Welcome to the North American Subaru Impreza Owners Club Monday November 19, 2018
Old 09-28-2018, 11:48 AM   #1
Bananana
Member#: 492040
Default Feedback Knock Correction -3.85 on WOT 2011 wrx GR
I have been trying to help out my good ol buddy with his wrx, if anyone could give some insight it would help alot, I also own a wrx GR but im also puzzled as to why he is experiencing knock. His car is protuned.
So first things we did was clean the maf sensor (still knocking). Theres a heatshield rattle from the exhaust manifold but never registers a knock when its audible on lower rpms so we dont think its that. He always uses 93 octane BP gas (top tier). I helped him log the following below:
First two logs are 3rd gear WOT, and last log is gradually getting into higher RPM range but staying out of boost. Have a good one all!
https://docs.google.com/spreadsheets...gid=2075658681
https://docs.google.com/spreadsheets...#gid=419546339
https://docs.google.com/spreadsheets...gid=1678070106
Bananana is offline   Reply With Quote
Old 09-28-2018, 02:07 PM   #2
86Dreams
Member#: 385256
V7 S204
Taking it that this is a new phenomena? is there oil in the tmic, maybe? how are the fuel trims? have you tried replacing the engine fuel filter?
86Dreams is online now   Reply With Quote
Old 09-30-2018, 02:22 AM   #3
Bananana
Member#: 492040
We haven't had a chance to check it out the TMIC yet but will do some hopefully, havent changed the fuel filter, car didnt seem to hesitate at all. I dont think he is monitoring fuel trims
Old 09-30-2018, 04:42 PM   #4
PDXREALTOR
Member#: 468393
2017 STI
Hard to read the logs on my phone, but, throw some octane booster in the car. Real stuff, not the crap stuff. You can use xylene and the online calculator or, find some torco or similar.
PDXREALTOR is offline   Reply With Quote
Old 09-30-2018, 06:51 PM   #5
Jersey Man10
Member#: 427632
Get with his tuner. Also those pulls arenít even to redline wtf.
Jersey Man10 is offline   Reply With Quote
Old 10-13-2018, 02:11 AM   #6
Bananana
Member#: 492040
new log, just driving in third and then knocks -4.20....Log attached, first instance of knock starts at line 55. Really need help because i don;t know anymore what else i can do to diagnose...All that is left is to check pre-turbo inlet leaks.
https://docs.google.com/spreadsheets...it?usp=sharing
Old 10-13-2018, 02:12 AM   #7
PDXREALTOR
Member#: 468393
2017 STI
Did you put octane booster in? How much and what kind if so?
Old 10-13-2018, 02:22 AM   #8
Bananana
Member#: 492040
No octane booster was put in. Car is tuned for 93 octane and we are running 93 octane shell v powered..not sure how octane booster would help fix this issue.
Old 10-13-2018, 02:35 AM   #9
PDXREALTOR
Member#: 468393
2017 STI
If you put a quality octane booster in and it doesn't knock you know you have a mechanical or tuning issue.
If it does still knock you know you have a false knock issue.
I run hybrid boost and haven't tuned any turbo dynamics, but, that's the only thing that stood out in your last log. I forgot to look at timing. But, doubt that's it.
Your at low load, low throttle pos, and the knock happens right as you enter boost. I've been there and it was super easy to go to home depot and get some xylene for the tank. Turned out, my car didn't like the lightweight crank pulley.
Putting in 100 octane proved it was false knock. I took the last item I put on, off and.... Problem solved.
Youre asking for help..... I suggested octane booster. Take it or leave it.... Maybe someone else will chime in.
Old 10-13-2018, 04:06 PM   #10
Bananana
Member#: 492040
If you put a quality octane booster in and it still knocks you know you have a mechanical or tuning issue.
If it doesn't knock you know you have a false knock issue.
Im not familiar with octane boosters as i have never used them, is it ok to use on quarter or less tank, just so it doesnt linger in the fuel tank for too long. The last thing the car had replaced was a drop in filter from cobb, same filter as old one because it got dirty, chances of that being the culprit imo is really small, but who knows....
