Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 11-08-2017, 01:36 PM   #1
deadstockpomp
Member#: 292520
13 WRX STI limited
Default Diy alignment
I’m in the process of making a diy alignment system so I can adjust toe at home. So far I have 4 square cuts of a plank about 16 inches by 8 for the slip plates. Each piece of plank has a sheet of plastic plywood nailed to it which is used to form concrete decks so some oil will make the surface slippery.
I also have 4 pipe hangers with 4 pieces of threaded rod. Each wheel will have 2 pipe hangers threaded to the front and backside of the wheel making it “square”
This is still all on top of the the slip plate setup.
Now I have a longacre toe gauge which is the 2 pointers and the scale on the aluminum pole. You are supposed to use a scribed line on the tire. But I am probably going to go off the square pipe hanger right up against the pointer.
I’m looking for a way to check thrust angle and to see if my method will work. What do you guys think??
deadstockpomp is offline   Reply With Quote
Old 11-09-2017, 04:18 PM   #2
MedicDG
Member#: 329822
2016 STi
I don't know about the thrust angle thing but I also do my own alignments at home using string method for toe and use a camber gauge for camber adjustments I bought online. I have done 2 alignments after suspension upgrades and my car drives straight down the road.
It's not hard to do alignments at home. U must have right tools and a lot of time on your hands.
MedicDG is offline   Reply With Quote
Old 11-09-2017, 04:22 PM   #3
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
Why not support your local alignment guy and save yourself the headache and time? Oh yeah, bragging rights! I mean, maybe if you’re doing them all the time or live in the middle of a forest.
fuelMuncher is offline   Reply With Quote
Old 11-10-2017, 12:41 AM   #4
MedicDG
Member#: 329822
2016 STi
Why? Because most of alignment places don't have a clue what they are doing. Every alignment I even gotten has sucked! My vehicle would pull right or left and do everything but track straight down the road. Started doing my own and dead centered steering wheel and no pull.
Old 11-10-2017, 02:08 AM   #5
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
White GF8 wagon
Cool
It's often the "local alignment guy" who wastes our time and gives us the headache.
More power to the DIYer!
Vancouver98STi is offline   Reply With Quote
Old 11-14-2017, 03:15 PM   #6
DNeid
Member#: 465701
WELL devils advocate here, you could always need to do the alignment just enough to get the car moving forward by any stretch of the term to get it to a shop. im probably gonna need to do that myself soon
DNeid is offline   Reply With Quote
Old 11-14-2017, 03:43 PM   #7
Plecain
Member#: 453598
2017 WRX Base
Red
Default local guy
If the 'local alignment guy' would align the car like I tell him to, that would be fine.
Usually, though, they'll insist on aligning it to 'manufacturer spec'. The tolerances on those specs are very wide.
Plecain is offline   Reply With Quote
