Welcome to the North American Subaru Impreza Owners Club Tuesday May 22, 2018
Old 07-17-2017, 11:08 AM   #6876
_wrxlr8r_
Member#: 108886
2017 sti
Good work CV888. This gives me a great preview. I have the same size TE37 SAGA in diamond dark gunmetal waiting to go on. I just need to pick up ohlins r&t coilovers.
_wrxlr8r_ is offline   Reply With Quote
Old 07-17-2017, 02:27 PM   #6877
CV888
Member#: 469394
Originally Posted by alvinli217 View Post
Aren't you rubbing at all in the rear?
I was rubbing a little bit on the rear close to bumper area running 18 x 9.5 +38 with 265/35/18 Cup2 tires
grind a little bit of the bumper and i was fine without rubbing
thats exactly what i did plus went up a little higher on height
CV888 is offline   Reply With Quote
Old 07-17-2017, 02:28 PM   #6878
CV888
Member#: 469394
thats nice man what size tires are you putting?
Old 07-17-2017, 04:28 PM   #6879
_wrxlr8r_
Member#: 108886
2017 sti
265/35 as well. 275 and 285 would be nice but more fender work than I want to do at this point. Good to see 265 is doable with just a proper drop, roll, grind and alignment
Old 07-17-2017, 04:43 PM   #6880
schkemy182
Member#: 415820
2015 WRX Limited
What part of the bumper are you grinding? I have the same 18x10+35 (ZE40s though) with a 265/35 with my fenders rolled and I still rub in the rear on occasion.
schkemy182 is offline   Reply With Quote
Old 07-17-2017, 04:58 PM   #6881
_wrxlr8r_
Member#: 108886
2017 sti
I imagine it's the area where the bumper and fender join. CV888 is that the part you removed or clipped back a bit?
Old 07-17-2017, 06:15 PM   #6882
M3lover1
Member#: 440553
2017 WRX STI Base
I just installed Gram Lights 57dr 18x9.5 et38 with Michelin PSS 265/35. The rears do rub if I hit dips on freeways. Need to get rear fenders rolled. Have RCE Yellow springs and rear LCA's installed.
M3lover1 is offline   Reply With Quote
Old 07-18-2017, 02:06 AM   #6883
alvinli217
Member#: 133236
2016 WRB STi
04 WRB STi-GONE
Cool, thanks for your info!
alvinli217 is offline   Reply With Quote
Old 07-18-2017, 08:56 AM   #6884
CV888
Member#: 469394
you are correct. just grinded a bit and now no more rub
Old 07-18-2017, 08:59 AM   #6885
CV888
Member#: 469394
Originally Posted by jdmct9mr View Post
Will do! The anticipation is killing me! I've been debating on getting the center cap adapters but it's a bit tough to spend so much extra just to use center caps.
the thing i dont like about not having center caps is after you wash your car, water deposit in there so i use a blower to make sure it dries
Old 07-18-2017, 03:16 PM   #6886
M3lover1
Member#: 440553
2017 WRX STI Base
Just a quick picture after install. Car is sitting at home couple days for now because the rears do rub a bit if I hit a dip on the freeway. Getting the rears rolled Wednesday night and hope that is enough, and not need a pull.
Gram Lights 57dr 18x9.5 +38
Michelin PSS 265/35/18
RCE Yellows with Superpro Rear LCA's.
-1.8/-2.7 f/r camber.
Old 07-18-2017, 10:14 PM   #6887
CV888
Member#: 469394
Default 2015 WRX/STi Aftermarket wheel and tire fitment
for those that changed onto a wider wheels, how would you describe the handling of your car compared to stock?
Old 07-18-2017, 10:30 PM   #6888
aniltip
Member#: 394300
2015 WRX Limited
Dark Gray Metallic
Haven't noticed much of a difference between the 18x8.5s from a 2013 STI and 18x9.5s that I run now (Done 1 autox on each set), though I would't call myself the most experienced autocrosser either.
aniltip is offline   Reply With Quote
Old 07-19-2017, 06:10 AM   #6889
jdmct9mr
Member#: 289223
2015 STI
CBS
Good point. I'll make sure to use my air compressor after a wash. I hope my wheels ship by Friday.
jdmct9mr is offline   Reply With Quote
Old 07-19-2017, 12:57 PM   #6890
kaeknows
Member#: 357191
2016 WRX
ISM
kaeknows is offline   Reply With Quote
Old 07-20-2017, 12:59 AM   #6891
ohemgii
Member#: 457165
Originally Posted by JeffrWRX View Post
Changed my suspension, wheels, and tires up...
WedsSport TC105n 18x9.5 +35
Michelin PSS 255/35/18
Swift Spec-R's
Untitled by Jeff Ruhl, on Flickr
I literally just ordered the same spec wheels and swift springs. I'm new to this whole modifying game, so quick question... did you have to install anything else like the LCAs, camber bolts, etc? I'm loving the way your car sits and I can't wait to install all my stuff! 😁
Edit:I also have a base model and I was told it sits different than the limitednor premium... which is why I also got springs
ohemgii is offline   Reply With Quote
Old 07-20-2017, 08:43 AM   #6892
16subaruwrx
Member#: 468378
Looking to run a 18/9.5 +38 wheel with rce yellows I've read that 255/35s fit without any issues but has anyone run 265s on this setup. Do you need to roll the fends or get LCAs etc
16subaruwrx is offline   Reply With Quote
Old 07-20-2017, 09:13 AM   #6893
Profoxcg
Member#: 169036
2015 STI
I wonder if the car above is sticking out a bit. mine is w the same wheels and offset...
Profoxcg is offline   Reply With Quote
Old 07-20-2017, 10:39 AM   #6894
itsmet
Member#: 450552
This is my setup just got it aligned Volk ZE40 18x10 +39, Tires 255/35/18, Rear fenders rolled.
I actually have SPC rear LCAs so I'm running OEM camber and toe. No rubbing issues.
itsmet is offline   Reply With Quote
Old 07-20-2017, 11:48 AM   #6895
kaeknows
Member#: 357191
2016 WRX
ISM
^ze40's ftw
Old 07-20-2017, 01:23 PM   #6896
CV888
Member#: 469394
mine feels like its floaty and soft? you think the tires are causing this?
Old 07-20-2017, 02:14 PM   #6897
M3lover1
Member#: 440553
2017 WRX STI Base
Mine rubs. I just put on 57dr 18x9.5 +38 with PSS 265s, also on RCE Yellows. The rear rubs, I got a roll yesterday, and its better, but the passenger side still rubs, so will have him massage it a bit more. I also have LCAs. The PSS do run wide and very square though, so that might be an issue as to why mine rubs. I have seen others on 265s with same size wheels that don't seem to rub, so experience may vary.
Old 07-20-2017, 06:13 PM   #6898
brianforte98
Member#: 471406
I have a 17 WRX, currently running stock wheels/suspension. I'm looking to make changes to both at once by going with some RCE Yellows & 18x9.5 +38 wheels. I'm curious as to what size tires I can run with this (as close to square setup as possible) without fender rolling/rubbing issues, and what people think of the RCE yellows on rough-ish roads. What I'm seeing a lot of is 265/35 or 255/40?
brianforte98 is offline   Reply With Quote
Old 07-20-2017, 07:37 PM   #6899
16subaruwrx
Member#: 468378
Thanks I'm probably just gonna go with 255s
Old 07-20-2017, 09:44 PM   #6900
aniltip
Member#: 394300
2015 WRX Limited
Dark Gray Metallic
Could be, I'm ran the same tires on both sets (just unmounted and remounted) and didn't notice a big change. What tires did you run?
