Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 07-06-2017, 11:54 AM   #1
veritasaequitas
Member#: 333964
2005 sti
aspen white
Default Fp blue
Not a lot of information out there about the fp blue. I know junior had got one to try out with prime motoring. Anyone have it? What's your take on it?
veritasaequitas is offline   Reply With Quote
Old 07-06-2017, 01:08 PM   #2
Stags4
Member#: 423480
JR Tuned Review:
Our Project Toilet Bowl (2000 Outback sports) hit the dyno today to do some testing on the new Forced Performance TurbochargersBlue stock location bolt on turbo. We have had it for weeks to test at the track, but the weather has really ****ed that up for us. So we decided to thrown it on the dyno and see what kinda of numbers it could produce. Full boost by 3800rpm and able to hold 27-28psi to redline(7200) This thing spools like the HTA71 but makes power like a HTZ Green
Pumpgas 93 = 430whp / 445tq E85 = 524whp / 527tq
Prime Motoring 2.5 Hybrid built by VinceBuilt Stock 2.0 cams/heads with IAG chambering GrimmSpeed 44mm external uppipe Grimspeed TMIC IAG Performance AOS IAG TGVD COBB Tuning v3 accessport SD with a JrTuned calibration =) SouthBay Fuel Injectors Inc 1600cc Injectors
Stags4 is offline   Reply With Quote
Old 07-06-2017, 06:28 PM   #3
veritasaequitas
Member#: 333964
2005 sti
aspen white
Originally Posted by Stags4 View Post
JR Tuned Review:
I saw this but was looking for anyone else who has the turbo who could comment on how they like it.
Old 07-09-2017, 09:27 AM   #4
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
I wish my customers were on here, we've been stocking them and they seem to be fp's most popular now a days. I will see if i can contact them to report their results back. I know one is still building his engine right now.
IMPORTIMAGE is offline   Reply With Quote
Old 07-09-2017, 11:27 AM   #5
veritasaequitas
Member#: 333964
2005 sti
aspen white
That would be awesome. Thank you
Old 07-09-2017, 10:30 PM   #6
Delphi
Member#: 239335
Taking a built motor 2009 wrx to get dyno tuned on Thursday with an FP Blue. Ill report what it does.
Delphi is online now   Reply With Quote
Old 07-09-2017, 10:34 PM   #7
Helloimethan08
Member#: 429209
2007 wrx sti
ugm
im protuned (etuned) by eric at torqued performance on the fp blue using the cobb v3. Currently running 20psi on my 07 sti and it pulls perfect i'm more then happy with this setup, i cant wait to push it farther when my block is done. since its road tuned i dont have any numbers at this time.
current mods:
intake
uel header
1000cc injectors
ebcs
fmic
3in catless turboback
walbro 255
recirculating bov
Helloimethan08 is offline   Reply With Quote
Old 07-10-2017, 08:16 AM   #8
veritasaequitas
Member#: 333964
2005 sti
aspen white
How is the spool? What turbo were you using before and how does it compare
Old 07-12-2017, 02:53 AM   #9
Helloimethan08
Member#: 429209
2007 wrx sti
ugm
i have full spool by 3900rpms, coming from the stock vf43, its a HUGE improvement
Old 07-12-2017, 08:10 AM   #10
veritasaequitas
Member#: 333964
2005 sti
aspen white
Awesome thanks for the response. If you have a dyno sheet could you put it up. I think I'm going to go with the fp blue and I'll try and upload my dyno sheet once I get it
Old 07-17-2017, 09:02 AM   #11
Delphi
Member#: 239335
There is only a 7psi spring in the WG Airboy Tuning was only able to hold 15-15.5 psi to red line. Also in Edmonton where the customer is from he gets full spool by 4200 RPM
Car: 2009 WRX
Temperature: 100F
Altitude: 3500 ft
Tuner: Sunny
Dyno: Dyno Dynamics
Transmission: Stock 2009 5 Speed
Gear: 3rd
Peak hp at rpm: 319 whp @ ~6100 rpm
Peak tq at rpm: 312 wtq @ ~5,100 rpm
Baseline for stock STi: 2012 STI 222 whp
Target boost: 17 PSI @ 4400
Fuel: Husky 94
Mods
TGV Deletes
Air Pump Deletes
DW1000's
Cobb Inlet
Tomei ELH
Grimmspeed EWG Upipe with Turbosmart 40mm
Manley H-Tuff Rods
Manley Forged Pistons
ARP Headstuds
FMIC
Old 07-19-2017, 10:41 AM   #12
veritasaequitas
Member#: 333964
2005 sti
aspen white
Awesome thanks for the response. My blue is on order so will update once I am done
Old 07-19-2017, 01:47 PM   #13
Delphi
Member#: 239335
No problem.
I have no doubt this turbo spools 3800-4000 rpm at sea level.
I forgot to put in my post (edited it now) that it was 100F in the dyno room.
I think it is a pretty solid turbo for the cost especially.
Old 07-19-2017, 09:07 PM   #14
Helloimethan08
Member#: 429209
2007 wrx sti
ugm
there is a dyno day coming up next month that i might be attending,its a low reading dyno, but im also at a pretty low elevation(around 400-500'), so we shall see how it does, lets just hope its not 100 degrees out that day, im pretty confident ill be at leas in the mid 300s
Old 08-18-2017, 08:07 PM   #15
jershelb
Member#: 312623
Any other updates here? I am really close to pulling the trigger on one of these, but would really feel better if I could hear some consistent feedback.
I have a 2013 wrx and would really like to see between 350-400 (mustang-dynojet) whp on 93 octane.
Graphs and feedback welcome!
jershelb is offline   Reply With Quote
Old 08-19-2017, 09:33 AM   #16
veritasaequitas
Member#: 333964
2005 sti
aspen white
I'm in the process of installing mine with ewg and new tmic. I'm hoping to be done worth all the moc up and welding is done
Old 08-19-2017, 07:44 PM   #17
That1sti
Member#: 430936
What do you think about FP blue with a meth kit?? On 93 pump with all the supporting mods
That1sti is offline   Reply With Quote
Old 08-19-2017, 07:46 PM   #18
That1sti
Member#: 430936
Default Fp blue on meth??
Has anyone run a fp blue on meth??
Old 08-23-2017, 07:04 PM   #19
linkubus06
Member#: 335449
07 WRX 20G 6MT
11 335i RWD 6MT
What do you know about blue meth?
linkubus06 is offline   Reply With Quote
