 spec block for our customers GTX3582r equipped STi on E85! Thanks, Alex [email protected]
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] |
04-21-2017, 09:51 AM | #27 |
Member#: 228856
South East
The Manley Performance H-Tuff 4340 Forged rods peaking out of the wrist pin service plug. The H-Tuff connecting rod is featured on our ML500+ spec block, a favorite for customers building for power anywhere between 350-550HP! Thanks, Alex [email protected]
__________________
04-24-2017, 03:03 PM | #28 |
Member#: 228856
South East
Out with the old! This customer dropped off last Friday to get his new ML500+ spec shortblock installed along with a Cobb flex fuel kit and a Dom1.5XTR turbo upgrade. Should be a fun and reliable street car! Thanks, Alex [email protected]
__________________
04-25-2017, 05:21 PM | #29 |
Member#: 228856
South East
New ML700+ spec closed deck block ready to ship out and make some power for our customer in California! Thanks, Alex
__________________
04-26-2017, 09:17 AM | #30 |
Member#: 228856
South East
The BEEFY Manley H-Tuff rod featured in our popular ML500+ never disappoints for the 425-550WHP builds. Thanks, Alex [email protected]
__________________
05-01-2017, 09:43 AM | #31 |
Member#: 228856
South East
The shops 2006 STi is going back under the knife. This was the last iteration of the build finished up a few years ago. We will be swapping out for a Borg Warner EFR9174 and are trying out something new with the shortblock that will hopefully allow for more displacement than has ever been achieved before. You can see more build details on our website! http://www.motionlabtuning.com/alex-2006-subaru-sti/ Thanks, Alex [email protected]
__________________
05-03-2017, 05:11 PM | #32 |
Member#: 228856
South East
ML700 + ML Stage 2 heads + Kelford 220-D + PTE 6466 = good fun. These results are on pump gas. Thanks, Alex [email protected]
__________________
05-04-2017, 03:23 PM | #33 |
Member#: 228856
South East
ML700 Plus Closed Deck shortblock: The ML700+ offers superior strength over our standard ML700 spec engine by upgrading the factory cylinder block with a closed deck conversion. For the ML700+ we utilize the same high quality Manley Performance "TurboTuff" components that we do in the standard ML700 engine. It offers their 1000HP rated "TurboTuff" rod set forged from aircraft quality 4340 degassed material. Each rod is shot peened and magnafluxed after final machining. In combination with the "TurboTuff" rods we are using the latest "TurboTuff" piston design as well superior to the traditional "Platinum Series" pistons found on our ML500 and ML500+ spec blocks. By incorporating proven design enhancements from their "Formula-Won" strutted piston forging they have created the ultimate piston for your Subaru. Like their "Platinum Series" pistons these feature a off-set wrist pin, TotalSeal ring pack, chromoly 2.500x.180 premium wrist pins, and anti-friction skirt coating right out of the box. Fully blueprinted and assembled to our strict specifications using King XPG Race bearings in a clean climate controlled facility.
Recommended Power: Up to 800whp - Manley Performance "TurboTuff" 4340 Forged I-Beam Rods - Standard ARP2000 Rod Bolts - ML-Spec King XPG Race rod bearing clearances - Manley Performance "TurboTuff" 2618 Forged Pistons - Choose 8.5:1 (or) 9.8:1 Compression Ratio - Anti-friction skirt coating - Off-set wrist pin - "Formula-Won" strutted piston design - Thicker skirt wall versus traditional "Platinum Series" piston design - Standard Chromoly Wrist Pin (2.500"x.180" wall) - New Subaru OEM Factory Block - Closed deck conversion - Bored and honed to 99.75MM - Seal kit can be purchased separately (Seal kit includes: 3x wrist pin plugs, 3x wrist pin plug washers, 1x separator cover, 6x separator cover bolts, 1x wrist pin service cover, 1x wrist pin service cover O-ring, and 2x wrist pin service cover screws) - New Subaru OEM Induction Hardened Crankshaft - ML-Spec King XPG Race main bearing clearances Customer to pay extra for shipping. Please call or email to arrange installation or local pickup. Thanks, Alex [email protected]
__________________
05-05-2017, 09:30 AM | #34 |
Member#: 228856
South East
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] Last edited by Motion Lab Tuning; 05-05-2017 at 09:40 AM. |
05-09-2017, 01:59 PM | #35 |
Member#: 228856
South East
Another one coming together. ML500+ spec shortblock, stock heads, ID 1300cc injectors, Cobb flex fuel, and a Dom 1.5XTR will make a badass street car! Thanks, Alex [email protected]
__________________
05-16-2017, 11:11 AM | #36 |
Member#: 228856
South East
__________________
05-17-2017, 04:10 PM | #37 |
Member#: 228856
South East
ML700 with our Stage 0 head refresh going together. Blouch 20G-XTR for now until its time for rotated turbocharger fun. Thanks, Alex [email protected]
__________________
05-18-2017, 12:22 PM | #38 |
Member#: 228856
South East
Billet TGV's and Billet compressor wheels make a great match with any Pro-built engine! Thanks, Alex [email protected]
__________________
05-23-2017, 11:08 AM | #39 |
Member#: 228856
South East
Manley Billet crank arriving for a ML1200 spec build. This beautiful crank is available as an upgrade to our ML700+ spec engine, and included standard in the ML1200. Thanks, Alex [email protected]
__________________
05-24-2017, 11:06 AM | #40 |
Member#: 228856
South East
Manley Performance RaceFlo valves used in our Stage 1 and 2 cylinder head packages. Thanks, Alex [email protected]
__________________
05-25-2017, 11:06 AM | #41 |
Member#: 228856
South East
__________________
05-31-2017, 12:23 PM | #42 |
Member#: 228856
South East
__________________
06-02-2017, 05:03 PM | #43 |
Member#: 228856
South East
Our Stage II FA20 block offers a closed deck conversion for superior strength without the costs of installing aftermarket cylinder sleeves. Great for those building for over 500WHP! Thanks, Alex [email protected]
__________________
06-06-2017, 11:58 AM | #44 |
Member#: 228856
South East
Another ML700+ closed deck build going down with our Stage 2 heads. Getting torn down now, will be reassembled with a ETS turbo kit and a bunch of other goodies. Should be a solid 700+WHP all said done! Thanks, Alex [email protected]
__________________
06-07-2017, 05:25 PM | #45 |
Member#: 228856
South East
__________________
06-12-2017, 11:19 AM | #46 |
Member#: 228856
South East
__________________
06-13-2017, 09:05 AM | #47 |
Member#: 228856
South East
Manley Billet crank. This beautiful crank is available as an upgrade to our ML700+ spec engine, and included standard in the ML1200. Thanks, Alex [email protected]
__________________
06-14-2017, 05:17 PM | #48 |
Member#: 228856
South East
__________________
06-15-2017, 12:10 PM | #49 |
Member#: 228856
South East
Keith's 2015STi looking good in the shop with a ML700 spec engine and our Stage 2 heads with Kelford 220-C cams. Making 650WHP on a GTX3582R ETS rotated turbo kit and intercooler kit! Thanks, Alex [email protected]
__________________
06-16-2017, 10:55 AM | #50 |
Member#: 228856
South East
__________________
