Welcome to the North American Subaru Impreza Owners Club Monday April 23, 2018
Old 11-28-2016, 08:45 PM   #1
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Default New fp blue htz
Somebody have this ?
68hta/71hta... Now 73htz ? Flow 57lbs, green htz is 61lbs/min
I want to replace my 18g xtr... 2.5 build engine and full bolt-on on 94. I want something near 375 whp on a mustang, im about 345whp right now.
Htz blue or green for 769$ or 1.5xtr for 1500$
Help please!
Thanks
alakazoo22 is offline   Reply With Quote
Old 11-28-2016, 08:50 PM   #2
Delphi
Member#: 239335
2011 WRX
Get the Green so you don't run the car on the ragged edge to hit the power you want.
Delphi is online now   Reply With Quote
Old 11-30-2016, 09:53 PM   #3
whoioncewas
Member#: 452971
2008 STi
The Blue HTZ, to me, looks a lot like a journal bearing GTX3071R equivalent. The 'new' FP54 turbine they advertise is roughly the size of the standard GT30R turbine and while the Blue's compressor wheel is 73mm, it looks to be rated (in lb/min) roughly the same as Garrett's 71mm GTX wheel. I'd expect somewhere around 350+ whp on a Mustang dyno on pump gas. Their website shows a 2.1 making ~355 on pump and 408 on E85, Mustang dyno.
That said, for the numbers you want, go Green HTZ. Unless you are convinced you absolutely 'need' a ball bearing turbo, skip the Blouch. I've never been all that impressed with their performance to cost ratio.
I'm planning on running either the Green HTZ or Blue on my '08 STi. I've leaning towards the Blue as I'm a fan of the GTX3071R as is and it looks like it will spool better than the Green HTZ without making a whole lot less power. That said, I've seen 440whp on a Dynojet out of a Green HTZ on 91 octane, which would be ~387whp on a Mustang. If you can deal with full spool around 4k, then you cannot go wrong with the newest Green.
whoioncewas is offline   Reply With Quote
Old 12-01-2016, 01:35 AM   #4
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Thanks for sharing this !
Old 12-02-2016, 06:52 PM   #5
whoioncewas
Member#: 452971
2008 STi
No problem.
Old 01-30-2017, 07:46 PM   #6
scottD
Member#: 94748
Has anyone else run the blue yet?
Some promising new info posted at FP.
"JR Tuned Review of the Blue including dyno sheet above.
Our Project Toilet Bowl (2000 Outback sports) hit the dyno today to do some testing on the new Forced Performance TurbochargersBlue stock location bolt on turbo. We have had it for weeks to test at the track, but the weather has really ****ed that up for us. So we decided to thrown it on the dyno and see what kinda of numbers it could produce. Full boost by 3800rpm and able to hold 27-28psi to redline(7200) This thing spools like the HTA71 but makes power like a HTZ Green
Pumpgas 93 = 430whp / 445tq E85 = 524whp / 527tq"
scottD is offline   Reply With Quote
Old 01-30-2017, 08:24 PM   #7
xyzyx00
Member#: 451168
good info! ive been eyeballing the new fp blue too, going back and forth between the green and the blue. The 440 on the Green w 91 that youve seen, how much boost was that?
thanks
xyzyx00 is offline   Reply With Quote
Old 02-10-2017, 12:30 PM   #8
stivf48
Member#: 453767
2011 STI Hatch
Blue/Purple
Default FP Blue will be installed in March 2017
Hi guys i am here in Toronto and I got a FP Blue and i will be installing it in March
Neetronics will do the job for me and Tune also
My Goal is 94 Oct 340 to 350 WHP with a good spool, i will post my results here
Wish me luck
stivf48 is offline   Reply With Quote
Old 02-10-2017, 12:56 PM   #9
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
I went with the Green and am pulling 370hp and 370ft-lbs on 91 and 420/411 on E60 winter blend. Im limited by injectors, MAF and my transmission right now. I'm only at 18psi of boost right now on both fuels. Im making full boost by 4300 rpm.
sub2010ss is offline   Reply With Quote
Old 02-11-2017, 02:53 PM   #10
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Wish me luck
340 to 350.. I think that will be easy. I do 348 on a 18G xtr at 18.5 psi
18g xtr is a 43lbs/min vs blue 57lb/min
Old 02-11-2017, 02:54 PM   #11
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Which injecteur, maf size ,5speed ?and dyno jet ?
