Brakes & Suspension Forum sponsored by The Tire Rack |
07-25-2015, 05:25 PM | #726 |
Member#: 325693
Vehicle:2015 WRX SOLD |
The camber looks close at least, nothing they can do in the rear for camber. They just completely f'd up your rear toe, if they won't correct find a new shop.
What were you wanting to be set at?
07-25-2015, 05:46 PM | #727 |
Member#: 388034
Vehicle:2015 WRX Limited Crystal White Pearl |
They didn't charge me. They just said there's literally nothing they can do unless I buy adjustable parts. I was hoping to just get to RCE's recommended settings
07-25-2015, 05:50 PM | #728 |
Member#: 325693
So they can adjust your front camber and toe...you can get -1 front camber easily. Rear camber they cannot adjust but all of your toe can be adjusted without anything.
The ONLY thing they would need is something to fix your rear camber If you don't want to be at -2. I guess as wrxlaunch said just go to another shop. |
07-26-2015, 01:53 AM | #729 | |
Member#: 421937
SCIC
Vehicle:2015 WRX WR Blue |
Can't go wrong with an s2k |
07-26-2015, 12:08 PM | #730 | |
Member#: 337075
BAIC
Vehicle:2016 STI Limited Silver |
Also, how does a brand new car become so out of spec WRT caster? 7 degrees on the left side and 5 something on the right side? Ducksauce, did you install these yourself? Are you sure you did it correctly? You may want to have someone fix it for you. Find a reputable shop...not wheel works or goodyear or firestone. |
07-26-2015, 12:39 PM | #731 |
Member#: 325693
Front says -.9 and -.7. rear I missed it was positive in the bottom right. Not sure how that could have happened either.
07-27-2015, 01:50 PM | #732 |
Member#: 54202
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
Seriously, the only way you're getting +2 degrees of rear camber on your car is if you got hit by a bus or something. My guess is their machine isn't calibrated or the tech just didn't do it correctly. I would recommend another shop. - Andrew |
07-27-2015, 07:07 PM | #733 |
Member#: 41863
NESIC
Vehicle:2015 STI Crystal Black Silica |
content deleted
07-28-2015, 11:28 AM | #734 |
Member#: 377200
Vehicle:21 Supra 3.0 MSM |
Ducksauce,
Try this guy if you are in Minneapolis. He is quirky, but really good. He did my alignment on my 15 WRX. Something seems really off. If this guy comes back and says your screwed it would seem to point to the springs being installed incorrectly. http://www.thealignmentguy.com/ |
07-28-2015, 09:46 PM | #735 |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
here we go, Day late but not a dollar short. wheel specs are 17x8 +45
07-28-2015, 10:24 PM | #736 |
Member#: 16969
SCIC
Vehicle:2015 WRX Limited Silver |
JDM 2015+ WRX S4 GT-S Bilstein struts+ Springs
07-29-2015, 06:46 AM | #737 |
Member#: 337626
TXIC
Vehicle:2015 WRX Crystal White Pearl |
07-29-2015, 12:27 PM | #738 |
Member#: 16969
SCIC
07-29-2015, 01:27 PM | #739 |
Member#: 337075
BAIC
Interesting...looks like the fronts are re-buildable with inserts.
07-29-2015, 03:15 PM | #740 |
Member#: 54202
Yeah the JDM ones have a weird shock profile too.
But our GTWORX rear will have 7 presets for rear height adjustability with the usual cir clips. In development for end of year. Usual lifetime warranty and matched to yellows and Blacks. Optional oem valving profile too. Myles |
07-29-2015, 05:38 PM | #741 |
Member#: 184571
Is anyone here running Tarmac 0s on their car? Looking to lower a bit more (about 1.25") than what the Yellows are offering without completely compromising ride quality.
07-29-2015, 09:35 PM | #742 |
Member#: 122924
SCIC
Vehicle:2011 sti spark silver |
Are rear 2015 sti + rear sway bars similar or identical to previous gr sti?
07-30-2015, 11:20 AM | #743 |
Member#: 416044
Vehicle:2015 Subaru WRX 6MT K1X |
07-30-2015, 11:31 AM | #744 |
Member#: 20952
Vehicle:BRZ & Datsun White & White |
07-30-2015, 11:41 AM | #745 | ||
Member#: 391748
NESIC
2015 WRX and STI suspension TECH thread.
Definitely low, but this really dials out the undeesteer. I would want more rear camber in an STi due to the diffs and less tendency to push It's a street driven care so it's not so much about all out grip as all out fun. And this thing feels sharp as a razor right now. Car rotates very well on throttle, Just need to be mindful of lift throttle oversteer in sweepers. I may have them dial it back a bit for the winter. We will see. Could be tons of fun.... |
07-30-2015, 12:46 PM | #746 |
Member#: 20952
That does sound fun.
The toe out could be a handful in the snow. The camber is probably fine though (not much roll happening). |
07-30-2015, 05:22 PM | #747 |
Member#: 327056
TXIC
Vehicle:2016 STI CWP |
Has the 2016 WRX w/inverted struts (18" wheels) been confirmed to work with these yet?
07-31-2015, 01:25 PM | #748 |
Member#: 181308
Vehicle:2016 WRX White |
I really wanted to do some yellows for my 2016 WRX but I think RCE is not gonna have them until later this year. Might have to spend my $$$ on a cobb AP in the time being.
08-01-2015, 12:04 AM | #749 |
Member#: 262657
NESIC
Vehicle:2016 WRX Prem Lapis Blue Pearl |
I've bumped asking about '16 fitment as well...
08-01-2015, 12:35 AM | #750 |
Member#: 181308
I'm sure it's a development thing. I will buy them when they do have them, but was hoping for sooner than later. The softer strut/shock thing must have really screwed stuff up. I guess waiting for them to get it right is a good them by too.