Old 10-13-2018, 04:40 PM   #11
PDXREALTOR
Member#: 468393
2017 STI
Here's a mix chart. http://www.gnttype.org/techarea/misc/octanebooster.html
Old 10-13-2018, 06:53 PM   #12
Jersey Man10
Member#: 427632
What mods are on the car besides the tune?
Old 10-19-2018, 12:57 PM   #13
Bananana
Member#: 492040
downpipe, intake, ewg, ebcs
Old 10-26-2018, 01:16 PM   #14
Bananana
Member#: 492040
I should be getting my torco tomorrow, quick question as it seems a common side effect of this product is it leaves an orange residue on sparkplugs, should I be worried about this?
Old 10-26-2018, 03:10 PM   #15
PDXREALTOR
Member#: 468393
2017 STI
No. I run 3oz torco per gallon 100% of the time. All my internals are orange.
Old 10-26-2018, 03:37 PM   #16
GlarryHoodDIT
Member#: 460907
2016 WRX
If you run an octane booster and raise your octane level and stop knocking couldn't that just indicate the tune is too aggressive for the current gas being used? Why is it automatically false knock? If you raise your octane from 91 to 93 and stop knocking couldn't that be the reason? A higher octane not that it was false knock?
GlarryHoodDIT is offline   Reply With Quote
Old 10-26-2018, 03:49 PM   #17
PDXREALTOR
Member#: 468393
2017 STI
That's the point. Raise the octane and if the knock goes away its likely a tune or mechanical issue.
If knock remains - its likely false.
*likely*
Old 10-26-2018, 04:02 PM   #18
GlarryHoodDIT
Member#: 460907
2016 WRX
Oh ok. That's just the exact opposite of what you first posted. Unless I misunderstood.
Old 10-26-2018, 04:10 PM   #19
PDXREALTOR
Member#: 468393
2017 STI
No, I miss-typed. My mistake, good catch!
Old 10-27-2018, 01:30 AM   #20
chukiichuu
Member#: 303157
So just to confirm after reading this thread im a little confused, put in octane boostet if A. Knock goes away its tune or possibly lose clamp/engine damage or if B. Knock remains its false knock anything from a heatshielf rattle to who knows? I have a loose heatshield and wanna make sure this wont happen to me lol....
chukiichuu is offline   Reply With Quote
Old 10-27-2018, 03:04 AM   #21
GlarryHoodDIT
Member#: 460907
2016 WRX
Correct.
If you're running 91 octane gas and you start getting knock, then you raise your octane (via torco or xylene) to 93 and you don't get knock anymore, then it's likely the tune was too aggressive or there is a mechanical issue with your motor. Octane = measurement of a fuel's resistance to knocking. So if you add more octane and the knock goes away then that was likely the problem.
If in the same situation, you're running 91 and you start getting knock, then you raise your octane and you still get knock, then it's likely not an octane or mechanical issue but likely false knock. If it was due to aggressive tuning or a mechanical problem then raising the octane would mitigate it. If it's a problem like a heat shield rattling, then no matter how high you raise your octane rating it won't matter because it's the noise of the rattle setting off the knock correction not actual knock.That would be false knock.
Obviously this isn't 100% fool-proof, just because you add torco and the car still knocks doesn't mean it's definitely false, the tune could still be too aggressive or something. But this is an easy way to check without ripping your engine apart.
Old 10-31-2018, 12:20 AM   #22
RolyatMusic
Member#: 493126
Unhappy feedback knock at WOT
https://docs.google.com/document/d/1...it?usp=sharing
i didnt do a redline pull but its most likely enough to see whats wrong or get to somewhere. what do you think it could be? its not bad fuel becuase ive been going to all shell stations and its all 92 v power. and i just tightened all my hose clamps for boost leaks too...
RolyatMusic is offline   Reply With Quote