Old 02-11-2017, 08:14 PM   #12
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Id1000's, I have a turboxs CaI which I believe is 2.4", so small, stock 5 speed and dynoed on a a dynojet.
Old 02-13-2017, 09:46 AM   #13
tomkun
Member#: 244028
2011 base WRX
I wonder how that will compare to the don 1.5xtr.
tomkun is offline   Reply With Quote
Old 02-13-2017, 10:13 AM   #14
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
57lbs vs 48lbs/min ?
Maybe on 91/93 will be around the same but on E85.. I never saw 1.5 at 545 whp..
Old 03-16-2017, 08:57 PM   #15
stivf48
Member#: 453767
2011 STI Hatch
Blue/Purple
Up date on my Dyno
March 16th 2017
List of mods
injectors 1000cc
Fuel pump
Headers
Downpipe
Intake
Turbo out let
TGV Delete
Turbo FP Blue 19 PSI
320 WHP 351 WTQ
I don't have a Exhaust, just a cut of valve and this is the reason i did not get abou 330 to 340 WHP on the top end , but i can tell one thing,my car drives amazing and is almost no turbo leg i love it, there is about 40 to 55 WHP between 4000 RPM all the way to 6700 RPM i could not be more happy
Old 03-16-2017, 09:16 PM   #16
stivf48
Member#: 453767
2011 STI Hatch
Blue/Purple
Up date on my Dyno
March 16th 2017
List of mods
injectors 1000cc
Fuel pump
Headers
Downpipe
Intake
Turbo out let
TGV Delete
320 WHP 351 WTQ
I don't have a Exhaust, just a cut off valve and this is the reason i did not get abou 330 to 340 WHP on the top end , but i can tell one thing,my car drives amazing and is almost no turbo leg i love it, the is about 40 to 55 WHP between 4000 RPM all the way to 6700 RPM i could not be more happy
Old 03-16-2017, 09:17 PM   #17
stivf48
Member#: 453767
2011 STI Hatch
Blue/Purple
Old 03-16-2017, 09:20 PM   #18
stivf48
Member#: 453767
2011 STI Hatch
Blue/Purple
Default Pictures explained
First was my stock turbo
second is the FP Blue
Old 03-17-2017, 07:22 AM   #19
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
19 psi but on 91 or 94 ?
40 whp gain but no wtq ? You need catback !!!
Old 03-17-2017, 07:49 AM   #20
igotboostpower
Member#: 280693
15' Launch Edition
WRB on Gold BBS
yea something is off man, my 71hta (not the new HTZ center section from xona) made with your same mods, 368hp on 93 and 416 on ethanol. Also I ran out of injector on e85, Nate said I should have been able to hit 425 reliably on their mustang dyno. Also I have ej255 heads on my LGT not the better flowing 257 heads like the sti
igotboostpower is offline   Reply With Quote
Old 03-17-2017, 10:54 AM   #21
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
He dont have a catback. So it dont help to make power with stock one
Old 03-17-2017, 07:26 PM   #22
turboo sti
Member#: 418229
I would of thought your numbers would of been higher even without a catback
turboo sti is offline   Reply With Quote
Old 03-17-2017, 07:36 PM   #23
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Big restriction = low number ?
Old 03-17-2017, 10:51 PM   #24
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Haha, I made 370hp on 91 with stock cat back. Cant be that bad of a restriction. And that was at 18#
Old 03-18-2017, 08:13 AM   #25
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
I said that because my axelback was completly destroyed and blocked inside and I lost about 50whp.. cannot pass 300 whp. Maybe he have a leak or something.
